POV-Ray : Newsgroups : povray.beta-test : Benchmark.pov update before release Server Time
25 Apr 2026 23:52:10 EDT (-0400)
  Benchmark.pov update before release (Message 17 to 26 of 26)
Subject: Re: Benchmark.pov update before release
Date: 25 May 2010 09:32:22
Message: <4bfbd166$1@news.povray.org>
Le 23/05/2010 21:52, clipka a écrit :
> Am 23.05.2010 20:33, schrieb Alain:
>> It would be good to remove at least one of those lines from
>> benchmark.ini:
>> Display=Off
>> This disable the preview.
>> Output_To_File=Off
>> This disable saving the resulting image.
>> As it is now, there is NO preview and the image is NOT saved anywhere.
> This is by design. The benchmark is /only/ a benchmark of the render
> engine, and any output activity is /not/ part of what it should measure.
But, without calling it benchmark, it might be "interesting" to be able
to render the benchmark on screen and in a file (at the same resolution
as benchmark, same AA, same ...)
Maybe an additional offer ? (with some warning about timing being not
from benchmark)
A: Because it messes up the order in which people normally read text.<br/>
Q: Why is it such a bad thing?<br/>
A: Top-posting.<br/>
Q: What is the most annoying thing on usenet and in e-mail?
Date: 25 May 2010 12:28:30
Message: <4bfbfaae$1@news.povray.org>
Le_Forgeron wrote:
> the OS scheduler sucks if we still get a 2:1 ratio!)
It's well known that the Windows scheduler sucks if you mix interactive with
compute-bound jobs. Especially at the same priority level. Almost as badly
as it sucks with interactive vs I/O-bound jobs, but not quite.
    Ada - the programming language trying to avoid
    you literally shooting yourself in the foot.
Date: 25 May 2010 12:38:59
Message: <4bfbfd23$1@news.povray.org>
On 25/05/2010 2:29 PM, Le_Forgeron wrote:
> Now that's even stranger if the last is "without Task Manager running"!
> If it is "With Task Manager running", looks normal: more charge, more time!
Sorry for the confusion, it was 17m 31s without display and without the
Task Manager running. 17m 40s without display and with the Task Manager
running.
> Good news seems to be that display does not change the time with High
> Priority.
> Now, the question would be: does it (with display or without display)
> change the time when the priority is Low (as the default) ?
Do I see a volunteer? ;-)
Best Regards,
Date: 9 Aug 2010 09:00:01
Message: <web.4c5ffa9280488a8c6cdadb0b0@news.povray.org>
Hello,
I tried 3.7 beta version, after serious problems with glass texture, media and
gamma, now I see that for several povray files the 3.7 SMP version is slower
than older 3.6 version (using only one core).
Hardware processor is core I7 870.
For core I7, the frequence is increased if you use only one core.
Did you saw something like this with the last POVRAY 3.7 SMP version.
With one povray file including glass texture, rendering time was 3 minutes using
3.6 single core and 12 minutes using 3.7 SMP.
Best regards,
JJ
Date: 9 Aug 2010 09:09:00
Message: <4c5ffdec$1@news.povray.org>
> Hello,
You are aware, of course, that some implementation have been changed ?
Great, Could compare to mine then, if needed.
I'm lazy, I do not want to search for a scene with glass texture.
Can you name one for me from the distribution, so that I could test it ?
(especially one that displayed your reported behaviour: quick on 3.6,
slow on 3.7)
Thanks in advance.
(Ready to test with the latest beta, as soon as you name the scene file)
Date: 9 Aug 2010 11:08:20
Message: <4c6019e4$1@news.povray.org>
Am 09.08.2010 15:08, schrieb Le_Forgeron:
>> Stephen<mca### [at] aolDOTcom>  wrote:
>> Hello,
@Stephen: What OS and exact versions of POV-Ray are we talking about?
Such issues have already been reported a while ago with earlier POV-Ray
3.7 betas, though mainly in conjunction with animations IIRC.
> slow on 3.7)
> Thanks in advance.
FYI: I'm currently running single-threaded (+WT1) beta.38 (inofficial
64-bit binary compiled with Intel icpc 11.1) against a collection of
~150 scenes on a Linux AMD64 machine (Phenom 9650 2.3GHz Quad-Core) to
compare them with timing results for POV-Ray 3.6.1 (official 32-bit
binary compiled with GNU g++ 3.4.1) and MegaPOV 1.2.1 (official 64-bit
binary compiled with GNU g++, unknown compiler version).
If there's anything substantial about the single-thread timing issues,
and those are /not/ OS- or compiler-dependant or specific to rare
circumstances, then it should ring an alarm bell or two on my
performance testbed.
So far, the tests have already highlighted a scene that renders in 8:35
instead of 2:40 (MegaPOV), but that one uses radiosity, which has
changed too much to be comparable.
Date: 9 Aug 2010 13:19:49
Message: <4c6038b5@news.povray.org>
>>> Hello,
>>> media and
>>> slower
Christoph, are you writing to me? Or there maybe a cut and paste type
error in the headers. Anyway I’m running Win 7 (32 bit) with Beta 38.
The benchmark is the one under Render > Run Benchmark (all CPUs) with
lots of other progs running. It took 9m 27s. Using
"C:\Users\Stephen\Documents\POV-Ray\v3.7\scenes\advanced\benchmark.ini"
took 34m 16s which is longer than what I reported previously/
Best Regards,
Date: 9 Aug 2010 13:23:45
Message: <4c6039a1$1@news.povray.org>
Am 09.08.2010 19:19, schrieb Stephen:
>>>> Hello,
>>>> media and
>>>> slower
Oops, sorry. Should have been "@JJ:", as it turns out.
Date: 9 Aug 2010 13:45:30
Message: <4c603eba$1@news.povray.org>
That's what I thought :-P
Best Regards,
Date: 9 Aug 2010 14:46:05
Message: <4c604ced$1@news.povray.org>
Am 09.08.2010 17:08, schrieb clipka:
I'm seeing notable slowdown for the following sample scenes (real
run-time in seconds):
                 MegaPOV 1.2.1   3.7.0.beta.38 +WT1
chess2.pov      223             409
grenadine.pov   164		214
infinitybox.pov  16              34  (!!!)
wineglass.pov    40              58
(plus various scenes using radiosity, but I'm ignoring those here)
Except for the "chess2.pov" slowdown, the other three appear to have
been newly introduced with beta.38, as a similar slowdown can also be
observed between multi-thread beta.37a and beta.38 for these particular
scenes.
OTOH, there is an even greater number of scenes exhibiting a notable
(and in some cases astonishing) speedup, e.g.:
glasschess.pov          499             281
landscape.pov           575              43  (!!!)
newdiffract.pov         574             129  (!!!)
projected_through.pov    36              13  (!!!)
(plus various scenes using radiosity, and others using crackle)
Again, some of these speedups can also be seen between multi-threaded
beta.37a and beta.38.
 From this I draw the conclusion that the speed balance between
individual features has indeed been changing, but the overall speed of
POV-Ray has not degraded in that process.
