POV-Ray : Newsgroups : povray.binaries.images : Early Earth: The Late Heavy Bombardment Server Time
21 Apr 2026 23:56:07 EDT (-0400)
  Early Earth: The Late Heavy Bombardment (Message 21 to 30 of 36)
<<< Previous 10 Messages Goto Latest 10 Messages Next 6 Messages >>>
Subject: Re: Early Earth: The Late Heavy Bombardment [final image]
Date: 10 Jul 2012 07:32:34
Message: <4ffc12d2$1@news.povray.org>
On 10-7-2012 10:07, Paolo Gibellini wrote:
>  >Thomas de Groot  on date 09/07/2012 14.03 wrote:
>> This should be the final development of the scene.
>> Thomas
> Ooh.
> The explosion is less terrifying (due to the daylight), but the sea and
> the fog are very convincing.
Thanks Paolo. I am still terrified though ;-)
I am adding a spherical shock wave to complete the impact.
For the fog over the water I used a df3 file made with Gilles Tran's
MakeCloud.
Date: 11 Jul 2012 07:32:20
Message: <4ffd6444@news.povray.org>
This is really the final image. Added a spherical shock wave.
Download 'earlyearth - lhb_final.png' (835 KB)
Preview of image 'earlyearth - lhb_final.png'
Date: 11 Jul 2012 16:30:51
Message: <4ffde27b$1@news.povray.org>
> Thomas
I have some problem with that shock wave: It don't difract light.
A shell with an ior of about 1.1 to 1.17 would be more convincing.
Date: 12 Jul 2012 04:43:33
Message: <4ffe8e35@news.povray.org>
This gets me into problems :-(
For the example I switched off the solid ejecta. I also tuned down the
fog over the water.
For the shock wave I used an ior of 1.01. Obviously, now its media
interacts with the other media inside, especially the dust ejecta
container. Higher ior makes it worse.
Download 'earlyearth - lhb.png' (159 KB)
Preview of image 'earlyearth - lhb.png'
Date: 12 Jul 2012 18:49:11
Message: <4fff5467$1@news.povray.org>
> fog over the water.
> Thomas
It looks like a solid, full, shell. Make the shock wave shell as a
difference of 2 spheres.
To bad we can't have variable ior, as in this case, it should go from 1
(in the air in front of the wave), raise in an S shape to maybe around
1.1, then drop slightly under 1 before returning to 1.
You may also try playing giving the area inside the sinside an ior
slightly less than 1, like 0.98 to 0.995...
Date: 13 Jul 2012 03:45:12
Message: <4fffd208$1@news.povray.org>
I did too but that was not better, rather worse.
Yes, that would be cool.
Yes, I tried too. It corrected somewhat the inner media but did not
change the chock wave appearance.
I shall still make a couple of experiments.
Date: 13 Jul 2012 10:56:22
Message: <50003716@news.povray.org>
The best I can get at this stage (no good) using a differenced sphere
for the shock wave. Diffractions looks ok at the border but I cannot get
the transparency of the sphere right. The cloud layer is also
differenced (a tiny bit larger sphere) to ensure that no clouds are
present inside the shock wave.
Code snippet:
difference {
sphere {0, 1
   hollow
   texture {pigment {rgbt <1,1,1,1>} }
   interior {
	  ior 1.1
     media {
       intervals 1
       samples 10, 1000
       scattering {1, 0.000025
         extinction 1
sphere {0, 0.98
   hollow
   interior {
	  ior 1.0
   scale MediaScale * 1.52
   translate <CamLoc.x, CamLoc.y, 5000> + <2800, 0, 0>
Download 'earlyearth - lhb.png' (114 KB)
Subject: Re: Early Earth: The Late Heavy Bombardment [experimental image #2]
Date: 14 Jul 2012 04:01:22
Message: <50012752@news.povray.org>
Trying to get at the problem. I here switched off the sphere
representing the sky and the atmospheric media. Also corrected the shock
wave container as follows:
//start code
difference {
   sphere {0, 1.00 hollow}
   sphere {0, 0.98 hollow}
   material {
     interior {
       ior 1.1 	//shock waved air
       media {
         intervals 1
         samples 10, 1000
         scattering {1, 0.0001
           extinction 1
//end code
While one can see /inside/ the shock wave, it is not possible to see the
stars through the opposite end of the sphere... why?
Download 'earlyearth - lhb.png' (145 KB)
Subject: Re: Early Earth: The Late Heavy Bombardment [experimental image #3]
Date: 14 Jul 2012 08:13:06
Message: <50016252@news.povray.org>
OK. Got the transparency solved. Just a stupid max_trace_level issue :-(
Next problem is to get rid of this sphere edge seen in cross section...
Download 'earlyearth - lhb_.png' (144 KB)
Preview of image 'earlyearth - lhb_.png'
Date: 14 Jul 2012 08:47:06
Message: <50016a4a$1@news.povray.org>
Am 14.07.2012 10:01, schrieb Thomas de Groot:
max_trace_level maybe?
