POV-Ray : Newsgroups : povray.binaries.images : Playing with Monsters Server Time
25 Mar 2026 21:19:27 EDT (-0400)
  Playing with Monsters (Message 7 to 16 of 16)
<<< Previous 6 Messages Goto Initial 10 Messages
Subject: Re: Playing with Monsters
Date: 2 Jul 2006 16:55:01
Message: <web.44a8318f5c8cac3a9db1fe880@news.povray.org>
Artemia Salina <y2k### [at] sheayrightcom> wrote:
> I tried Norbert's suggestion last night (see his article in this thread)
> and it didn't work. I played with swapping the sign for the x and z axes
> but still no luck.
It should work, believe me!
Here a bit more code, which shows what I mean -
#declare Norm = <0,0,0>;
#declare loc = trace (M1, start, <0,0,0>, Norm);
#if (vlength(Norm) != 0)
        object {
                eye
                rotate <degrees (atan2 (Norm.z,Norm.y)),0,-degrees (atan2
(Norm.x,Norm.y))>
                translate loc
If the difficulties persist, please post the relevant code part.
Norbert Kern
Date: 2 Jul 2006 17:19:22
Message: <pan.2006.07.02.21.19.21.472772@sheayright.com>
>> but still no luck.
Oh, I think I see what's going on. Instead of <0,0,0> for the direction
vector I'm using <0,0,-1>! I don't know how or why I did that. I'll retry
with your suggestion, Norbert.
Thanks again for the assistance!
Date: 2 Jul 2006 17:35:00
Message: <web.44a83b515c8cac3a9db1fe880@news.povray.org>
My fault, <0,0,0> doesn't work!
I don't know, how you come to your start coordinates for trace (start), but
if the base sphere is centered at <0,0,0>, the direction has to be -start.
Norbert Kern
Date: 2 Jul 2006 18:03:58
Message: <pan.2006.07.02.22.03.54.579706@sheayright.com>
> Norbert Kern
Here's a the code that I'm using (with most texturing removed for clarity). The
RRand() just provides some irregularity to the final positioning of the eyes
and makes the eyeballs look in different directions (rotating them in their
sockets).
So Start would be
<-90, -90 (plus some randomness), 0>
And it would end the scanning at
<90 (plus some randomness), 90 (plus some randomness), 0>
#declare BSB = sphere{0, 11 scale <1, 0.85, 1>};
#declare CntX = -90;
#declare CntY = -90;
#declare ZZ = <0,0,-1>;
#declare N1 = seed(12345);
#while(CntY < 90)
        #while(CntX < 90)
                #declare POSB = trace(BSB, <CntX, CntY + RRand(-0.95, 0.95, N1), 0>,
ZZ, Norm);
                #if (!VZero(Norm))
                merge{
                        object {Eye(Green*0.5, .70)
                                // Make eyes look in different directions
                                rotate <POSB.y*RRand(4, 20, N1), -POSB.x*RRand(4, 20,
N1), 0>
                                pigment{rgbt 1}
                        sphere{<0,0,0.55>, 0.75
                                texture{pigment{rgb <1, .9, .9>}}
                                // Flatten the spheres a bit
                                scale <1.3, 1.3, 0.95>
                                // This rotation was what I was using and it was
close:
                                // rotate <POSB.y*8, -POSB.x*8, 0>
(atan2(Norm.x,Norm.y))>
                        translate POSB
                #declare CntX = CntX + 3 + RRand(-0.55, 0.55, N1);
        #declare CntY = CntY + 2;
Today's Alliterative Monomania Headlines:
Laputan Laryngeal Law-fall Liquidly Litters Lachrymary Law-fall
Degloried Deflective Decession Disfavorably Disincorporates Dihedral Decahedron
Redivivus Rapid-fire Refait Retroactively Roentgenizes Retrousse Redif
Date: 3 Jul 2006 06:10:01
Message: <web.44a8ec985c8cac3ac398b7380@news.povray.org>
I came up with this solution. Hope it helps.
Don't know, why my rotation tip failed - but Warp's hint works always albeit
being less flexible.
//______________________
#version 3.6;
#declare RAD = 2;
global_settings {
        assumed_gamma 2.2
        max_trace_level 16
        noise_generator 2
        radiosity {
                pretrace_start 0.08
                pretrace_end   0.04/RAD
                count 30*RAD
                nearest_count RAD
                error_bound 2/RAD
                low_error_factor 0.5
                recursion_limit 1
                gray_threshold 0
                minimum_reuse 0.015
                brightness 2.3
                adc_bailout 0.005
                normal on
                media off
        location <0,6,-30>
        up y
        look_at 0
        angle 67
light_source {
        <80000,150000,-5000>,
        <2.42,2.23,1.87>
sky_sphere {
                gradient y
                color_map {
                        [0 color <212,221,239>/255]
                        [1 color < 79,103,170>/255]
plane {
        y,-50 hollow
                pigment {color rgb <0.2,0.3,0.1>}
//______________________________________________________________________________
#include "functions.inc"
#include "transforms.inc"
#declare eye = cylinder {0,y*2,0.4 pigment {color rgb 0.4} finish {ambient
0}}
#declare BSB = sphere {0, 11 scale <1, 0.85, 1>};
#macro RRand (a,b,c)
        rand (c)*(b-a)+a
#while(CntY < 90)
        #while(CntX < 90)
N1), 0>, ZZ, Norm);
                #if (vlength (Norm)!= 0)
                merge {
                        object {eye}
                        sphere{<0,0,0.55-0.55>, 0.75
                        rotate <RRand(-20, 20, N1), RRand(-20, 20, N1), 0>
                        Reorient_Trans (y,Norm)
                        translate POSB
object {BSB pigment {color rgb <1,0,0>} finish {ambient 0}}
Download 'rotation_issue.jpg' (65 KB)
Preview of image 'rotation_issue.jpg'
Date: 4 Jul 2006 13:11:08
Message: <44aaa12c@news.povray.org>
Norbert Kern wrote:
> Hi,
This method worked just fine, Norbert!
Thanks again for your help!
Download 'eyesphere.jpg' (158 KB)
Preview of image 'eyesphere.jpg'
Date: 4 Jul 2006 20:31:38
Message: <44ab086a$1@news.povray.org>
(oops, I hit the wrong button.)
Artemia Salina wrote:
> . . .  Please note the scaled spheres under the eye balls and how they
> are not rotated correctly to lay on the surface of the large sphere.
> I haven't been able to figure out how to do this properly yet. . . .
Can't see the discrepancy myself, but anyway .. I'd put the eye with its
mount at <R,0,0>
	#declare Eye = union {
		//the eyeball itself and
		sphere { 0,1 scale <1,2,2> translate R*x }
and then rotate it into place.
For uniformly random placement this is the way to go:
	object { Eye
		rotate <0,
		 degrees(asin(1-2*rand(Seed))),
		 360*rand(Seed)>
For a uniform quasi-grid placement:
	#declare H = 1/N;
	#declare Z = H-1;
	#declare Theta = 0;
	#declare Magic = 180*(3-sqrt(5));
	#while Z < 1
		object { Eye rotate <0, degrees(asin(Z)), Theta> }
		#declare Z = Z+2*H;
		#declare Theta = mod(Theta+Magic,360);
	#end//while
Anton Sherwood, http://www.ogre.nu/
"How'd ya like to climb this high *without* no mountain?" --Porky Pine
Date: 5 Jul 2006 05:33:16
Message: <44ab875c$1@news.povray.org>
Hallo, Artemia!
The texture of the monster is very interesting: how did you realized it?
Could be interesting with some normal, in order to obtain a vascular system
relief effect.
Paolo
> "Artemia Salina" wrote:
> Norbert Kern wrote:
> > Hi,
albeit
Date: 10 Jul 2006 12:40:35
Message: <44b28303@news.povray.org>
Paolo Gibellini wrote:
> Hallo, Artemia!
It's just a color map using a turbulated mandel pattern. I have it set
up as a macro using a color ("Red" from colors.inc) passed as a
parameter, and rbgt 1 to make it layerable. Depending on how it is
adjusted you can get some interesting textures. The image below shows a
convincing raw meat texture (I've forgotten the parameters to get that
texture) but it was several layers using Red and White.
#macro BloodShot(N, T, C, S)
texture{
                 mandel (5000  * RRand(1, 5, N)) / S
                 turbulence RRand(0.2, 10.9, N)
                 rotate <0, 0, RRand(0, 360, N)>
                 translate T
                 color_map {
                         [0.010  rgbt 1]
                         [0.010 C ]
                         [0.210 C ]
                         [0.210 rgbt 1]
                         [0.900 rgbt 1]
                         [0.900  C ]
                         [0.900  C ]
                         [0.990 rgbt 1]
> relief effect.
I'm thinking of adding actual veins to the monster's head and body. This
thing is far from being done :-)
Download 'meatloaf.jpg' (156 KB)
Preview of image 'meatloaf.jpg'
Date: 11 Jul 2006 04:28:44
Message: <44b3613c@news.povray.org>
Thank you, I'v never dared to use mandel in a texture, but the effect is
very interesting!
Paolo
> texture{
>          pigment {
>                  translate T
>                  color_map {
>                          [0.010  rgbt 1]
>                          [0.010 C ]
>                          [0.210 C ]
>                          [0.210 rgbt 1]
>                          [0.900 rgbt 1]
>                          [0.900  C ]
>                          [0.900  C ]
>                          [0.990 rgbt 1]
> #end
system
> > relief effect.
