POV-Ray : Newsgroups : povray.beta-test : Gamma? Server Time
4 Mar 2026 05:35:21 EST (-0500)
  Gamma? (Message 1 to 9 of 9)
Subject: Gamma?
Date: 29 Oct 2008 13:40:00
Message: <web.49089f15440ec5fc5b4449250@news.povray.org>
SO how does gamma work in POV these days?
When I try to use global_settings {assumed_gamma ...} I get an error message
telling me that this will not work any more and directing me to the
documentation. The documentation, however, touts Display_gamma and [quote]"the
new assumed_gamma global setting"[end quote].
I can state confidently that the gamma that is actually put into my renders is
way too high -- every image I create is very bright with very little contrast.
None of the ini-files I can find has Display_gamma set so this should default to
2.2 (according to the documentation) which is about right judging from the
greyscale chart in the docs. I manually correct the images after-the-fact in a
graphics program (PhotoStudio 5.5 in case that matters) and they look about
right when I reduce gamma to about 50%.
(This is 3.7b29 - I've been following every beta since 3.6;
  Win2k3, but I get the same effect on my XP and S.08 boxes)
Subject: Re: Gamma?
Date: 29 Oct 2008 13:47:41
Message: <4908a1bd@news.povray.org>
  This is actually something I would like to know as well. As far as
I remember all POV-Ray 3.7 betas have used by default a much brighter gamma
than POV-Ray 3.6 uses by default, and nowhere have I seen an explanation
for this. This means that all scenes will render very differently in 3.7
than they do in 3.6, unless you specifically go and specify an assumed_gamma
when rendering with 3.7.
  Why was the default gamma changed so drastically in 3.7 compared to 3.6?
Why can't the default gamma be the same in both? Having a drastically
different default is only going to cause problems, as scenes will render
very differently.
Subject: Re: Gamma?
Date: 31 Oct 2008 06:12:30
Message: <490ada0e$1@news.povray.org>
"Sven Geier" <.sven.at.sgeier.dot.net.nospamplease> wrote in message
news:web.49089f15440ec5fc5b4449250@news.povray.org...
I can only comment about what works for me ....
The scene I'm working on right now has this in the globals block:
#if (version < 3.7)
    assumed_gamma 2.2
with Display_Gamma=2.5 in quickres.ini  my scene renders the same in 3.6.1
and 3.7 beta's
Jim
Subject: Re: Gamma?
Date: 2 Nov 2008 23:50:00
Message: <web.490e82ae66e3e89ea044b9730@news.povray.org>
I noticed this today.  I received an error about gamma when rendering an image
with the version set.  I turned off the version information and the the image
created was overexposed.
> and 3.7 beta's
Okay, I tried this, expect I put the Display_Gamma in povray.ini.  However, it
still was pretty bright.  I tried "Display_Gamma=1.0" instead and everything is
darker, more like what I expect.  I also tried 1.8 (MAC), 2.2 (Windows) and both
created an overexposed image.
Note that I'm using Vista.  I haven't tested with XP but I assume I'll get the
same results.
Subject: Re: Gamma?
Date: 3 Nov 2008 05:01:30
Message: <490ecbfa$1@news.povray.org>
"SafePit" <ste### [at] reids4funcom> wrote in message
news:web.490e82ae66e3e89ea044b9730@news.povray.org...
>image
> image
>> 3.6.1
>> and 3.7 beta's
> However, it
> everything is
> and both
I think you got it wrong!
There are two parts for this .....
The Display_Gamma=XX goes in the command line box, or in quickres.ini file.
From the top toolbar select Tools/Edit resolution INI file.  The entry
differes from display to display. My value is 2.5 yours may be the same or
it may not. The other piece is in your scence source file ....
#if (version < 3.7)
    assumed_gamma 2.2
Cheers Jim
Subject: Re: Gamma?
Date: 3 Nov 2008 06:32:29
Message: <490ee14d@news.povray.org>
I think you mean a warning message? It should not be an error (errors halt
parsing).
The gamma changes are covered in the release notes. I've once summarized
them in message http://news.povray.org/4891a3cf$1@news.povray.org.
-- Chris
Subject: Re: Gamma?
Date: 3 Nov 2008 20:50:00
Message: <web.490faa2766e3e89ea044b9730@news.povray.org>
It also works in povray.ini which, for Windows, is read first for global
options.  Quickres.ini would override the defaults.
ust to make sure, I also tested on the command line with the same results.
Display_Gamma=1.0 looked good, 1.8/2.2/2.5 were all blown out.
> #if (version < 3.7)
>     assumed_gamma 2.2
> #end
Yep, I did add that option, although it doesn't make any difference in 3.7.  :-)
Thanks for the help Jim, it got me where I needed!  Even if I needed a different
value.
Subject: Re: Gamma?
Date: 4 Nov 2008 05:17:33
Message: <4910213d@news.povray.org>
news:web.490faa2766e3e89ea044b9730@news.povray.org...
>> #if (version < 3.7)
>>     assumed_gamma 2.2
>> #end
> 3.7.  :-)
that's because assumed_gamma is not used in v3.7 anymore just Dispaly_Gamma
like chris said in his post, you should read release notes
Subject: Re: Gamma?
Date: 21 Nov 2008 12:39:53
Message: <4926f269$1@news.povray.org>
An easy way to fix this is to add these to the end of your master POVRAY.INI
file
; Picture brightness
Display_Gamma=1
File_Gamma=1
For me the only setting that makes "normal" looking pictures is 1.0, higher
values look to bright/washed out.
Sorry if you don't agree but it works best for me...
> message
> [quote]"the
> renders is
> contrast.
> default to
> in a
> about
