POV-Ray : Newsgroups : povray.binaries.images : Two Blobs (14 KB) Server Time
29 Mar 2026 20:31:01 EDT (-0400)
  Two Blobs (14 KB) (Message 11 to 20 of 22)
<<< Previous 10 Messages Goto Latest 10 Messages Next 2 Messages >>>
Subject: Re: Two Blobs (14 KB)
Date: 26 Jun 2000 17:07:26
Message: <3957C586.6FC3517B@online.no>
Peter Popov wrote:
> On Mon, 26 Jun 2000 01:58:17 +0200, Tor Olav Kristensen
> <tor### [at] onlineno> wrote:
> >Could this be useful for any scenes ?
> Yes, you'll only need some hair and a Gillete razor <grin>
So you are thinking about shaving foam. - I like that idea.
Funny I didn't see that myself:  "Once upon a time" I was
fascinated about taking macro pictures of  different shaving
foam "shapes".
Amongst the many things on my to-do list is modelling an
old Gillette razor with one of these thin double edged razor
blades. This foam could come in handy for such a scene.
Tor Olav
mailto:tor### [at] hotmailcom
Date: 27 Jun 2000 03:44:35
Message: <39585b63@news.povray.org>
"Tor Olav Kristensen" <tto### [at] onlineno> wrote in message
news:39577684.362EF60F@online.no...
| Jerome wrote:
| >         trace()?
| No ... ehh .... what is trace() ?
| Is it a function in one of the new patches ?
| I'm only using plain POV v3.1.
| A macro I made calculates where the surface of a blob is.
| (The red one in this image.) I used information from this macro
| to place the spheres in second blob (the white one).
| The removing of the "ice" in some areas is done by inserting some
| spheres with negative strength randomly around on the surface.
Figured there had to be negative strength blob at work here.  It's great,
except your macro might very well become extinct because of 'trace()',
although only in that the check for blob surface would no longer be
manually(?) done.
MegaPov ( http://www.nathan.kopp.com/patched.htm ) is what has the trace
function, useable for locating surfaces and their normals.
Date: 27 Jun 2000 15:38:01
Message: <39590205.8CE9B9B6@online.no>
> | Jerome wrote:
> | >         trace()?
> manually(?) done.
I just downloaded the html documentation for MegaPov and as far as
I can see it would be difficult to use trace() to locate "every" part of the
surface of an object if it's surface is not convex.
(Othervise one would then have to test for surfaces behind surfaces.
And one would have to move around and "radiate" vectors from several
points in space to be sure that surfaces that otherwise would be
perpendicular to the ray centre, get enough vector "hits".
Hmmm... maybe this could be an interesting macro to make !)
So I think my "manual" macro has an advantage here :-)
It can can "map" any blob surface topology.
But its parsing very slowly. Maybe I'll combine trace() with my macro later.
Thank you for commenting.
Tor Olav
Date: 27 Jun 2000 15:54:26
Message: <chrishuff-AE32BD.14542727062000@news.povray.org>
In article <39590205.8CE9B9B6@online.no>, Tor Olav Kristensen
> later.
You could probably use the blob pattern patch with eval_pattern() or
eval_pigment() to do the same thing...it would probably render faster.
BTW, I have been working on adding new component types to the blob
pattern. So far I have added "box"(pretty obvious), "pigment"(where the
grayscale value of the pigment at each point is the field value of the
component at that point.), and "blob"(which takes an ordinary blob
object as input) component types.
Date: 27 Jun 2000 16:08:49
Message: <39590943.6E32D6BD@online.no>
> > later.
I don't understand. Please explain this. And what is blob pattern patch ?
Ahhh...Yes !
Please, please include a torus component !
(I love torii and therefore I've been missing a torus component
for a long time.)
And maybe a cone component !
The "blob" type component I don't understand.
Tor Olav
Date: 27 Jun 2000 16:36:50
Message: <chrishuff-E7903A.15365127062000@news.povray.org>
In article <39590943.6E32D6BD@online.no>, Tor Olav Kristensen
The first two are new functions: eval_pattern() takes a point and a
pattern, and returns the value of the pattern at that point, while
eval_pigment() takes a point and a pigment, and returns the rgb color of
the pigment at that point.
The blob pattern...
Well, blobs are defined as the surface formed by all points where the
total "field strength" of several field emitting components is equal to
a certain threshold, I think you already understand this quite well
because it seems to be part of what your macro does. The blob pattern
returns this field strength value, it basically lets you use blob
components to control a pattern. I originally designed it to be mainly a
media density pattern, but when used in a pigment function for an
isosurface, it allows you to make blobs in the isosurface.
The blob pigment is similar, but each component has a pigment and the
pigment colors are blended together instead of the component fields.
> for a long time.)
I do plan on adding torus and cone components. :-)
It just adds the contribution of the blob into the rest of the pattern.
I added it so you don't have to translate/duplicate a blob object into
the blob pattern.
Date: 27 Jun 2000 17:06:35
Message: <395916CA.D8746C63@online.no>
> The blob pattern...
This sounds like a lot of useful functions to me.
And the blob pattern sounds really cool !
> > for a long time.)
Good.
Any chance of a torus segment component as well ?
(E.g.: Give a normal vector for the torus and a point in the "ring",
the angle it covers and the minor radius.)
Maybe im going to far now, but how about making it possible to
cut in the strength field of a component with primitive shapes ?
(I.e.: "CSG-light" for blobs)
> the blob pattern.
Smart.
So then one can make nested blobs (or even recursive ones) ?
Thank you very much for explaining.
Tor Olav
Date: 27 Jun 2000 17:25:38
Message: <chrishuff-3907BF.16253927062000@news.povray.org>
In article <395916CA.D8746C63@online.no>, Tor Olav Kristensen
> Good.
Maybe...
This should be possible with the "pigment" component type using the blob
pattern with the object pattern.
> > the blob pattern.
> Smart.
No nested blobs, it just allows you to add a blob *object* to a blob
*pattern*. Though the syntax looks like one blob nested within another...
Date: 27 Jun 2000 17:30:35
Message: <MPG.13c323a8ab43c345989719@news.stmuc.com>
> for a long time.)
I think he means he can now construct nested blobs, which have been asked
for a few times previously.
I could be wrong, and I could certainly have made that clearer if I knew
what I was talking about :)
Bye for now,
     Jamie.
Date: 27 Jun 2000 17:36:37
Message: <chrishuff-A10A19.16363827062000@news.povray.org>
In article <MPG### [at] newsstmuccom>,
No, it simply means you can now use blob objects in the blob pattern.
