POV-Ray : Newsgroups : povray.beta-test : Problem with new focal blur noise pattern and animations Server Time
12 Jul 2025 17:29:13 EDT (-0400)
  Problem with new focal blur noise pattern and animations (Message 1 to 10 of 15)
Subject: Problem with new focal blur noise pattern and animations
Date: 10 Nov 2010 08:45:00
Message: <web.4cdaa135f1635598caa39c860@news.povray.org>
It seems like the "random" samples for focal blur are now the same on every
frame of an animation. Is there any way to randomize it per frame?
I don't mind a bit of noise but if it's not moving it looks like I'm viewing the
scene through a distorted pane of glass. I'm pretty sure it didn't used to have
this problem (though admittedly I don't often use blur in animations).
Subject: Re: Problem with new focal blur noise pattern and animations
Date: 10 Nov 2010 11:14:32
Message: <4cdac4e8$1@news.povray.org>
Can we have a demo setting to try to reproduce it ?
(with a minimal scene, please)
A good Manager will take you
through the forest, no mater what.
A Leader will take time to climb on a
Tree and say 'This is the wrong forest'.
Date: 10 Nov 2010 11:50:00
Message: <web.4cdacbf651977b7ecaa39c860@news.povray.org>
Here's a simple example. Render a few frames of this (e.g. +kfi0 +kff20)
//---start of code
#default { pigment { rgb 1 } finish { diffuse .8 emission .2 } }
background { rgb z }
plane { y, -1 pigment { checker rgb 1, rgb .8 } }
light_source { <-2,3,-1>, rgb 1 }
#declare T = frame_number/final_frame;
box { -1,1 translate x*(1-2*T) pigment { rgb x } }
 up y
 direction z*.8
 location <-1.5,.5,-3>+x*T
 look_at x*T
 aperture 0.5
 focal_point 0
 blur_samples 4
//---end of code
Notice how the noise is completely static. If I had the option to make the noise
different on every frame I'd get a much more visually pleasing result. It's
worth noting that I'm planning to blend multiple frames to get motion blur, so I
was hoping that blending would improve the focal blur too. Though in any case
static noise draws attention to itself far more than if it was moving.
Date: 10 Nov 2010 13:33:12
Message: <4cdae568$1@news.povray.org>
Le 10/11/2010 17:45, Tek nous fit lire :
Thanks.
Testing with 3.6 for windows, the reported issue was already there.
(the noise at horizon stays the same).
But that change if you raise the blur_samples to 20.
(In fact, even a value of 5 make a change at the horizon)
Date: 10 Nov 2010 14:09:54
Message: <4cdaee02@news.povray.org>
For 3.7beta, you might have a look at the bokeh setting to vary the sampling
http://wiki.povray.org/content/Documentation:Reference_Section_3
Using a moving pattern of your choice for the distribution of the
samples grid.
Date: 11 Nov 2010 06:40:00
Message: <web.4cdbd50651977b7ecaa39c860@news.povray.org>
> samples grid.
Good idea, but sometimes it still samples the same points (particularly with
very low numbers of samples).
Date: 11 Nov 2010 10:15:00
Message: <web.4cdc075a51977b7ecaa39c860@news.povray.org>
> > samples grid.
After some testing I'm getting the impression that the bokeh filter isn't
strictly applied. I'm getting square shapes when using a bokeh which is mostly
black, as if the algorithm gives up after a few tries and just uses the sample
anyway. Indeed, using a completely black bokeh filter doesn't cause any error
and I still have blur.
This is an understandable limitation of the bokeh filter implementation, but it
limits my ability to use it to randomize blur samples.
Anyway, for the time being I don't really need high quality focal blur in an
animation, and if I do I can just use more blur_samples to brute-force it. But
it would be nice if someone could take a look at the code to fix these niggles.
Date: 11 Nov 2010 12:24:44
Message: <4cdc26dc$1@news.povray.org>
Am 10.11.2010 14:42, schrieb Tek:
Using the very same focal blur sample sequence for all frames of an
animation is by design, not by error; I'm pretty sure both earlier 3.7
betas and 3.6 did the same (they used a pseudo-RNG instead of a Halton
sequence, but unless I'm totally mistaken they started the PRNG all over
again with the very same seed for each frame). There appears to be
consensus among the POV-Ray animators that static noise should be
favored over dynamic noise.
Date: 11 Nov 2010 12:58:25
Message: <4cdc2ec1@news.povray.org>
  How hard would it be to make it optional?
Date: 11 Nov 2010 13:10:01
Message: <web.4cdc315551977b7ecaa39c860@news.povray.org>
> There appears to be
Is there? Can you point me to some discussion of this topic, since I strongly
disagree.
Noise that remains static in screen space when everything else is moving draws
attention to itself. Conversely, animated noise can look quite realistic
provided you have a high enough number of samples for it to pass for film-grain,
and if you don't have enough samples it's going to look bad either way.
Obviously there's no "right" answer to which is the best error (they're both
wrong!), but it would be really nice to have the ability to set the random seed
for the focal blur so I can chose if it changes or not.
Incidentally, I'm pretty sure Pixar use animated noise... though I've failed to
Google a reference for that.
