POV-Ray : Newsgroups : povray.binaries.images : 'Accidental' isosurface Server Time
16 Aug 2025 09:00:49 EDT (-0400)
  'Accidental' isosurface (Message 1 to 10 of 68)
Subject: 'Accidental' isosurface
Date: 16 Nov 2009 20:30:15
Message: <4b01fca7@news.povray.org>
After seeing the mandelbulb getting some press recently on slashdot, I
started to wonder how close I could get with povray.
I forgot to segment the parts of the isosurface into the x,y,z
components (added them instead), and this happened, at least it's fun
looking.
#local n = 8;
#local r = function{sqrt(pow(x,2)+pow(y,2)+pow(z,2))};
#local theta = function{atan2(sqrt(pow(x,2)+pow(y,2)),z)};
#local phi = function{atan2(y,x)};
isosurface{
   function {
pow(r(x,y,z),n)*(sin(theta(x,y,z)*n)*cos(phi(x,y,z)*n)+sin(theta(x,y,z)*n)*sin(phi(x,y,z)*n)+cos(theta(x,y,z)*n))
   threshold 0
   max_gradient 57
   contained_by {sphere{0,1}}
   texture{
     pigment{color rgb 0.8}
     finish{ambient 0 diffuse 1}
Download 'mandelball.jpg' (22 KB)
Preview of image 'mandelball.jpg'
Subject: Re: 'Accidental' isosurface
Date: 17 Nov 2009 17:05:40
Message: <4b031e34$1@news.povray.org>
That's cool.
I've been wondering the same thing, but I haven't made any effort to
find out if it's possible to do the Mandelbulb in POV.  I figure someone
who knows a lot more than me will figure it out first.
> looking.
> #local n = 8;
> isosurface{
> function {
> threshold 0
> max_gradient 57
> texture{
Date: 19 Nov 2009 07:51:56
Message: <4b053f6c$1@news.povray.org>
> I've been wondering the same thing, but I haven't made any effort to find
> out if it's possible to do the Mandelbulb in POV.  I figure someone who
I think it would be easiest (ie not take 400 years) if you made a program in
a faster language (eg C++) to write a df3 file, and then used POV to render
the df3 file as an isosurface.
Date: 19 Nov 2009 09:06:56
Message: <4b055100$1@news.povray.org>
>> someone who knows a lot more than me will figure it out first.
> program in a faster language (eg C++) to write a df3 file, and then used
> POV to render the df3 file as an isosurface.
Like this?
http://news.povray.org/povray.binaries.animations/thread/%3Cweb.4b02da71bde7fd6d299b4a940%40news.povray.org%3E/
That 256x256x256 df3 took a few minutes to generate on my machine, so
the proof of concept works.
I haven't optimized the code too far yet, it's still using the trig
functions, but it can be used for any value N. It's ready to render a
XxYxZ resolution mesh at any zoom, defined by passing min and max values
for each dimension. Unfortunately it's not multi-threaded yet either,
but as soon as I learn a bit more about how to write that, the structure
of the code will require very little modification to allow that.
Chris
Date: 19 Nov 2009 10:12:12
Message: <4b05604c@news.povray.org>
> Like this?
> That 256x256x256 df3 took a few minutes to generate on my machine, so the
Hehe I just did the same :-)  Mine was 1024x1024x1024 df3 file which took
about half an hour multithreaded under c#.net (I decided the speedup I could
get by easy multithreading in c# outweighed the speedup I could get with C++
over C#).  The render only took about 2 minutes, it's just an isosurface and
a few lights.
Yeh mine too, it looks like there should be a way to lose the trig even with
N=8, but it might get a bit scary...
> Unfortunately it's not multi-threaded yet either, but as soon as I learn a
> bit more about how to write that, the structure of the code will require
Yeh, I chose to do it under C# because it's very easy to do the
multithreading on there and I have no experience of doing multithreading on
normal C++.  I just wanted to get something working this afternoon to see
what it looked like.
The issue is that the isosurface is still made up of millions of little cube
shaped voxels, I think the only way to improve that is to write a
fractal-ray tracer too!  Or maybe patch POV...
Download 'mandelbulb.jpg' (112 KB)
Preview of image 'mandelbulb.jpg'
Date: 19 Nov 2009 10:58:33
Message: <4b056b29$1@news.povray.org>
scott wrote:
>> Like this?
> took about half an hour multithreaded under c#.net (I decided the
> speedup I could get by easy multithreading in c# outweighed the speedup
> I could get with C++ over C#).  The render only took about 2 minutes,
> it's just an isosurface and a few lights.
> with N=8, but it might get a bit scary...
>> learn a bit more about how to write that, the structure of the code
> on normal C++.  I just wanted to get something working this afternoon to
> see what it looked like.
> cube shaped voxels, I think the only way to improve that is to write a
Amazing!  I wish I was half as smart as all these programmers around
here.  I'd love to see a large and detailed render.
Date: 19 Nov 2009 14:08:06
Message: <4b059796$1@news.povray.org>
scott wrote:
>> Like this?
g
o
	Well, if your compiler supports OpenMP, the multithreading is as
simple as including omp.h and writing "#pragma omp parallel for
shared(a)" just before your outer loop (where "a" is the name of the
array in which you store your results)...
See: https://computing.llnl.gov/tutorials/openMP/
		Jerome
mailto:jeb### [at] freefr
http://jeberger.free.fr
Jabber: jeb### [at] jabberfr
Download 'us-ascii' (1 KB)
Date: 19 Nov 2009 20:29:15
Message: <4b05f0eb$1@news.povray.org>
... or use the "interpolate" keyword?
If you use tricubic interpolation, you may want to change your generator
program though, to output not values 0 and 255, but something like 64
and 192, as some versions of POV-Ray have bugs in the interpolation code
that may otherwise cause artifacts due to "overshoot".
Date: 20 Nov 2009 02:47:53
Message: <4b0649a9@news.povray.org>
It's already using interpolate 1 (interpolate 2 was very slow and I couldn't
see much difference from this zoom), but as all voxels are either 0 or 255
you still get a very rough look.
> program though, to output not values 0 and 255, but something like 64 and
> 192,
Yeh good idea, I could do something clever in the df3 generator to output a
varying value depending on how "close" the voxel is to the border.
Date: 20 Nov 2009 07:38:42
Message: <4b068dd2@news.povray.org>
> Amazing!  I wish I was half as smart as all these programmers around here.
Better?  There are still artifacts due to the discrete nature of the df3
file, but I'm working on it.
Generating a df3 file from code outside of POV is not very hard.  And I just
copied the formulas to generate the fractal from the websites referenced.
Download 'mandelbulb4.jpg' (490 KB)
Preview of image 'mandelbulb4.jpg'
