POV-Ray : Newsgroups : povray.binaries.animations : Wet paper texture Server Time
13 Jul 2025 15:24:10 EDT (-0400)
  Wet paper texture (Message 2 to 11 of 11)
<<< Previous 1 Messages Goto Initial 10 Messages
Subject: Re: Wet paper texture
Date: 19 Jan 2024 06:45:33
Message: <65aa60dd$1@news.povray.org>
On 1/18/24 21:53, Bald Eagle wrote:
> I have no real idea what I'm doing with the filter and transmit values, and I
> can't achieve any transparency no matter what values I use.
In v3.8 (v3.7?) there is that second finish { difuse } specification?
diffuse 0.6, 0.3
Bill P.
Date: 19 Jan 2024 10:10:00
Message: <web.65aa906a9bc1d8da97dafaf4aa81652d@news.povray.org>
> So, I wasted half the day doing ridiculous things with cross products, dot
> products, and rotating graphs of scattering functions.
> Then I just decided to experiment with faking it from scratch.
> After wrestling with the aoi and slope patterns, I got something that more or
> less works as a basic concept.
> Anyway, here's a quick animation I threw together to adequately show how it
> works.
> It's just "one" texture and 2 light sources to provide adequate illumination of
> both sides.
> - BE
Wow, your ridiculous thing is really attractive.
Date: 20 Jan 2024 02:24:21
Message: <65ab7525$1@news.povray.org>
Op 19/01/2024 om 12:45 schreef William F Pokorny:
>> values, and I
> diffuse 0.6, 0.3
> Bill P.
I was going to suggest that too indeed. I use that for simulating
semitransparent cloth combined with backside illumination. Is also
available in v3.7.
Date: 20 Jan 2024 10:10:00
Message: <web.65abe1419bc1d8da1f9dae3025979125@news.povray.org>
> available in v3.7.
Unexplored territory for me.
So, my texture is
     slope {}
     texture_map {
          [0 pigment {
               average
               pigment_map {
                    [Entries]
          [0 pigment {
               average
               pigment_map {
                    [Entries]
I've tried plugging in a finish statement, but the parser squawks "no }, found
finish instead"
Where does the finish GO?
I was also thinking about how to go about making a user defined finish function,
and that will probably have to be done with another map, since we don't have
function controlled finish parameters
- BW
Date: 20 Jan 2024 10:40:00
Message: <web.65abe8d39bc1d8da1f9dae3025979125@news.povray.org>
OK, so I finally got the finish in the right place
     slope {}
     texture_map {
          [0 pigment {
               average
               pigment_map {
                    [Entries]
               finish {}
          [0 pigment {
               average
               pigment_map {
                    [Entries]
               finish {}
But no matter what I do with those 2 diffuse values, I don't get anything like
that translucent effect.  I'm also still puzzled why filter and transmit don't
seem to work at all - it doesn't result in a totally transparent region even if
I hard code the function pigment map entry to 1.
I do seem to get more "light" coming through, but strangely, it doesn't look
like the usual filtered or transmissive appearance that I normally expect.
It tried getting rid of those entries entirely, and that didn't seem to help
either.
- BW
Date: 20 Jan 2024 10:56:15
Message: <65abed1f$1@news.povray.org>
Op 20-1-2024 om 16:05 schreef Bald Eagle:
>> available in v3.7.
> So, my texture is
> texture {
>       slope {}
>       texture_map {
>            [0 pigment {
>                 average
>                 pigment_map {
>                      [Entries]
>            [0 pigment {
>                 average
>                 pigment_map {
>                      [Entries]
> finish instead"
> - BW
I have no access presently to the PC where I have stored my stuff (and
it is some years since last I used backside illumination). First thing
in the morning, on my ToDo. Sorry for the delay!
Date: 20 Jan 2024 11:15:00
Message: <web.65abf1629bc1d8da1f9dae3025979125@news.povray.org>
Never fear, intrepid renderer - I figgered it out.
I just needed to add the ft values in, using a constant function in the pigment
map.
So, it works, but probably could use a fair bit of improvement.
- BW
Download 'wetpaper.mp4.dat' (1599 KB)
Date: 21 Jan 2024 02:28:51
Message: <65acc7b3@news.povray.org>
Op 20/01/2024 om 17:14 schreef Bald Eagle:
> map.
> - BW
Excellent!
Just in case you want to play with those diffuse parameters, here is
some code (+ an image map) I used a long time ago in my window scene
with the Sultana (Gancaloon Project):
#declare p_curtain_1 = pigment {image_map {png
"Orange_Gold_Damask_by_R2krw9.png" gamma srgb interpolate 2 filter all 0.5}}
#declare p_curtain_2 = pigment {image_map {png
"Orange_Gold_Damask_by_R2krw9.png" gamma srgb interpolate 2 filter all 0.0}}
#declare p_curtain_sat = pigment {image_map {png
"Orange_Gold_Damask_by_R2krw9_sat.png" gamma 1 interpolate 2}}
//Material definitions
#declare Curtain_=
#declare f_curtain_1 =
finish {
   specular 0.0
   roughness 0.0005
   diffuse 0.8, 0.2  //using backside illumination
   conserve_energy
#declare f_curtain_2 =
finish {
   specular 0.25
   roughness 0.002
   diffuse 0.8, 0.3  //using backside illumination
   conserve_energy
material {
   texture {uv_mapping
     pigment_pattern {p_curtain_sat}
     texture_map {
       [0.0 pigment {p_curtain_1}
            finish {f_curtain_1}
       [1.0 pigment {p_curtain_2}
            finish {f_curtain_2}
Download 'orange_gold_damask_by_r2krw9.png' (402 KB)
Preview of image 'orange_gold_damask_by_r2krw9.png'
Date: 21 Jan 2024 02:31:37
Message: <65acc859@news.povray.org>
forgot to add the saturation map.
Download 'orange_gold_damask_by_r2krw9_sat.png' (281 KB)
Preview of image 'orange_gold_damask_by_r2krw9_sat.png'
Date: 22 Jan 2024 02:41:27
Message: <65ae1c27$1@news.povray.org>
Op 21/01/2024 om 08:28 schreef Thomas de Groot:
> Just in case you want to play with those diffuse parameters, ...
This suddenly reminds me that there also is:
interior_texture {...}
Friedrich Lohmueller used that with the leaves of his versions of Arbaro
trees..
