POV-Ray : Newsgroups : povray.binaries.images : Skyrim (and beyond) Server Time
26 May 2026 14:40:14 EDT (-0400)
  Skyrim (and beyond) (Message 4 to 13 of 36)
<<< Previous 3 Messages Goto Latest 10 Messages Next 10 Messages >>>
Subject: Re: Skyrim (and beyond)
Date: 15 Oct 2012 11:44:18
Message: <507c2f52@news.povray.org>
I do believe I just clicked on the 'reply' button instead of 'followup'...
...again.
Really dislike that 'feature' of Thunderbird.
I think the data I pulled is the level-of-detail terrain data from
in-game, one or another of which is used as the world-map as well...?
I'm of half a mind to take and scale the meshes so they match what I've
been able to discern of 'real' distances for things; they're squished
about 10x laterally and stretched 10x vertically, so when you correct
for that, Skyrim's a lot flatter.  (It's about 250 lore-canon miles from
Dawnstar to Windhelm, or something like that...?  Whereas in-game, if
you use their 128 units = 6 feet, it's only about 25 miles.  And the
Throat of the World is iirc 52 miles high--again with the 128 units to 6
feet measure.)
Date: 15 Oct 2012 16:30:01
Message: <web.507c7131f9ac85a3474fd52e0@news.povray.org>
Tim Cook <z99### [at] gmailcom> wrote:
> This rendering was actually made a bit over a month ago, as a supplement
> to my primary project of making a topographic map of Skyrim.  That,
> while based on a render of the game terrain data with a gradient slapped
> on it to indicate elevations, is needing to be redone by hand to get
> consistent-width contour lines (if I were clever, I'd probably be able
> to figure out something much simpler and faster as an automated process,
> but what can I say, glutton for punishment or something), so doesn't
> really qualify for posting here.
Try out the following if/when you have a chance:
#declare NLines  = 10; // number of elevation lines
#declare LineSize = 2; // line size in pixels (1.0-2.0)
#declare LineOffs = 0; // line offset (phase)(0.0-1.0)
// your input pigment
#declare PgInput =
 pigment{
  bumps
  turbulence .5
  lambda 2.5
#declare FInput =
 function{
  pattern{
   pigment_pattern{
    PgInput
    phase LineOffs/NLines
    color_map{
     #for(V, 0, NLines)
      [V/NLines rgb (mod(V,2)=0)]
      [V/NLines+1/NLines rgb (mod(V,2)=0)]
#declare FSpherical = function{pattern{spherical}}
#declare PgElevationLines =
 pigment{
  #declare LineSizeX = LineSize/image_width;
  #declare LineSizeY = LineSize/image_height;
  function{
   FSpherical(
    FInput(x+LineSizeX, y, 0)-FInput(x-LineSizeX, y, 0),
    FInput(x, y+LineSizeY, 0)-FInput(x, y-LineSizeY, 0),
    0
plane{z,0
 pigment{PgElevationLines}
It's really only good for line thicknesses between 1-2 pixels, but at least the
lines are of an even width. Antialiasing is recommended. Hope it helps!
Sam
Date: 15 Oct 2012 17:05:00
Message: <web.507c79ecf9ac85a3d09d0ca60@news.povray.org>
Here's a version using an improved method. Elevation lines of any thickness will
be drawn properly, at the expense of PPS:
#declare NLines  = 10; // number of "elevation" lines
#declare LineSize = 3; // line size in pixels (1.0-?)
#declare LineRes = LineSize*16; // number of line samples (1=?)
// input pigment
#declare PgInput =
 pigment{
  bumps
  turbulence .5
  lambda 2.5
#declare FInput =
 function{
  pattern{
   pigment_pattern{
    PgInput
    color_map{
     #for(V, 0, NLines)
#macro SampleLoop()
 #for(N, 1, LineRes)
  #local C = 1/LineRes*N;
  #local R = pow(C*sqrt(N)/pow(LineRes,.5),1/3);
  #local Angle = N*137.508;
  #local Pt = vrotate(y*R, z*Angle);
  #local PtX = Pt.x*LineSizeX;
  #local PtY = Pt.y*LineSizeY;
  , FInput(x+PtX, y+PtY, 0)
 pigment{
  function{
   min(1 SampleLoop())*(FInput(x, y, 0)=1)
   (1-max(0 SampleLoop()))*(FInput(x, y, 0)=0)
plane{z, 0
Date: 15 Oct 2012 19:40:01
Message: <web.507c9e11f9ac85a32165ae730@news.povray.org>
I believe the code has reached its final state. Elevation lines are now mapped
correctly starting at elevation=0.0. Included is an option for using smoothed
lines or not, and it's all wrapped up nicely into a macro that produces a
pigment_pattern.
Use it or don't; I always script for fun :)
http://news.povray.org/povray.text.scene-files/thread/%3Cweb.507c9bbc53181abf2165ae730%40news.povray.org%3E/
Sam
Date: 15 Oct 2012 19:50:01
Message: <web.507ca0ecf9ac85a3721473b50@news.povray.org>
Attached is an image rendered from the example scene, using eight elevation
lines. An acceptable result, IIDSSMS, although calculating the number of lines
needed for real-world data might prove to be somewhat of a challenge!
Download 'elevationlines.png' (119 KB)
Preview of image 'elevationlines.png'
Date: 15 Oct 2012 22:15:14
Message: <507cc332$1@news.povray.org>
Needs a bit of fiddling (go right-hand rule!) and POV 3.7 to work, but...
...need to figure out proper scaling and offset, but I think that just
might let me bypass another month of hand-drawing contour lines.
Thanks!
Tim Cook
http://empyrean.sjcook.com
Date: 16 Oct 2012 03:06:59
Message: <507d0793$1@news.povray.org>
> pigment_pattern.
Incredible, Sam. This can be a very useful feature. I shall certainly
use it. Thanks indeed.
Date: 16 Oct 2012 07:40:20
Message: <507d47a4@news.povray.org>
A'ight, I think I'm doing something wrong here, because I'm not getting
the fixed-width contour lines.
Here's relevant bit of SDL:
#declare East_Land4 = union {
   object { Land4_P00P00_to_P12P28 }
   object { Land4_P20P00_to_P28P28 }
   object { Land4_P00M04_to_P12M32 }
   object { Land4_P16M04_to_P32M32 }
   object { Land4_P32P00_to_P44_28 }
   object { Land4_P48P00_to_P60P28 }
   object { Land4_P32M04_to_P44M32 }
   object { Land4_P48M04_to_P60M32 }
   object { tamriel_4_12_60_ }
   object { tamriel_4_28_60_ }
   object { tamriel_4_44_60_ }
   object { tamriel_4_60_60_ }
   #declare InputPigment = pigment{
     gradient z
     rotate x*90
   pigment{
     Pg_Elevation_Lines(
       InputPigment,
       8,
       3,
       8,
       0,
       on
     pigment_map{ [ 0 InputPigment][ 1 rgb x] }
     rotate -90 * x
     scale 16384.0 * 3.2
     translate <0.0, 0.0, -13800.0>
   finish{ ambient 1 diffuse 0 }
Halp?
Tim Cook
Download 'tamrieleast.png' (217 KB)
Preview of image 'tamrieleast.png'
Date: 16 Oct 2012 08:50:00
Message: <web.507d579ef9ac85a35b7d07940@news.povray.org>
> ...again.
Oh yes. I've not yet been to Dawnstar, Riften or Morthal so I couldn't comment!
Trying to keep the quest list down to a manageable size :)
> feet measure.)
I thought so, or it would take weeks to cross wilderness! It's quite a clever
effect though, the landscape hides the locations' proximities so on the ground
it feels like a real, large world.
If you get Sam's contours working, it'd be fun to see a tourist hiking map :)
Date: 16 Oct 2012 15:20:00
Message: <web.507db334f9ac85a35f336ae30@news.povray.org>
>      gradient z
>      rotate x*90
>    pigment{
>      Pg_Elevation_Lines(
>        InputPigment,
>        8,
>        3,
>        8,
>        0,
>        on
>      rotate -90 * x
>      scale 16384.0 * 3.2
> Halp?
A simple "gradient z" will not work because it doesn't contain any topographical
information describing your landscape. The macro requires a height map, so
you'll need to produce one from East_Land4 and then pass it to the macro. (You
might even be able to use it for a height_field object instead of that union of
objects you have now, but I'm not sure, since I don't know how your scene is set
up.)
Once you have your height_map, you'll be going forward again. If not, just give
me a holler :)
