POV-Ray : Newsgroups : povray.binaries.images : volcano WIP5 Server Time
2 Aug 2026 11:48:33 EDT (-0400)
  volcano WIP5 (Message 13 to 22 of 32)
Subject: Re: volcano WIP5
Date: 15 Feb 2006 14:38:30
Message: <43f38336$1@news.povray.org>
Mmmm, I like it...
Date: 16 Feb 2006 01:05:01
Message: <43f4160d@news.povray.org>
Yeah that's the elliptical error I mentioned. I can see it, it's a mistake,
it will be fixed. Though I'm annoyed pov can't handle having 2
media-containers overlapping without artefacts.
Tek
http://evilsuperbrain.com
"St." <dot### [at] dotcom> wrote in message news:43f37a88@news.povray.org...
> "Warp" <war### [at] tagpovrayorg> wrote in message
> news:43f2e627$1@news.povray.org...
>> Tek wrote:
>>> And that's about it. What do you think?
>>   It's looking quite good.
>>   However, there's still some non-photorealistic quality to it,
>> even though I can't put my finger on it.
>  The bounding box for the immediate fire/flames from the top of the
> volcano shows too much?
>   Not sure if anyone else can see this?
>   ~Steve~
Date: 16 Feb 2006 01:11:18
Message: <43f41786$1@news.povray.org>
Well, the max trace level I'd need to show that bit correctly would be at
most 6, and my max trace is currently 80!
The problem seems to simply be I have 2 different media-containers that
happen to overlap, it seems pov carves a hole out of one of them where it
finds the other. I was getting some horiffic errors from the flying lava
until I differenced it with the smoke's media container. The errors looked
like shadows through the media but bright white. Anyway my experience is
media "just does that sometimes" and you need to help it understand where
the division is between your surfaces by using differences and such, I was
just hoping someone understood the technical aspect of this better than me.
i.e. I can work round it, but I'd like to know why I have to :)
Tek
news:dsv5jr$n3f$1@chho.imagico.de...
> Tek wrote:
>> Still to do:
>> -The aforementioned resurrection of the lava rivers
> I think you will have to modify the terrain geometry for that.
>> -fix that eliptical bug round the top of the volcano (anyone know why
>> overlapping media-containers don't play nice together?)
> Do you have sufficient max_trace_level?
>> -steam wherever lava touches water/snow
>> -...and something else... the left side of the image looks too calm, any
>> suggestions?
> Maybe some landslide - would be reasonable to occur during a vulcanic
> eruption...
> Concerning realism - it is extremely difficult to achieve an impression of
> realism for the viewer with such an image where hardly anyone has a real
> life experience to compare to.  None the less i think the smoke is too
> fluffy.
> Christoph
> POV-Ray tutorials, include files, Landscape of the week:
> http://www.imagico.de/ (Last updated 31 Oct. 2005)
> MegaPOV with mechanics simulation: http://megapov.inetart.net/
Date: 16 Feb 2006 03:41:25
Message: <43f43ab5@news.povray.org>
This is a great improvement, Tek!
Still, some unconfortable feelings. Although the shape of the volcano is
much better, I think the slope is too steep. Volcano slopes are mainly made
up of rubble and the "maximum angle of repose" of loose material is about 37
degrees. This concerns all kind of slopes like screes, or dunes too. Your
slope (to the left) is about 50 degrees.
Your underwater view is impressive indeed. Still, I feel that the flow is
too thin to be really believable and natural looking. I would expect a more
massive "wall" of lava with those fiery blobs sticking out.
Sorry for these comments! They come from my professional background mainly.
You have created a great image already!
Date: 16 Feb 2006 11:46:56
Message: <43f4ac80@news.povray.org>
Aren't the Pyramids of Egypt built at a 37 degree angle as well?
...Chambers
(Sorry, a bit OT)
Date: 16 Feb 2006 18:10:01
Message: <web.43f5052d84388aa062aad93e0@news.povray.org>
This is looking much better, the sky looks better now you have made the blue
darker nearer the top and this (plus other changes I am sure) makes the
water looks much better too. The darker colour of the smoke is also an
improvement.
Sean
Date: 16 Feb 2006 22:53:54
Message: <43f548d2$1@news.povray.org>
> finds the other.
The problem, I believe, is that your sampling parameters aren't high enough.
POV-Ray isn't taking enough samples of the media, so you're getting
incorrect results. When there's only one container, the result looks good
enough that you don't have to worry about it - but when a ray passes through
two containers, the places the samples are taken change, so you get a
*different* incorrect result.
As you improve your sampling parameters ("samples n" where n is high (start
at 10 or so and work your way up)), the effect should diminish, but the
render will also get slower.
If you can put both medias into one container, you can eliminate the problem
that way - but you'll be sampling both medias everywhere, which will hurt
performance.
 - Slime
 [ http://www.slimeland.com/ ]
Date: 17 Feb 2006 02:26:00
Message: <43f57a88$1@news.povray.org>
That's certainly a problem I've seen before, though I suspect that's not it
because I've already cranked the samples up pretty high. Having said that,
the difference in size between the 2 containers is vast, so maybe even with
a lot of samples they're still quite coarse in the overlapping area...
But you're right, if I up the number of samples I can tell if that's the
problem... a few hours later when it finishes rendering... :)
Tek
"Slime" <fak### [at] emailaddress> wrote in message
news:43f548d2$1@news.povray.org...
>> finds the other.
> enough.
> through
> (start
> problem
> performance.
> - Slime
Date: 17 Feb 2006 02:37:42
Message: <43f57d46$1@news.povray.org>
> more
That might be what you'd expect, but it's not what really happens. I've said
it before and I'll say it again, reference!:
http://www.pmel.noaa.gov/vents/nemo/explorer/concepts/pillows.html (watch
the video at the bottom of the page).
And regarding the slope, you're entirely right, but I can't get the
composition to work with steeper edges. After all I'm not really going for
realism... Oh hold on I just contradicted myself :)
Tek
"Thomas de Groot" <t.d### [at] internlnet> wrote in message
news:43f43ab5@news.povray.org...
> made
> 37
> more
> mainly.
> Thomas
Date: 17 Feb 2006 03:32:14
Message: <43f58a0e@news.povray.org>
"Tek" <tek### [at] evilsuperbraincom> schreef in bericht
news:43f57d46$1@news.povray.org...
That's allright! ;-)
It is part of the artistic liberty! Just go on, your image is overwhelming
<cough (smoke & ash)> already!
