POV-Ray : Newsgroups : povray.binaries.images : unexplained Server Time
27 May 2026 20:30:41 EDT (-0400)
  unexplained (Message 41 to 50 of 58)
<<< Previous 10 Messages Goto Latest 10 Messages Next 8 Messages >>>
Subject: Re: unexplained
Date: 20 Aug 2014 09:40:11
Message: <53f4a53b$1@news.povray.org>
Am 20.08.2014 15:26, schrieb James Holsenback:
> OTO_Get_Mask
> <-8.00000000000000000000,-5.00000000000000000000,0.0000000000000000
> 0000> Result:0.99999997764825820923
> Hmmm ... OK I think this shows problem the above is output from inside
> the OTO_Get_Mask function ... I now see why reversing the logic (and my
> "on a lark" test) in corner test works
Bingo!
Okay, you obviously have already figured a way around this problem by
way of modifying OTOc.inc, and I think I now have enough information to
go hunting for the root cause in the codebase.
I might come back to you for testing of some code modifications, if
that's ok for you.
Date: 20 Aug 2014 10:00:43
Message: <53f4aa0b$1@news.povray.org>
> that's ok for you.
ok fine
Date: 20 Aug 2014 16:00:43
Message: <53f4fe6b$1@news.povray.org>
> I'm confused now ... aren't
> #if(OTO_Get_Mask(Vec)=1)
This is /true/ if and only if the result *is* 1 (one)
> and
> #if(OTO_Get_Mask(Vec))
This is /false/ if and only if the result *is* 0 (zero)
> functionally the same?
So, not at all *unless* the result can only be zero or one.
Date: 28 Aug 2014 13:41:55
Message: <53ff69e3@news.povray.org>
>> OTO_Get_Mask
> Bingo!
> that's ok for you.
curious if you've had any time to follow up
Date: 28 Aug 2014 14:08:50
Message: <53ff7032$1@news.povray.org>
Am 28.08.2014 19:41, schrieb James Holsenback:
>>> OTO_Get_Mask
>> Bingo!
>> that's ok for you.
Not yet, sorry.
Date: 6 Jan 2015 17:43:00
Message: <54ac64f4$1@news.povray.org>
Am 28.08.2014 um 19:41 schrieb James Holsenback:
>>> OTO_Get_Mask
>> Bingo!
>> that's ok for you.
Now that I've returned from outer space, I have at last; can you please
try the following patch:
At the beginning of source/base/colour.h, around line 95, replace the
following lines:
const float kRedIntensity   = 0.297;
const float kGreenIntensity = 0.589;
const float kBlueIntensity  = 0.114;
with this:
const PreciseColourChannel kRedIntensity   = 0.297;
const PreciseColourChannel kGreenIntensity = 0.589;
const PreciseColourChannel kBlueIntensity  = 0.114;
I /think/ it should fix the issue. The culprit would then have been
change 0ea2da4.
Date: 13 Jan 2015 14:02:09
Message: <54b56bb1$1@news.povray.org>
>>>> OTO_Get_Mask
>>> Bingo!
>>> that's ok for you.
Well my job (10hrs a day 7 days a week) is a black hole ...
> following lines:
> with this:
> change 0ea2da4.
I will do my best, but can't promise any sort of time frame
Date: 14 Jan 2015 03:26:37
Message: <54b6283d$1@news.povray.org>
No kidding? Slavery has been prohibited as far as I know... :-\
Date: 23 Jan 2015 13:25:21
Message: <54c29211@news.povray.org>
>>>> OTO_Get_Mask
>>> Bingo!
>>> that's ok for you.
> following lines:
> with this:
> change 0ea2da4.
I'm unable to get a clean build after beta6 and I don't have time to
troubleshoot. Wooo hoo I'm getting my 1st day off (this coming sunday)
since the 1st of the year, and I'm not inclined to spend that time
trying to unravel. I DID however notice you made a change on the Wiki to
the "Strings" documentation. What time frame are you looking at for a
release? There have been other doc changes since last release and I'd
like to pick up the changes and post the new doc sets if there aren't
any more changes.
Date: 23 Jan 2015 17:04:45
Message: <54c2c57d$1@news.povray.org>
Am 23.01.2015 um 19:25 schrieb James Holsenback:
> troubleshoot.
beta6? Wait, that's UberPOV, isn't it?
It was my understanding that we were talking about fixing POV-Ray proper
for now. Once we have that sorted out, it can be merged into UberPOV.
> trying to unravel.
Can't blame you :D
> any more changes.
As for a full-fledged official release, with installer and all, I guess
you'll have to ask Chris about that one. He had intended to do a build
earlier this month, but it seems like real life interfered.
I've just released a new semi-official development build (see
povray.beta-test), but that's just a drop-in replacement for the binary,
without any docs.
