POV-Ray : Newsgroups : povray.binaries.images : Spinner colony (again) Server Time
27 May 2026 13:54:48 EDT (-0400)
  Spinner colony (again) (Message 50 to 59 of 59)
Subject: Re: Spinner colony (again)
Date: 24 Feb 2015 18:54:59
Message: <54ed0f53$1@news.povray.org>
On 2/24/2015 5:11 PM, Alain wrote:
>> I got some very good suggestions in this post:
>> https://forum.geogebra.org/viewtopic.php?p=139143#p139143
>> The problems now are that:
>> 1. Should I collect the light from the direction the ship is heading, or
>> extending from the rotating ring? The ship will not be facing the sun
>> 100% of the time.
>> 2. I'm running out of room to place the mirrors.
> Place the mirrors on pivots, with some actuators, mounted on rails that
> run the length of the hull.
> That way, you can place the mirrors in the most effecient way.
What sort of pivots? Wouldn't that cause the mirrors to point away from
the agridomes? Do you mean tracks of some sort?
Date: 24 Feb 2015 18:56:57
Message: <54ed0fc9$1@news.povray.org>
On 2/24/2015 3:24 AM, Le_Forgeron wrote:
> Le 24/02/2015 02:45, Mike Horvath a écrit :
>> I tried turning on the atmosphere and area light in my latest version of
>> the spaceship interior, but after 10 hours the render was at 8% and
>> hadn't reached the slow bits yet. I will try again in 10 years. :(
> What size of area light (in term of row & column) did you try ?
> (did you try a preview with only 2x2 area lights, to get an idea of time
> to render ?)
> What option (adaptative ? +AM2 or +AM1 ?) are you using to speed up area
> lights ?
The area light is a 16x1 grid. Anything less leaves weird shadows.
Date: 24 Feb 2015 23:27:04
Message: <54ed4f18$1@news.povray.org>
On 2/20/2015 7:40 PM, Mike Horvath wrote:
> My latest render. I'm satisfied with the inner/outer hull viewport area.
> I think now it is time to consider propulsion. A nuclear pulse drive
> like Project Orion could work. I would have to model some shock
> absorbers, and the pressure pad would need to be flat instead of
> parabolic (or not?).
> I'm actually not sure what my other options are.
The latest source code can be found here:
https://www.mediafire.com/?u11o46byrcjlfn6
The relevant files are:
gh_scene_spinner_interior.pov
gh_scene_spinner_cutaway.pov
There are quite a few dependencies. I'll try and list them all here:
// 1. Chris Colefax for the CITY GENERATOR INCLUDE FILE which I have
heavily modified.
// 2. Rune's particle system
// 3. GALAXY INCLUDE FILE FOR PERSISTENCE OF VISION
// 4. Meshmerizing Mesh Maker Macros
// 5. http://www.ignorancia.org/en/index.php?page=Lightsys
// 6. Truss Generator include by Theran Cochran
// 7. sphere.inc by Shuhei Kawachi
// 8. grasspatch.inc by Josh English
// 9. SPACE AGE TrueType font
// 10. Joseph Hewitt for most of the mecha models, except for items like
the hovercraft which I got from TurboSquid, as well as my own Lego models.
// 11. Raumschiff5.inc, Horus.inc by Frank Bruder
// 12. eagle.pov from the Object Collection
// 13. vulture.pov from the Object Collection
My modified City Gen is included in the zip file. Joseph Hewitt's mecha
models are included in the "models" sub-directory. If you need more help
just let me know.
Date: 26 Feb 2015 16:13:49
Message: <54ef8c8d@news.povray.org>
Am 16.02.2015 um 15:10 schrieb Stephen:
> texture {
>    pigment {
>      color rgbft <0.122,0.122,0.122,0.000,0.000>
>    finish {
>      diffuse     0.600
>      metallic    1.000
>      reflection {
>        rgb <0.481,0.301,0.133>, rgb <0.722,0.451,0.200>
>        fresnel   0
>        falloff   0.000
>        exponent  1.000
>        metallic  0.000
Don't do that; this will make highlights white while making reflections
coloured, which is a particularly bad idea (unrealistic combination).
Also, polished metals should only have a very low diffuse (if any), and
minimum reflection should be 0.0. So instead of the above, use something
like this:
       color rgbft <1.00, 0.62, 0.28, 0, 0>
    finish {
       diffuse     0 // or some very low value
       metallic    on
       reflection {
          0.722
          metallic on
Date: 26 Feb 2015 16:15:55
Message: <54ef8d0b@news.povray.org>
>>> 100% of the time.
Some pivots that allow 2 levels of freedom. A cardant joint would work,
or a ball and socket one.
The actuators are used to orient the mirrors toward the agridomes.
The rails/tracks are used to move the mirrors do that they are not in
the shadow of something else.
Date: 26 Feb 2015 17:12:57
Message: <54ef9a69$1@news.povray.org>
Good advice in general. My example was just to show that you could add a
coloured tinge to a reflection. It is way to high to be a tinge I admit.
Take heed all. :-)
In my haste I just used the defaults built into Bishop3D. :-(
Regards
Date: 26 Feb 2015 17:19:16
Message: <54ef9be4@news.povray.org>
For my latest render I turned on the atmosphere. However, it resulted in
the super blue colors you can see in the attached image. What is the
cause and how do I tone it down?
Here's my material:
	#declare atmos_material = material
		// check TexQual here?
		texture {pigment {color rgb 1 transmit 1}}
		interior
			media
				scattering
					4, <0.2,0.4,1.0>/8000	// crappy approximaion of TerraPOV value
					extinction	1
				samples	1,1
				density
					cylindrical
					poly_wave	0.25
					density_map
						[0	srgb 1]
						[1	srgb 0]
					scale	city_radius
		rotate	x * 90
Download 'gh_scene_spinner_interior_26.png' (870 KB)
Preview of image 'gh_scene_spinner_interior_26.png'
Date: 26 Feb 2015 19:06:50
Message: <54efb51a$1@news.povray.org>
I think that may take up too much space. The whole assemblage would also
have to rotate around the ship along with the agridomes.
Date: 27 Feb 2015 03:14:14
Message: <54f02756$1@news.povray.org>
I would strongly tone down the blue component in the scattering. You
will need to find what suits you best. Start with <0.2, 0.4, 0.5> and go
up or down.
Date: 27 Feb 2015 19:12:17
Message: <54f107e1$1@news.povray.org>
Am 26.02.2015 um 23:19 schrieb Mike Horvath:
Why bother simulating an atmosphere at all? At those sizes, it shouldn't
make any visible difference anyway.
