POV-Ray : Newsgroups : povray.binaries.images : Bolts Server Time
9 Jun 2024 02:11:52 EDT (-0400)
  Bolts (Message 32 to 41 of 41)
Subject: Re: Bolts (POV image attatched) 30KB
Date: 1 Feb 2002 03:57:02
Message: <3C5A581E.1050400@videotron.ca>
Jaime Vives Piqueres wrote:
> Andrew, sorry if this was not another "brazil challenge", but I've not
> resisted to try my old bolt model with such scene.  I wanted to try it with
> my new way of making light_sources (very strong and very short ones).
> I my self was impressed by the result: IMHO, we all don't really know (yet)
> what POV is capable of...
THEM ROLLEXES KEEP GETTING AWSOMER AND AWSOMER!!!
/*   videotron.ca  */}camera{location<6,1.25,-6>look_at a orthographic}
Date: 1 Feb 2002 04:30:49
Message: <3c5a6049$1@news.povray.org>
DAMN that nice!!
Subject: Re: Bolts (me too!)
Date: 1 Feb 2002 06:07:32
Message: <3C5A772E.9E99DFCC@engineer.com>
Thomas Lake wrote:
> Neat did you play with the individual colour channels to get this effect?
Adjust color balance, shadows -> blue+cyan, highlights -> red+yellow.
And some layer combinations, and various other tweaks. I think the
usual way to do this is to convert to tritone.
_____________
Kari Kivisalo
Date: 1 Feb 2002 07:09:41
Message: <3c5a8585$1@news.povray.org>
with
(yet)
Stunning
perhaps we should have a site comparing pov & braz :)
PGP Public Key
Date: 1 Feb 2002 08:46:52
Message: <3c5a9c4c@news.povray.org>
Damn.. that's SO much better than mine :-(
Well done.
How did you make the bolts, especially the indentations?
Andy
"Jaime Vives Piqueres" <jai### [at] ignoranciaorg> wrote in message
news:3c5a570f@news.povray.org...
with
(yet)
> La Persistencia de la Ignorancia
> http://www.ignorancia.org
Subject: Re: Bolts
Date: 1 Feb 2002 16:01:44
Message: <3C5B01B5.3050608@skynet.be>
Hugo wrote:
> I refuse to think any other renderer can do better than Pov
There is room for some simple quality and speed improvement in POV-Ray.
Example 1 : Brazil does "bokeh", which is the simulation of the way
highlights appear (bigger) in blurry areas, like with a real photograph.
There is a POV-Ray patch (MLPov) that implements a first draft of it,
promising.
Example 2 : Brazil (and most commercial radiosity systems) does NOT
take reflected (and refracted) rays into account when it takes radiosity
samples !!!  Big speedup there, for almost no difference in result (not
a realistic difference, anyway).  If anyone doubts that, I have a
set of images that proves it.
(and the two-step rendering experiences of Jaime and others are
  also in favour of that).
Fabien.
Date: 1 Feb 2002 16:59:56
Message: <3c5b0fdc@news.povray.org>
Hi Andrew,
In my opinion, your bolts are slightly better looking than Jaime's, so don't
be TOO sorry please!  It's true that Jaime's version has some things better
than yours: The contrast is better and the metal plate is better textured.
But your bolts look more dusty = a great thing.. They also have scratches
where they have been touched by ...a tool ... you know (I miss the english
word for it)
Jaime's modelling is presumably done with CSG.. That's technically more
efficient than your heightfield, but in this particular case, it looks too
perfect, so your bolts wins here, too... Anyway, both of you have done a
terrific work!  To merge the results would be perfect.
Hugo
Date: 1 Feb 2002 17:12:48
Message: <3c5b12e0@news.povray.org>
my only complaint is that the blur seems to cut to sharply between not
blurred and blurred. that is, on the bottom bolt atleast.
perhaps though it is just due to where that bolt is placed. like if it had
more of the bolts head in the not-quite-so-blurred part then the blur might
look more gradual.
other than that, it looks stunning
Jaime Vives Piqueres <jai### [at] ignoranciaorg> wrote in message
with
(yet)
Subject: Re: Bolts
Date: 1 Feb 2002 20:54:56
Message: <3C5B46EE.CDCEBA8C@earthlink.net>
they look like cookies coming out of a conveyer belt...
Or halls, peppermint patty's, some kind of food...
Andrew Cocker wrote:
> Hi,
> It's been a long while since I posted anything, but as I very recently
> FINALLY got a new pc (1Ghz Athlon, 256 Meg DDR etc), I'm POV-ing again.
> This piece was inspired by a BRAZIL render - maybe some of you have seen it.
> If so, you'll be able to see that mine comes nowhere near the
> photorealistism of that work. Mine is definitely a WIP. I don't like the
> textures, nor can I even approach the contrast from dark to light of the
> BRAZIL render (even though that artist mentions using post-processing, I
> still feel that my render could be improved. Maybe using radiosity was a bad
> idea.)
> Anyway, any comments would be welcome.
> All the best,
> Andy Cocker
Date: 2 Feb 2002 05:46:47
Message: <3c5bc397@news.povray.org>
> Well done.
  Thanks Andy (and all), but as Hugo said, your is also very well done, and
has some things better. I also like specially your focal blur, mine is
somewhat strange and does not seem to follow the camera zoom.
union{
 intersection{
  union{
   cylinder{<0,-.3,0>,<0,.3,0>,.6}
   torus{.6,.3}
  plane{z,.72}
  plane{z,-.72 inverse}
  plane{x,0 rotate 30*y inverse translate -.82*x}
  plane{x,0 rotate -30*y inverse translate -.82*x}
  plane{x,0 rotate 30*y translate .82*x}
  plane{x,0 rotate -30*y translate .82*x}
 height_field{
  png "hf_bolt"
  smooth
  water_level 0.1
  translate -.5
  scale <1.3,.1,1.3>
  translate <0,.27,0>
  The height_field is the nice lettering on the top (which of course says
"POV-RAY"), and is done with The Gimp, puting white letters in circle on
black background and blurring it a bit.
  There are also some facts about the image I forgot to mention:
  + To get the feeling from Brazil, I used a double CD from Joao Gilberto.
  + The image uses Kari rad settings from the cornell box scene, with the
count lowered a bit.
  + The focal blur uses Warp recommendation of variance 0.
  + The metal texture uses an averaged normal (only the normal) from 4
patterns at diferent scales, and a "procedural" image_map "a la Tran".
  + The light is created with my new macro, wich uses basically
fade_distance 1 fade_power 2 and the light color is multiplied by a very
high value (about 3600 for this one).
  + Render time was 7h... !
  I promise to release the light macro this weekend, mainly because I want
some feedback about all my (surely wrong) assumptions creating it.
  Bye...
