POV-Ray : Newsgroups : povray.beta-test : memory problem with radiosity Server Time
20 Apr 2026 18:11:41 EDT (-0400)
  memory problem with radiosity (Message 16 to 25 of 25)
Subject: Re: memory problem with radiosity
Date: 14 Feb 2010 16:36:57
Message: <4b786cf9$1@news.povray.org>
Thorsten Froehlich wrote:
> No, that does not turn of virtual memory, it turns of the page file. The
> page file is part of the a common virtual memory implementation, but the
> most important part is that you have a non-linear physical memory (hence
> the "virtual" in "virtual memory").
That would be the "virtual addressing" of which I was speaking. "Virtual
addresses" don't match real addresses. "Virtual memory" doesn't match real
memory.
 > In effect, disabling the page file
> simply means the system cannot move writable memory out to disk. The
> system still can move all read-only memory to disk, such as code and
> static data (i.e. resources) loaded from application and library files.
This is true. And of course the application still has the ability to map
files and use page faults to read and write files. But if you're trying to
limit how much memory a program allocates in order to reduce page thrashing,
turning off the paging file will be sufficient. If you don't have enough
memory to hold POV-Ray's executable code entirely in RAM, chances are you
need more RAM anyway.
   Forget "focus follows mouse." When do
   I get "focus follows gaze"?
Date: 14 Feb 2010 18:30:36
Message: <4b78879c$1@news.povray.org>
>> The page file is part of the a common virtual memory implementation,
>> but the most important part is that you have a non-linear physical
>> memory (hence the "virtual" in "virtual memory").
> real memory.
You have your terminology confused. Read up on the subject in a textbook or
Wikipedia or Google it. All not my problem, so please stop trying to make
your mistake my problem.
	Thorsten, POV-Team
Date: 14 Feb 2010 18:33:13
Message: <4b788839$1@news.povray.org>
On 14.02.10 22:21, GraemeM wrote:
>> Turning virtual memory off in Windows is trivial. I don't think you can turn
>> off virtual addressing, but that shouldn't have an impact on this problem.
> I have experienced this with XP (32bit) and 4Gb ram.  The PC ran well for around
> 4 days and then started crashing on start up.  the only way to get it to boot
> successfully was to re-enable the virtual memory.
If you turn off your page file, the system has less memory it can assign to
applications. Windows does not handle running out of memory very well. And
again, you turn writing to the page file, you do not turn off virtual memory.
	Thorsten
Date: 14 Feb 2010 20:00:41
Message: <4b789cb9$1@news.povray.org>
> Read up on the subject in a textbook or Wikipedia or Google it.
I wasn't going to argue it, but you keep bringing it up. Different people
call it different things. Wikipedia points "virtual addressing" and "virtual
memory" at the same page, and it's quite possible to have either one without
the other, so they've simplified.  I don't really care what you call it.
And yes, I've read many a textbook on the topic, so I'll take the textbooks
I read while getting a Ph.D., written by people who actually design modern
CPUs, as more authoritative than Wikipedia, but thanks for playing.
Date: 14 Feb 2010 21:01:14
Message: <4b78aaea$1@news.povray.org>
On 2/14/2010 1:58 PM, Ken Willmott wrote:
>>> Given that turning virtual memory off is impossible in Windows that
>>> seems like an odd suggestion...
>> Control panel->System->Advanced->Performance->Advanced->No page file
>> Admittedly, it's behind two "advanced" tabs, but the help tells you how to
>> get there too if you put "virtual memory" into the search bar of the control
>> panel.
> Interesting, I had no idea this was possible. Actually though, I believe it is
> probably better to leave it alone. It's probably there to allow better real-time
> performance for time critical apps.
As a rule, usually is. Windows will try to page, even if it *has*
sufficient system memory available, due to how it loads/unloads things
it doesn't need immediately. And, you run into major issues "if" you
don't have it and hit the memory limit.
About the only thing its good for, if you have the system memory, is to
wipe it with a reboot (after turning it off), run a *detailed*
defragger, which consolidates files properly (most won't), then put it
back, and restart. This causes the original to be removed, and a new one
to be created, contiguously, at the end of the high end of the
partition. I doubt 7 is any better than any other version has ever been
at this, so **eventually** the page file gets so screwed up that
everything runs like crap. Killing the file, consolidating everything,
then restoring it is the most effective solution, but if you have enough
free space, there are 1-2 things that *specifically* defrag the page
file, during startup, and before its in use.
Otherwise, you could turn it off in Windows, but, as I said, Windows
doesn't like you doing it **at all**.
void main () {
     if version = "Vista" {
       call slow_by_half();
       call DRM_everything();
     call functional_code();
   else
     call crash_windows();
<A HREF='http://www.daz3d.com/index.php?refid=16130551'>Get 3D Models,
3D Content, and 3D Software at DAZ3D!</A>
Date: 14 Feb 2010 22:12:03
Message: <4b78bb83$1@news.povray.org>
Easiest is to simply create the file at a fixed size, and don't let it grow
or shrink. It'll be created contiguously if you have one spot big enough for
it. It's when you say "Let Windows manage it" that it tries to grow and
shrink it on demand. If you have 30G free space, allocating a 5G contiguous
swap file shouldn't be problematic.
I don't know. I've run for years without a page file and never had a
complaint, on both Win32 and Win64. As long as you have enough memory, it's
really not a problem.
This really isn't the forum for this discussion, tho.
Date: 15 Feb 2010 02:06:14
Message: <4b78f266$1@news.povray.org>
> people call it different things. Wikipedia points "virtual addressing"
> and "virtual memory" at the same page, and it's quite possible to have
> either one without the other, so they've simplified. I don't really care
> what you call it. And yes, I've read many a textbook on the topic, so
> I'll take the textbooks I read while getting a Ph.D., written by people
> who actually design modern CPUs, as more authoritative than Wikipedia,
*plonk*
Date: 15 Feb 2010 02:32:53
Message: <4b78f8a5$1@news.povray.org>
>>> turn off virtual addressing, but that shouldn't have an impact on this
>>> problem.
>> the "virtual" in "virtual memory"). In effect, disabling the page file
> What is even more surprising is that it is even explained on Wikipedia
> fairly well, so before this starts some argument I will post the link:
> <http://en.wikipedia.org/wiki/Virtual_memory>
And for all those who do not like Wikipedia, here the same news from
Microsoft: <http://msdn.microsoft.com/en-us/library/ms810616.aspx>
	Thorsten
Date: 15 Feb 2010 10:08:24
Message: <4b796368$1@news.povray.org>
>>> can turn
>>> problem.
>>> how to
>>> control
>>> panel.
>> believe it is
>> real-time
Never let windows complete control over the page file, and don't leave
it on the same partition as windows.
One of the best way to manage it is to create a dedicated partition with
nothing else on it, then to hide that partition.
If you have more than one hard drives, create a drive leter less
partition as the first partition on each drives and make those contain
your page file. It should be the first thing done on any new system.
Date: 16 Feb 2010 00:43:21
Message: <4b7a3079$1@news.povray.org>
>>>> can turn
>>>> problem.
>>>> how to
>>>> control
>>>> panel.
>>> believe it is
>>> real-time
> Alain
Hmm. Interesting idea, actually. I fowled up and made a mini-partition
on mine, thinking it was like 98, and some stuff would be easy to shift
some place else. If I ever manage to find something that can nuke the
Fedora partitions I never use, I can make one for it out of that (its a
virtual partition, so half the damn tools a) don't recognize it or b)
know how to delete it...)
void main () {
   else
