POV-Ray : Newsgroups : povray.beta-test : memory problem with radiosity Server Time
13 Jul 2025 00:52:46 EDT (-0400)
  memory problem with radiosity (Message 1 to 10 of 25)
Subject: memory problem with radiosity
Date: 12 Feb 2010 11:35:01
Message: <web.4b758276b3a723006a1983ea0@news.povray.org>
I have beta 35a running on an i7 and an AMD Phenom system. I've been adopting
radiosity for my scenes, and using the beta to speed things up with the two quad
core machines. There haven't been any problems until recently but my latest
scene froze the computer. I rebooted and launched the task manager window to
analyze CPU and memory utilization. I began with the i7 system with 6GB. The
render began using about 4 GB. After the radiosity pre-trace (the funny square
phase? :)) the memory allocation began to slowly increase at the rate of about
1GB per 10 seconds. This continued until the memory was full, then Windows
(arghh!) attempted to run in virtual memory (I assume because console I/O was
slow and disk was constanly busy).
I ran to the store and purchased another 6GB of RAM, installed it and tried
again with a total of 12GB. The same thing happened (only I was able to halt the
process in time when 11.8GB was reached).
Another strange thing... I noticed that there are many times when CPU
utilization is alarmingly low. When I run version 3.6 I seen 100% utilization of
one core. With 3.7b-35a it is bursty, and spends a lot of time running at 20%
utilization. During those times, the load seems to be fairly evenly divided
between the 4 cores.
The scene in question isn't anything special, just a landscape with a few
isosurfaces and planes. The isosurfaces do contain a lot of functions, which
create a lot of divergent surface details. To be perfectly clear, when I run the
same code without radiosity everything is fine. Also I ran the same code on
version 3.6 with radiosity turned on and everything is fine.
Ideas?
Subject: Re: memory problem with radiosity
Date: 12 Feb 2010 12:01:37
Message: <4b758971$1@news.povray.org>
> Ideas?
Radiosity, an experimental feature, changed from 3.6 to 3.7, so you may need
to adjust your parameters. And it is, sadly, not uncommon for Windows to
crash when it runs out of memory.
You also did not mention that you are running a 64-bit Windows and the
64-bit version of POV-Ray. If you are not running both as 64-bit versions,
POV-Ray will never get more than 3 GB of memory, regardless of the amount of
RAM you install. This would certainly explain your low CPU usage, as it
implies your system is spending most of its time with swapping.
	Thorsten
Date: 12 Feb 2010 13:00:01
Message: <web.4b759718a32fb1cf226a7060@news.povray.org>
If it is doing a lot of swapping, then the CPU usage may drop during swaps.
> Ideas?
I am really curious about how your radiosity settings are.  Also, what is the
peak memory usage without radiosity?
-Reactor
Date: 13 Feb 2010 21:35:01
Message: <web.4b776050a32fb1c6a1983ea0@news.povray.org>
Thanks for the comments... there are good suggestions there. I prepared a test
file so that any of you could try it out. I verified that both OS and beta are
running 64 bits. I discovered that there are problems even with radiosity
commented out. Namely, CPU usage is not 100%, and control does not come back to
the GUI after the render is complete. With radiosity (using default values)
enabled, the task levels off at 7.89GB. I think it is only because I simplified
the scene. Many minutes elapse before it releases the memory, and returns
control (or I lose patience and kill the app). Here is the source code:
#include "functions.inc"
global_settings
        ambient_light 0.001
        radiosity
#declare valley_radius = 8.0;
        location <valley_radius*100, -45, 0>
        up <0, 1,  0>
        right x*1600/1200
        angle 60
        look_at <valley_radius*100,-100,4000>
light_source
        < -60, 30, -30>
        color rgb <255/256, 229/256, 123/256>
        parallel
fog {fog_type 1 distance 2000 color Gray}
#declare P1=function
                {pattern{wrinkles turbulence 0.3}}
#declare P2=function
                {pattern{crackle turbulence 0.3}}
#declare P3=function
                {pattern{bozo turbulence 0.3}}
#declare ROCK_TEXTURE_SCALE = 0.5;
#declare RockTexture = function
                P1(x,0,z)*1/4*ROCK_TEXTURE_SCALE
                +P2(x,0,z)*3/4*ROCK_TEXTURE_SCALE
#declare RockTexture2 = function
                P3(x*2,0,z*2)*1/4*ROCK_TEXTURE_SCALE
                +P3(x,0,z)*3/4*ROCK_TEXTURE_SCALE
#declare  F_valley_sides = function {exp(-(2-2*abs(x))*(2-2*abs(x)))}
#declare  F_valley_contour = function {exp(-(x*x*x*x/4))}
#declare  F_river_contour = function {exp(-(x*x*x*x*4096))}
#declare ValleySurface =
function
        y
        + F_valley_contour(sqrt(x*x+z*z)-valley_radius, y, 0) //SOR of valley
        - F_valley_sides(sqrt(x*x+z*z)-valley_radius, y, 0)*RockTexture(x,0,z)*2
//SOR of valley sides
        + F_river_contour
                                sqrt(x*x+z*z)
                                -valley_radius
                                +(0.5-f_bozo(x*2, 0, z*2))/2,
                                y,
                                0
                        )/8 //SOR of river w/ meander
        - F_river_contour
                                sqrt(x*x+z*z)
                                -valley_radius
                                y,
                                0
                        )*RockTexture(x*64,0,z*64)/8 //SOR of river
        - RockTexture2(x*8,0,z*8)*0.02
//Valley
isosurface
        function
        ValleySurface(x,y,z)
        max_gradient 8
        contained_by{box{<-80,-10,-20>,<80,3,20>}}
        texture
                pigment {colour rgb <171/256, 23/256, 15/256>}
                finish {specular 0.5  diffuse 0.5}
        scale <100, 50, 100>
// some water...
plane
        y, -51
        hollow on
        pigment { rgbt <0.1, 0.6, 0.5, 0.8> }
        normal
                bozo 1.6
                scale <0.5, 1.0, 0.5>
        finish
                ambient 0.05
                diffuse 0.2
                reflection 0.1
        interior
                ior 1.3
                media { absorption <1.8, 1.0, 0.8>/2 }
Date: 13 Feb 2010 23:05:04
Message: <4b777670@news.povray.org>
The use of the crackle pattern, in any way, result in more memory load.
Anyway, it should not acount for the load you are seeing.
It won't affect your memory problem, but will affect the speed of the
isosurfaces:
Change:
to:
#declare  F_valley_contour = function {exp(-(pow(x,4)/4))}
#declare  F_river_contour = function {exp(-(pow(x,4)*4096))}
Every time you encounter a variable, even the same used several times in
a row, you need to do a search in the variable table. It does take more
time than to elevate to a power.
Whenever you have x*x use pow(x,2).
Do the same for y*y and z*z.
For the radiosity, it's beter to NOT use ambient_lights in the
global_settings, but to use #default{finish{ambient 0}}
Date: 14 Feb 2010 01:54:00
Message: <4b779e08@news.povray.org>
The low CPU usage is likely related to the use of crackle, which requires
some data to be shared between threads. This in turn creates dependencies
between render threads. The performance of multi-threaded ray tracing
exclusively depends on the independence of render threads.
Since crackle also happens to be one of the less suitable functions for
integration performed to render it is an isosurface, it takes very long time
to find intersections with the isosurface involving a real lot of crackle
pattern evaluations. The POV-Ray statistics likely show this.
Freeing memory in this state, for various reasons, may also take quite some
time. Again, the statistics may provide some indication on what is going on.
	Thorsten, POV-Team
Date: 14 Feb 2010 12:30:01
Message: <web.4b78329aa32fb1c6a1983ea0@news.povray.org>
When I removed the crackle function from my main project, all the problems
disappeared. Memory remained stable, slightly less than 2.0GB. It will be a
painful loss, since it made such beautiful rock surfaces. I guess I will end up
using something like bozo+wrinkles instead.
It is my impression that virtual memory is useful mostly to make memory
management easier, rather than to increase the working memory capacity. It can't
work with 100% physical memory allocated because of excessive disk swapping. I
think this is a fundamental constraint that is common to all OS, whether it is
Windows or Linux or whatever.
So, in this case, the issue is only that what should have only been a painfully
slow render in physical memory, which some users might have found an acceptable
price to pay for a certain effect, became instead a full-blown failure of the
OS. If there is some way in that case, to limit the expansion of memory or exit
with an error, it would probably be better.
I also realize that with beta versions, the development issues are diverse and
priority is correctly given to primary design features above error and UI
issues.
Thanks, everyone for the help! I can now continue with my project, and I have
other radiosity questions which I will move to the other newsgroup.
>  Thorsten, POV-Team
Date: 14 Feb 2010 14:50:00
Message: <web.4b78533da32fb1c500462bb0@news.povray.org>
You mentioned having quite a bit of RAM.  Have you tried turning virtual memory
off and using a RAM disk to see how it does?  RAM disks are not difficult to set
up, and it may be worth the effort.
-Reactor
Date: 14 Feb 2010 14:59:09
Message: <4b78560d$1@news.povray.org>
Given that turning virtual memory off is impossible in Windows that seems
like an odd suggestion...
	Thorsten
Date: 14 Feb 2010 15:44:21
Message: <4b7860a5$1@news.povray.org>
> seems like an odd suggestion...
Turning virtual memory off in Windows is trivial. I don't think you can turn
off virtual addressing, but that shouldn't have an impact on this problem.
Control panel->System->Advanced->Performance->Advanced->No page file
Admittedly, it's behind two "advanced" tabs, but the help tells you how to
get there too if you put "virtual memory" into the search bar of the control
panel.
   Forget "focus follows mouse." When do
   I get "focus follows gaze"?
