POV-Ray : Newsgroups : povray.binaries.images : Ocean Server Time
27 May 2026 11:21:46 EDT (-0400)
  Ocean (Message 52 to 61 of 71)
Subject: Re: Ocean
Date: 7 Apr 2016 03:58:28
Message: <57061324$1@news.povray.org>
On 7-4-2016 9:17, Jaime Vives Piqueres wrote:
> El 05/04/16 a las 12:11, Jaime Vives Piqueres escribió:
>> ... still needs work.
>    Well, the proximity pattern is still not what I really need, but gets
> close. Unfortunately it really makes the render much slower (x4)...
> luckly I'm using a mesh: with an isosurface this would have taken almost
> 2/3 days.
This is very close indeed. Less convincing foam close up but in the
distance it looks very good.
Subject: Re: Ocean
Date: 7 Apr 2016 04:08:30
Message: <5706157e$1@news.povray.org>
> 2/3 days.
That looks good to me.
Sea state 5 or 6, I would guess.
In 2009 Edouard Poor created DF3 proximity pattern macros.
That might be worth a try.
Regards
Subject: Re: Ocean
Date: 7 Apr 2016 07:07:19
Message: <57063f67@news.povray.org>
>> 2/3 days.
I was going to suggest Edouard's macros too. I prefer them to Sam's and
believe them to be faster. Advantage is that the pattern is calculated
and saved to file before render.
Subject: Re: Ocean
Date: 7 Apr 2016 07:35:28
Message: <57064600$1@news.povray.org>
Am 07.04.2016 um 09:17 schrieb Jaime Vives Piqueres:
> 2/3 days.
I'm wondering: Presuming the foam is a texture (rather than a media
effect), shouldn't a slope pattern do the job?
Subject: Re: Ocean
Date: 7 Apr 2016 07:39:31
Message: <570646f3$1@news.povray.org>
   That's another matter... the foam texture is not very good. I find it
very difficult to get a convincing one.
jaime
Subject: Re: Ocean
Date: 7 Apr 2016 07:41:07
Message: <57064753$1@news.povray.org>
El 07/04/16 a las 10:08, Stephen escribió:
> That looks good to me. Sea state 5 or 6, I would guess.
   Thanks!
> In 2009 Edouard Poor created DF3 proximity pattern macros. That might
> be worth a try.
   Thanks, I will try... also the proximity pattern included on hgpovray
(I just found about it).
jaime
Subject: Re: Ocean
Date: 7 Apr 2016 07:47:01
Message: <570648b5$1@news.povray.org>
   Yes, it is a texture (well, a pattern for the combined water/foam
texture map). And yes, that's what I thought at first, so I tried a
slope y with altitude, but didn't work very well... maybe my fault at
implementing it, but then I thought about the proximity pattern thing,
so I abandoned the slope approach.
jaime
Subject: Re: Ocean
Date: 7 Apr 2016 09:52:38
Message: <57066626@news.povray.org>
Am 07.04.2016 um 13:47 schrieb Jaime Vives Piqueres:
I wouldn't use altitude, just the plain slope.
Given that the slope pattern is a lot faster than any proximity pattern,
I think it should be worth another try.
Subject: Re: Ocean
Date: 7 Apr 2016 10:26:34
Message: <57066e1a$1@news.povray.org>
> pattern, I think it should be worth another try.
   But just plain "slope y" shows foam also on "valley" parts of the
surface, not only on the crests. Or are you suggestion another approach?
jaime
Subject: Re: Ocean
Date: 7 Apr 2016 10:54:39
Message: <570674af@news.povray.org>
Am 07.04.2016 um 16:26 schrieb Jaime Vives Piqueres:
From what I see the waves aren't sinusoidal, but have "sharp" peaks, so
a high slope should be the proper indicator.
Then again, I must concede that this idea crumbles if the peaks aren't
perfectly sharp after all.
Let's take a step backward:
What you want is foam at the crests, i.e. near local maxima.
Local maxima can be identified by a zero 1st derivative (aka slope) and
negative 2nd derivative (aka curvature).
It should be possible to analyze the f_ridged_mf() function in order to
construct the 1st and 2nd derivative functions, and use the resulting
functions as a basis for a foam pattern. (If you want to avoid function
analysis, you could still design functions for the slope and curvature
that effectively take samples from the original function.)
