POV-Ray : Newsgroups : povray.binaries.images : A couple of isosurfaces Server Time
4 Nov 2024 12:50:27 EST (-0500)
  A couple of isosurfaces (Message 1 to 10 of 22)
Subject: A couple of isosurfaces
Date: 8 Jul 2010 08:25:01
Message: <web.4c35c2cf80efe655caa39c860@news.povray.org>
I keep e-mailing myself things I made in my lunch break to post here when I get
home, and then I get home and don't switch the PC on... :-/ So I'm posting via
the web interface in my lunch break instead*.
Anyway, here's a couple of isosurfaces I came up with recently. Both are very
slow, but quite pretty (IMO).
The reinforced concrete is an inverse isosurface, differerenced with a block. I
wanted to see if I could carve a realistic decay into an object without needing
the shape of the object itself to be an isosurface.
The other picture is a substance I've christened Greebelium :) It's a
multi-fractal based on crackle metric 1 (3 octaves, scale and amplitude reduced
by 1/4 with each octave).
What do you think?
Anyone want source with that?
Tek
http://evilsuperbrain.com
*Grammar fail, my lunch break has a web interface?
Download 'decay.jpg' (76 KB)
Preview of image 'decay.jpg'
Subject: Re: A couple of isosurfaces
Date: 8 Jul 2010 08:35:00
Message: <web.4c35c4d3e5fe6399caa39c860@news.povray.org>
Doh, can only attach 1 picture in web interface. Here's the greebelium.
Download 'greebelium.jpg' (83 KB)
Preview of image 'greebelium.jpg'
Date: 8 Jul 2010 11:15:01
Message: <web.4c35eb0de5fe639938b61e700@news.povray.org>
> What do you think?
> Tek
Beautiful image Tek. By the way, what about render time?
Keep up the good work.
Txemi Jendrix
http://www.txemijendrix.com
Date: 8 Jul 2010 11:16:30
Message: <4c35ebce$1@news.povray.org>
Amazing.
> What do you think?
> Tek
Date: 8 Jul 2010 11:40:01
Message: <web.4c35f0d3e5fe6399caa39c860@news.povray.org>
> > What do you think?
> > Tek
> Txemi Jendrix
The concrete took many hours to render (I don't remember how many, it was an
overnight render). The Greebelium took 2 hours.
That's on my work PC, an Intel Core2 Quad Q9300 2.5GHz. Using Pov 3.7 on all 4
threads.
Date: 8 Jul 2010 13:55:01
Message: <web.4c361076e5fe6399320e5be10@news.povray.org>
> What do you think?
The concrete block looks pretty good. I'm not sure what purpose such a solid
chunk of cement would serve, but it looks pretty cool nonetheless. It's too bad
isosurfaces must always render so slowly :(
If you had made that statement regarding your lunch /box/, I might have believed
you :P
Date: 8 Jul 2010 20:22:25
Message: <4c366bc1$1@news.povray.org>
news:web.4c35c2cf80efe655caa39c860@news.povray.org...
>get
> via
> very
> block. I
> needing
> reduced
> What do you think?
> Tek
Amazing!  That first image is brilliant, I'd love to take a look at the
source please please pretty please :)
Cheers Dre
Date: 9 Jul 2010 04:02:58
Message: <4c36d7b2$1@news.povray.org>
Very convincing, both of them. I am certainly interested in seeing the
code... :-)
Date: 9 Jul 2010 04:35:01
Message: <web.4c36dec7e5fe6399caa39c860@news.povray.org>
And here's a frickin' huuuge render of the greebelium, for my desktop (and
anyone else's that wants it).
It took 5h32m.
Tek
Download 'greebelium1_5h32m.jpg' (506 KB)
Preview of image 'greebelium1_5h32m.jpg'
Date: 9 Jul 2010 04:45:01
Message: <web.4c36e0afe5fe6399caa39c860@news.povray.org>
Ok the source for both objects is pretty small, so I'll just drop it in
here:
//------Greebelium------
isosurface {
 #declare Funches =
  function { pigment {
   average
   pigment_map {
    #local a = 1;
    #local i=0; #while ( i < 3 )
     [a crackle metric 1 pigment_map { [0 rgb .5][.1 crackle metric 1 solid
colour_map { [.5 rgb 0][.5 rgb 1] }] } scale a]
    #local a=a/4; #local i=i+1; #end
 // trap the pattern between low & high levels...
 function {
  max( y-.5+.5 - Funches(x,y,z).x, min( y+.5/*+.5 - Funches(x,y,z).x*/,
 max_gradient 20
 contained_by { box { -<5,1,5>, <5,1,5> } }
//------Concrete with Rebar------
#macro DecayBlob(Pos)
 isosurface {
  #local Off = VRand(rs)*100;
  #local f_Hole =
    average
    pigment_map {
     [1 spherical scale 2 cubic_wave translate Off warp { turbulence .5 octaves
3 } translate -Off]
     [1 pigment_pattern { granite translate Off scale 5 Flip() } poly_wave 2]
     [.4
      pigment_pattern {
       #local f = function { 1-sqrt(min(min(x*x+y*y,x*x+z*z),y*y+z*z))/sqrt(2) }
       function { min(1,max(0,f(sin(x)*4,sin(y)*4,sin(z*4))*5-3)) }
       cubic_wave
       scale 1/pi
       translate .5
       scale .8
       warp { turbulence .2 octaves 3 }
      Flip()
      translate -Pos // so they line up in different holes
  function {
   1-2*f_Hole(x,y,z).x
  max_gradient 8
  all_intersections
  contained_by { sphere { 0, 2 } }
  scale .5
  translate Pos
difference {
 superellipsoid { <.1,.1> normal { granite .2 accuracy 1/1000 } }
 #local rs = seed(7);
 #local i=0; #while ( i < 5 )
  #local Norm = <0,0,0>;
  #local Pos = SphereRand(rs);
  #local Pos = trace( Thobject, Pos*2,-Pos, Norm );
  #if ( vlength(Norm) > 0 )
   DecayBlob(Pos)
   #local i=i+1;
