POV-Ray : Newsgroups : povray.binaries.images : Simple Patina Macro (7kb jpg) Server Time
10 Sep 2025 20:04:58 EDT (-0400)
  Simple Patina Macro (7kb jpg) (Message 1 to 10 of 10)
Subject: Simple Patina Macro (7kb jpg)
Date: 28 Nov 2003 08:28:36
Message: <3fc74d84@news.povray.org>
In the thread "Subsurface Scattering: macro now available (21kb jpeg)"
Gilles Tran wrote this:
> Also: could a trick like this be used to create patina effects?
I don't know that much about how patina should look, but I've got the
impression that it's not dependent on light source location, like
subsurface scattering is? If it's more a matter of curvature of the
surface and nearby surfaces, then this macro might be sufficient:
#macro patina_pattern(Obj,Blur,Samples,Stream)
   // by Rune S. Johansen 2003
   #local FN =
   function {
         average
         pigment_map {
            #local C = 0;
            #while (C<Samples)
               [1
                  object{Obj rgb 0, rgb 1}
                  translate <
                     rand(Stream)-rand(Stream),
                  >*Blur
               #local C = C+1;
   function {FN(x,y,z).red}
Here's a simple sample scene which produces the attached image:
#declare Object =
union {
   plane {y,0}
   box {-1,1 scale <3.2,1.0,0.7> translate y}
   box {-1,1 scale <1.0,1.0,3.0> translate y}
   box {-1,1 scale <1.0,2.0,1.0> translate 2*y}
   box {-1,1 scale <0.5,0.7,3.5> translate 0.7*y}
   sphere {4*y, 1}
   torus {2.4, 0.5 translate y}
   scale 2
object {
   Object
      patina_pattern(Object, 2, 256, seed(0) )
      color_map {
         [0.1, rgb 1][0.9, rgb 0]
light_source {< 2, 3,-1>*100, color rgb <1.2,1.2,0.9> shadowless}
light_source {<-2, 3,-2>*100, color rgb <0.5,0.5,0.8> shadowless}
camera {location <9,12,-13> look_at 3*y}
Let me know if this is any useful...
Rune
rune|vision:  http://runevision.com **updated Sep 28**
POV-Ray Ring: http://webring.povray.co.uk
Download 'patina.jpg' (7 KB)
Preview of image 'patina.jpg'
Subject: Re: Simple Patina Macro (7kb jpg)
Date: 28 Nov 2003 10:30:01
Message: <web.3fc76919d96c42012e746c9a0@news.povray.org>
Hi Rune,
I used a similar technique, based on a macro by ABX, in my 'Death of a
Cliche' image:
code : http://news.povray.org/povray.binaries.scene-files/23889/
image: http://news.povray.org/povray.binaries.images/23788/
Mike.
>   #local FN =
>   function {
>      pigment {
>         average
>         pigment_map {
>            #local C = 0;
>            #while (C<Samples)
>               [1
>                  translate <
>                  >*Blur
>               #local C = C+1;
>            #end
>#end
[snip]
>Rune
>3D images and anims, include files, tutorials and more:
Date: 28 Nov 2003 12:30:25
Message: <3FC7862B.8050603@hotmail.com>
Hey Rune. I'm sure this concept will be useful, but somebody needs to
produce a model worthy of diplaying its properties. That buddha statue
ought to work. This technique could be used to simulate oxidation or
paint that has been partially worn off by excessive handling.
By the way, isn't this kind of like the proximity pattern? (I never used
it, so I don't know).
Samuel Benge
stb### [at] hotmailcom
See my website@: http://www.goldrush.com/~abenge/Top/index.html
Date: 28 Nov 2003 12:39:36
Message: <7p1fsvsbj4ogagbdd02sisa8l7rja7onub@4ax.com>
On Fri, 28 Nov 2003 09:30:19 -0800, Samuel Benge <sbe### [at] hotmailcom>
I could say it's KIND of proximity pattern but more to refresh associations to
old long discussion in one of groups than to really express something. ;-)
ABX
Date: 28 Nov 2003 22:31:41
Message: <cjameshuff-13E0AD.22314528112003@netplex.aussie.org>
In article <3FC### [at] hotmailcom>,
I agree...this looks like it may be a very useful effect. Maybe I should
revive my blurred pattern patch...I'll have more time to do that after
this semester is over.
(Didn't someone else also do a blurred pattern patch?)
Not really, though it can resemble it in shape. The proximity pattern
was based on distance to the surface. This is based on the proportion of
nearby space taken up by the volume of the object. It is basically a
blurred object pattern.
http://tag.povray.org/
Date: 28 Nov 2003 22:34:18
Message: <cjameshuff-779B4C.22342228112003@netplex.aussie.org>
In article <3fc74d84@news.povray.org>, "Rune" <run### [at] runevisioncom>
It is a matter of curvature, or more precisely, accessibility. Oxidation
and weathering that gets rubbed off of exposed surfaces while
accumulating on more protected surfaces.
Date: 29 Nov 2003 05:32:05
Message: <s88m91-cp2.ln1@triton.imagico.de>
http://www.tu-bs.de/%7Ey0013390/povcyg/docu/docu_pattern01.html#BLUR
I used a relative grid which does not lead to a completely smooth
pattern while you used an absolute grid.  Both metods hve their use i think.
Last updated 25 Oct. 2003 _____./\/^>_*_<^\/\.______
Date: 29 Nov 2003 05:44:43
Message: <3fc8789b$1@news.povray.org>
me neither but I've done some attempts 2 years ago (woh, time passed fast..)
with the projection pattern , creating a kind of accessibility pattern :
http://news.povray.org/povray.binaries.images/18641/
(The source for this example is in the mlpov documentation)
M
Date: 29 Nov 2003 09:13:41
Message: <cjameshuff-26C5BF.09134629112003@netplex.aussie.org>
In article <s88### [at] tritonimagicode>,
I did a patch using a relative grid first. The "smooth" blur version was
specifically intended for isosurfaces, which benefited from the
continuity of that version. I never got anything polished enough for
release though...seem to have some trouble doing that. ;-)
Date: 29 Nov 2003 14:29:55
Message: <cjameshuff-1FAF24.14300129112003@netplex.aussie.org>
In article <cja### [at] netplexaussieorg>,
BTW, the "sub-surface scattering" pattern using the projection pattern
is quite similar to a "visibility" pattern I was working on, which was a
very close relative of the proximity pattern and was intended to be used
for patinas. It could be a bit closer to a proximity pattern if the
projection pattern depended on distance...
