POV-Ray : Newsgroups : povray.binaries.images : rendering height fields with overhangs Server Time
9 Jun 2026 05:39:17 EDT (-0400)
  rendering height fields with overhangs (Message 8 to 17 of 17)
<<< Previous 7 Messages Goto Initial 10 Messages
Subject: Re: a less buggy hf_slicer
Date: 18 Dec 2009 19:15:00
Message: <web.4b2c1ab75f6b9df6a049a19e0@news.povray.org>
stbenge <UN### [at] hotmailcom> wrote:
> Those other ones were quite buggy. Odd numbers wouldn't work, the
> function for testing the control pigment wasn't accurate, and the thing
> was not filling a unit cube correctly.
> While testing this, also I realized that the more it stretches a
> height_field, the slower it becomes. I wish I could make it more
> efficient somehow.
Hi Samuel
I had a look at your macro to see if I could make it more efficient.
Here's what I came up with:
#macro SliceHF(HeightField, ControlPigment, NrOfSlices)
  #local Step = 1/NrOfSlices;
  #local M_Fn = function { pigment { ControlPigment } }
  #local N_Fn = function(_C) { M_Fn(0, _C*Step, 0).gray }
  union {
    #local Cn = 0;
    #local Dn = N_Fn(Cn);
    #while (Cn < NrOfSlices)
      #local Cp = Cn;
      #local Cn = Cn + 1;
      #local Dp = Dn;
      #if (Dn != Dp)
        intersection {
          object { HeightField }
          box { <0, Dp, 0>, <1, Dn, 1> }
          translate -Dp*y
          scale <1, Step/(Dn - Dp), 1>
          translate Cp*Step*y
      #end // if
    #end // while
#end // macro SliceHF
But I'm not sure if it still works like you intended.
Tor Olav
http://subcube.com
Date: 19 Dec 2009 14:23:41
Message: <4b2d283d@news.povray.org>
>> efficient somehow.
> Hi Samuel
It seems to work better than my versions.
With the changes you made, it might be actually be advantageous to use
this instead of an isosurface for some things.
Thanks! If I release another version of hf_tools.inc, I'll include your
version and give you proper credit :)
Subject: Re: rendering height fields with overhangs
Date: 19 Dec 2009 15:25:00
Message: <web.4b2d3604ce3532365f302820@news.povray.org>
> Hello,
> Here's a method for slicing a height_field into many pieces and
> translating/scaling the parts to create caves and overhangs. It renders
> faster than an isosurface...
Once again, you've come up with some magical sleight-of-hand! (Your POV code
creations are coming so fast, I can't keep up with them!) I was hoping someone
might come up with a method for producing HFs with overhangs. Kudos to you!
Results so far just astound me; it's one amazing tool. (I haven't yet tried Tor
Olav's version; just noticed it.) In the short time I've been playing with your
version #3 code, there seem to be endless shapes it can produce (by varying this
or that parameter.)  Yeah, I'm experimenting with some of your code, adding
things here and there, doing everything I can to break it (!) just to see what
will happen--then putting it back together, of course. :-) I continue to
'examine' the code to see how it operates, and what exactly it does. Seems like
voodoo at present.  :-p
BTW, a question about one of your #while loop lines:
hfs_pv=hfs_function(0,hfs_V,0).x
Any particular reason why you used .x (i.e., .red) rather than .gray?  Just
curious.
Your slicing method shows GREAT promise, so by all means continue with its
development. I foresee *many* uses for your technique.
Ken
Date: 19 Dec 2009 15:50:00
Message: <web.4b2d3b2d5f6b9df665f302820@news.povray.org>
> > [Tor Olav wrote:]
I just did an A/B test of your 3rd version with Tor's reworked version, and the
first thing I noticed in Tor's was some coincident-surface speckling of the HF
base--NOT related to the plane (I moved that out of the way.) Perhaps there are
some duplicate slices at the base? (Just a guess.)
Also, with your version, water_level can be used in the HF to erase the base (or
any part of the HF.)  In Tor's version, water_level doesn't behave normally, and
instead produces some odd results (a square block shows up below the
water_level.)  Just thought I'd mention these differences.
Keep those developments coming!!
Ken
Date: 19 Dec 2009 15:57:04
Message: <4b2d3e20$1@news.povray.org>
> curious.
> Ken
If all 3 colour chanels are the same, it's faster and gives the same result.
Using ".x", you only access one value.
Using ".gray" you need to access all 3 chanels, then you perform a
ponderated average.
Date: 19 Dec 2009 16:20:01
Message: <web.4b2d4324ce3532365f302820@news.povray.org>
> > curious.
> ponderated average.
Thanks, Alain. I never thought about that, when using a grayscale image to begin
with.
Ken
Date: 19 Dec 2009 16:35:00
Message: <web.4b2d44acce3532365f302820@news.povray.org>
Going back over sbenge's code, I see that his version uses a pigment for the
function (i.e., rgb colors)--which might benefit from .gray (if we happen to use
something other than grayscale 'bumps' as the pigment pattern); whereas Tor's
code *does* use .gray for all pigments. BUT, I assume that bumps as a PIGMENT
(rather than as a PATTERN) has three color channels internally? All three the
same, of course. In which case, .red would make sense.
Ken
Date: 20 Dec 2009 00:07:11
Message: <4b2db0ff@news.povray.org>
>> Hello,
Thanks.
It was a good idea, executed poorly. Tor's version is faster and more
accurate. If I end up making a scene with this, I'll be using his version :)
Date: 20 Dec 2009 11:44:27
Message: <4b2e546b@news.povray.org>
> Ken
If you use the bozo, wood or agate pigment, you need to use .gray. Those
use a default colour map that have colours other than gray.
For all other pigments, .red, .green or .blue are OK as they use a gray
scale by default.
Date: 16 Jan 2010 20:59:19
Message: <4b526ef7@news.povray.org>
Something here reminds me for the flying mountains of Pandora ("Avatar"
movie)...
Good idea, your way to create over-hangs.
Sven
