POV-Ray : Newsgroups : povray.beta-test : Same scene renders different in v3.7beta34 versus v3.62 Server Time
5 May 2026 20:15:37 EDT (-0400)
  Same scene renders different in v3.7beta34 versus v3.62 (Message 11 to 20 of 104)
Subject: Re: Same scene renders different in v3.7beta34 versus v3.62
Date: 23 Aug 2009 02:48:36
Message: <4a90e644@news.povray.org>
> Warp schrieb:
> >> Maybe because they actually /do/ render identically, provided you
> >> specify "#version 3.6" to enforce backward compatibility?
> >   That didn't really answer my question.
> Of course it didn't - if the question is based on false observations and
> therefore moot, what point would there be in answering it?
  How is it a false observation that I take a scene, render it in 3.6 and
3.7, and I get results which only differ in their gamma setting, and they
do so rather radically?
  Obviously the default gamma settings are different. What has never been
obvious to me is the reason for this.
> That is, unless you are asking why the behavior is different when a
> #version statement is /not/ present. But in that case, there's no reason
> to favor compatibility over correctness: 3.6 default gamma handling was
> simply wrong (because it wasn't any gamma handling at all, thereby
> producing linear output where other software commonly expects
> gamma-precorrected files).
  Could you be more precise about this? I still don't understand the reason.
Maybe some concrete examples?
Date: 23 Aug 2009 04:54:40
Message: <4a9103d0@news.povray.org>
Take any scene with (A) an object with a small-scale black-and-white
checker pattern (if you're using a CRT display, use a large scale
horizontally), and (B) some rgb 0.5 object. Render without AA.
Now if you render the whole smash and squint your eyes, you /should/ see
just plain 50% grey for both objects.
Indeed the black-and-white object (A) /will/ look 50% grey (unless your
display's black and/or white point are bogus), because POV-Ray will have
output the perfectly unambiguous values 0 and 255 representing 0% and
100% intensity respectively, in a 1:1 mix, and averaged no earlier than
when passing between your eyelids.
In 3.6, however, the rgb 0.5 object (B) will look way darker: POV-Ray
will have output "127", but your graphics card + display will interpret
this as a meager 22% grey (0.5^2.2 - provided your display has indeed a
gamma of 2.2).
3.7, on the other hand, will output "186" (255 * 0.5^(1/2.2)) for rgb
0.5, which is just the right value for a 2.2-gamma display system to
show 50% grey ((186/255)^2.2); even if your display gamma is somewhat
off, like 2.0 or so, it will still be closer to the right thing than the
3.6 output.
(Or, alternatively, POV-Ray will output "127", but store information in
the output file that a display gamma of 1.0 has been assumed, leaving it
  to the image viewer to perform gamma-correction; this will happen for
instance if you choose PNG output and set File_Gamma=1.0.)
Date: 23 Aug 2009 05:02:50
Message: <4a9105b9@news.povray.org>
  You mean that POV-Ray 3.6 didn't gamma-correct the output at all, while
POV-Ray 3.7 now does?
  Does that mean there's now a new option to set the gamma correction of
the created image (the actual pixels, not just some header data in the
image file format)? Is there a way to turn this off, if one so desires
(eg. if you really *want* the pixels to be exactly (127,127,127) and
nothing else)?
Date: 23 Aug 2009 05:24:31
Message: <4a910acf$1@news.povray.org>
I mean that 3.6 didn't do it /by default/ (which is what you've been
asking about all the time).
> nothing else)?
Yup. "File_Gamma" is the magic ini file option. Set it to 1.0 and you'll
get linear pixel values, plus (for PNG and HDR) a header saying that the
data is linear. Set it to 2.2 and you'll get gamma pre-corrected pixel
values, plus a header saying that the data is pre-corrected for a gamma
of 2.2. (The latter is highly recommended though, as not all viewers -
browsers included - support linear image data.)
Note that this makes it impossible to deliberately mess with gamma for
artistic effect in POV-Ray when you use PNG output and all your image
processing software handles gAMA chunks properly: You can only affect
the encoding of pixels - and thereby the dynamic ranges of highlights
vs. shadows - but not their interpretation.
At least that's the theory as known to me. I never tested in detail
whether it indeed works exactly as intended.
Date: 23 Aug 2009 06:47:31
Message: <4a911e43@news.povray.org>
> > nothing else)?
  Well, this clears things up a bit. I'm still not 100% happy that old
scenes will render differently by default, but I suppose it's an acceptable
change.
  I highly recommend writing a concise and clear explanation of this in the
"what's new in POV-Ray 3.7" section when the final version is published.
Else it's only going to cause a lot of confusion.
Date: 23 Aug 2009 13:18:02
Message: <4a9179ca$1@news.povray.org>
> change.
/That/, as I mentioned as well, is only the case if they don't have a
"#version" directive, or when you're rendering to a "gamma-aware" file
format.
Boy, how /I/ long for a concise and clear explanation of gamma! Output
gamma is only the tip of the iceberg.
Try feeding POV-Ray output into POV-Ray again as a texture image -
that's where things appear to get /really/ hairy!
Date: 29 Aug 2009 11:20:12
Message: <4a99472c@news.povray.org>
Btw, if I load a jpeg image as an image_map to an object with diffuse 0
and ambient 1, the image will look way too bright and washed out, completely
different than when I look at the image with any other program.
  If I write an "assumed_gamma 2.2" in the global_settings block, pov3.7
will warn me, but now the image will look correct.
  So what is the *proper* way to tell pov3.7 how it should assume colors
(eg. in image maps) to be gamma-corrected?
Date: 29 Aug 2009 12:49:16
Message: <4a995c0c@news.povray.org>
  Btw, if I put "Display_Gamma=1.0" in povray.ini, then the *display* shows
the proper gamma. However, the generated png file has the wrong gamma.
  I thought that I could fix that by adding "File_Gamma=1.0", but that had
no effect on anything. Neither does "File_Gamma=2.2" or anything else.
Date: 29 Aug 2009 15:05:10
Message: <4a997be6$1@news.povray.org>
Apparently POV-Ray fails to properly read the gamma information from its
own generated PNG files. There has been some discusson about this in thread:
news://news.povray.org:119/web.4a398f2555c7683545339cfa0@news.povray.org
Date: 29 Aug 2009 15:30:09
Message: <4a9981c1@news.povray.org>
  In this case it's not a problem of POV-Ray itself reading its own PNG files.
It's a problem of POV-Ray always creating image files with the same (and to
my understanding wrong) gamma value, regardless of what the File_Gamma ini
setting is.
