POV-Ray : Newsgroups : povray.binaries.images : BlobScape w/radiosity (26k jpeg) Server Time
31 Dec 2025 04:42:52 EST (-0500)
  BlobScape w/radiosity (26k jpeg) (Message 1 to 9 of 9)
Subject: BlobScape w/radiosity (26k jpeg)
Date: 10 Oct 2003 12:11:31
Message: <3F86DA20.7090903@hotmail.com>
It was taking too long... I had to abort the render.
I think blobs might be a good replacement for isosurfaces when it comes
to making landscapes that render more quickly. While you can't get the
same detail out of blobs(that is, without some hefty parsing and
rendering times), sculpting with them can be easier.
One thing that would make it even easier would be being able to use
torii, cones, etc. Any word on a compiled Windows version of the blob2
patch? I would take this question to povray.unofficial.patches, but I
don't want to clog it up with such questions.
Samuel Benge
stb### [at] hotmailcom
Download 'clipboard01.jpg' (26 KB)
Preview of image 'clipboard01.jpg'
Subject: Re: BlobScape w/radiosity (26k jpeg)
Date: 10 Oct 2003 12:48:38
Message: <Xns941082539AE86None@204.213.191.226>
Samuel Benge <sbe### [at] hotmailcom> wrote in news:3F86DA20.7090903
@hotmail.com:
Nice widescreen effect ;-).  Nice.
Date: 10 Oct 2003 12:54:01
Message: <3f86e429@news.povray.org>
I like this a lot.  It reminds me of Fantasy Canyon.  I attached a
picture so you can see what I mean.
-autowitch
Download 'fantasycanyon.jpg' (26 KB)
Preview of image 'fantasycanyon.jpg'
Date: 10 Oct 2003 13:22:01
Message: <hu5j51-e91.ln1@triton.schunter.etc.tu-bs.de>
Nice, if you use less 'heavy' radiosity settings it will render faster
of course. ;-)
I think the difference in modelling techniques between blobs and
isosurfaces is quite significant so you can't really use them as a fast
preview or so.
You can find some discussion about inclusion in megapov in the original
announcement thread - with negative result for the moment so sum it up.
  If you would like to write some user documentation for it that would
already be a large step forward.
But you should also note that the blob2 object renders much slower than
the regular blob.
Last updated 2 Sep. 2003 _____./\/^>_*_<^\/\.______
Date: 10 Oct 2003 15:22:06
Message: <3F8706D8.3080202@hotmail.com>
> of course. ;-)
You're right. I was meaning to fix the textures anyway, so I guess I can
take a hit on radiosity quality.
Okay, I'm starting a new thread in the patches section.
> the regular blob.
*Much* slower? I thought it was slightly slower..... At least it's still
faster than using isosurfaces, right?
> Christoph
Samuel Benge
Date: 10 Oct 2003 16:02:02
Message: <oefj51-gij.ln1@triton.schunter.etc.tu-bs.de>
Well, i have not made detailed tests myself (especially none with a lot
of components) but it is significantly slower.
It is much faster than the function based blob in IsoCSG because it does
not have to consider all components of the blobs at every point (only
those close enough to have an influence)
Date: 10 Oct 2003 16:21:43
Message: <3f8714d7$1@news.povray.org>
If I dare ...
Your discussion makes me think that a way to turn a blob into a
function, just like we turn a pattern into a function, would be very
convenient. From a theorical point of view it seems quite possible, it
would just mean taking out the threshold parameter and keep the
efficient blob evalution algorithm. It could then be used in patterns,
isosurfaces, media, etc ...
But I'm already getting mad with all the possibiilties of POV, so I
should just keep messing around with them before I start dreaming about
new ones,  :-)
JC
> of course. ;-)
>> comes to making landscapes that render more quickly. While you can't
>> get the same detail out of blobs(that is, without some hefty parsing
>> and rendering times), sculpting with them can be easier.
> preview or so.
> the regular blob.
> Christoph
Date: 12 Oct 2003 20:25:29
Message: <cjameshuff-4E18F0.20231012102003@netplex.aussie.org>
In article <3f8714d7$1@news.povray.org>, "JC (Exether)" <no### [at] spamfr>
You mean something like the blob pattern? ;-)
http://tag.povray.org/
Date: 13 Oct 2003 17:54:13
Message: <cjameshuff-6B8896.17515413102003@netplex.aussie.org>
In article <oef### [at] tritonschunteretctu-bsde>,
From my tests, common results range from 2 to 3 times slower, in some
cases almost as fast as the original blob, and much faster than the
isosurface primitive.
It actually does not yet do this type of bounding. It first tests the
ray against the bounds of each component, gathering a list of components
that affect the ray. Intersection solving is then done with this list,
which may have only a couple out of several thousand total components.
This "hit gathering" stage could itself be optimized by using
heirarchial bounding, but that isn't implemented yet.
