POV-Ray : Newsgroups : povray.beta-test : Same scene renders different in v3.7beta34 versus v3.62 Server Time
20 Mar 2026 00:11:53 EDT (-0400)
  Same scene renders different in v3.7beta34 versus v3.62 (Message 45 to 54 of 104)
Subject: Re: Same scene renders different in v3.7beta34 versus v3.62
Date: 31 Aug 2009 15:58:06
Message: <4a9c2b4e@news.povray.org>
Warp wrote:
> Warp <war### [at] tagpovrayorg> wrote:
>>   Now the lower half of the rendered images is a checkerboard pattern of
>> alternating black and white pixels.
>   There was a warning somewhere that a checkerboard patter should *not* be
> used for this kind of test because it doesn't work properly with CRT
> monitors. Instead, alternating horizontal lines should be used instead.
I have an LCD monitor, and the checkerboard looked *green*. Quite strange.
Now with the horizontal stripes. POV3.6 looks too dark and POV3.7 looks too
light.
Date: 31 Aug 2009 16:28:32
Message: <4a9c3270@news.povray.org>
> light.
  As I already wrote, now that I'm using the proper test (at least for CRT
monitors, which is what I have), I must admit that the 3.7 image background
looks very even with my monitor. I suppose that my monitor does indeed
require a gamma correction of almost exactly 2.2 for proper brightness,
and that my system settings were correct to begin with.
  On the other hand, I'm wondering how precise this test really is.
Bright white lines stand out a lot more than black lines, and the brighter
the white lines are, the more they tend to glow to the human eye. A bit
like color bleeding. This would mean that if your monitor is set very
bright, then the white lines will overwhelm the black ones, requiring
a different gamma correction value than if your monitor was set to a
very dim setting, in which case the white lines won't stand out that much
compared to the black lines.
Date: 31 Aug 2009 16:35:29
Message: <4a9c3411$1@news.povray.org>
Isn't this kind of the point, tho? Unless you turn up both the black level
and the white level in a controlled way, I'd think increasing the brightness
of one or the other is going to mean you have to correct your images
differently for them to "look right".
   Understanding the structure of the universe
    via religion is like understanding the
     structure of computers via Tron.
Date: 31 Aug 2009 16:57:55
Message: <4a9c3952@news.povray.org>
  What I meant is that, at least it seems to me, this phenomenon would be
exclusive to this precise test (in other words, alternating black/white
horizontal lines) and might not correspond to what is intended to be a
"50% gray" in an image would really look like on your monitor.
  Or if I try to express myself more clearly: Could it be that this
precise test (the horizontal lines) gives you the wrong impression of
what the proper gamma setting for your monitor would really be, this
visual impression being biased by the brightness setting of the monitor?
  If you used a completely different test, eg. physical pieces of paper
colored appropriately, would you end up with the same gamma setting?
Date: 31 Aug 2009 17:42:05
Message: <4a9c43ad@news.povray.org>
I see. That makes more sense, yes.
Date: 31 Aug 2009 22:51:14
Message: <4a9c8c22$1@news.povray.org>
Warp schrieb:
>   I find it a bit hypocritical for you to criticize me and tell me to shut
> the fuck up when even you can't get the math right.
That's what happens when one gets annoyed by the other one not
listening, alleging that one is "explaining nothing at all", and being
extraordinarily demanding: It drastically reduces the motivation to
invest time into it.
Besides it would be more humiliating for me if I didn't know already
that I keep getting the exponent wrong way round.
Date: 31 Aug 2009 22:58:53
Message: <4a9c8ded@news.povray.org>
Warp schrieb:
>   (Btw, IMO there still should be a way of telling POV-Ray to not gamma
> correct anything if that's what the user wishes. Currently it seems to
> be difficult, as POV-Ray seems to be writing a gamma value of 2.2 to the
> output PNG file regardless of what File_Gamma is. I don't even understand
> where it's getting that 2.2 value from.)
That's not POV-Ray, it's the display software. Encoded pixel data and
the embedded gamma information together allow the viewing software to
reconstruct the linear values, and it will then convert this to whatever
it assumes the actual display hardware gamma to be.
Date: 31 Aug 2009 23:00:12
Message: <4a9c8e3c@news.povray.org>
Warp schrieb:
>   It was not, after all, a problem with my monitor gamma. It was a problem
> with the test being skewed by how CRT works.
That does explain the whole smash then. I didn't expect it to make that
much of a difference (I'm using an LCD myself).
>   There's still the problem of the image map incorrectly brightening, though.
Input file gamma issues. POV-Ray, as mentioned already, is currently
pretty poor about this (and has always been, by the way).
Date: 31 Aug 2009 23:01:31
Message: <4a9c8e8b$1@news.povray.org>
Do you use an analog or digital connection?
Date: 31 Aug 2009 23:07:50
Message: <4a9c9006@news.povray.org>
You can do the same test with a 0.0 / 0.5 checkerboard and 0.25
background, for instance.
Indeed lighting conditions (of your room, not your scene ;-)) do
influence the perception of brightness and mess with the gamma, so I'd
assume display brightness possibly does as well.
