POV-Ray : Newsgroups : povray.binaries.animations : balls simulation (665k) Server Time
1 Jun 2024 16:11:37 EDT (-0400)
  balls simulation (665k) (Message 11 to 19 of 19)
Subject: Re: balls simulation (665k)
Date: 13 May 2002 11:49:04
Message: <3CDFE06E.48A67A89@gmx.de>
Rune wrote:
> Very nice simulation!
Thanks.
> However, even though the slow-motion playback often better show off the
> details, I usually prefer real-time playback because it gives a much
> better feel of how realistic the simulation is.
I will try making a real time version tonight, but you will of course see
less details there.
> I see that you have also found the many problems with the water surface
> algorithm that we're using... ;)
Yes.  I found you can very well influence the size of the waves by using
different kinds of disturbances, but the speed and the sinus like shape
can't be influenced at all.  Something that would be nice in that concern
is a save_file function for image maps.  This would seriously speed up the
generation of the influence grid which is the only really slow part about
the water calculation. The water simulation itself i do with an external
program.
Last updated 05 May. 2002 _____./\/^>_*_<^\/\.______
Date: 13 May 2002 16:20:18
Message: <3ce02002@news.povray.org>
Wow! This is the first one I've seen with water too!! Nice!
Date: 13 May 2002 17:18:07
Message: <3CE02D6D.5EAFCD2A@gmx.de>
*Snip*
> You can't see this as individual springs, you simply have the potential
> field of the environment and the other bodies and calculate the forces
> from it.
Well, that's an approach similiar to some CFD-models out
there. Instead of using tons of springs, some just use a limited
area for calculation with a 3D-Grid of samples. Samples affect
each other on a neighbouring basis, which I think comes very
close to being a potential field. Its a different approach, nontheless,
its rather particle-amount-independant.
Ah well. Getting off-topic, I think. ;-)
Are you using pure POV, or some C++ "plug-in"?
Hm. Cancel that question. "iso_csg" was mentioned somewhere.
Tim Nikias
Email: Tim### [at] gmxde
Date: 13 May 2002 17:35:37
Message: <3CE031A3.ACD6B1C3@gmx.de>
No.  I don't understand completely what you are saying, but it seems very
different.
I don't discretize space for calculating the collisions (apart from
calculating the gradient to be correct, but this is not important). It's
just calculating the repulsion of the balls from the field of the
environment and the other balls.
Date: 13 May 2002 18:06:42
Message: <3CE03925.3BE94A2@yahoo.com.au>
Nice simulation! Good to see someone take a different approach to particle systems
too.
Do you have an estimate on how much faster/slower your method is compared to the usual
particle system methods?
When I saw Rune's water, I had a similar idea, but did not have the time to persue it.
The balls entering the water lack splashes. I wonder whether you could generate
'water'
particles if ball velocity entering the water exceeds a certain limit. These water
particles could then be treated like other particles, with the exception that they
would be destroyed if they re-entered the pool of water.
MJL
Date: 14 May 2002 02:32:56
Message: <3CE0AF97.3DB58EC3@gmx.de>
Thanks.
Date: 14 May 2002 02:41:26
Message: <3CE0B195.FD74C607@gmx.de>
too.
usual
That difficult to say, but it's quite a bit different than a classical
particle system.  It is certainly much slower than a system like Rune's,
but you can't really compare that.  I do not yet simulate rotation of the
balls, but i plan to add that although i'm a bit afraid of the
mathematics... ;-)
it.
'water'
This is an interesting idea, but quite tricky.  Where do you think the
particles should be created and with what direction of movement?
Date: 14 May 2002 02:51:56
Message: <c8c1eukheouusnjj5ll42c4fe698f249eo@4ax.com>
On Mon, 13 May 2002 00:09:01 +0200, Christoph Hormann <chr### [at] gmxde>
wrote:
> geometry to an iso_rcsg function
finnally some serious application :-)
> a longer and better version
> can be found
really interesting and nice animation, but ... where are drops of the water ?
ABX
Date: 15 May 2002 02:04:13
Message: <3CE1FA96.CB554EC6@yahoo.com.au>
> mathematics... ;-)
Rotation... yikes! Good luck!
it.
'water'
Point of impact to no more than the radius of the ball causing the disturbance, with
directions spread between parallel to the water surface and parallel to ball surface
influence (maybe?). This is just a guess (and I haven't tried it myself) but I agree,
it is a
tricky problem. I think that knowing whether the ball will give rise to a splash or
just a
'plop' will also be hard.
MJL
