POV-Ray : Newsgroups : povray.beta-test : Subsurface scattering Server Time
14 May 2024 01:21:56 EDT (-0400)
  Subsurface scattering (Message 9 to 18 of 18)
<<< Previous 8 Messages Goto Initial 10 Messages
Subject: Re: Subsurface scattering
Date: 5 Feb 2018 05:03:45
Message: <5a782c01$1@news.povray.org>
On 05/02/2018 08:57, Mike Horvath wrote:
> On 2/4/2018 3:03 AM, Stephen wrote:
>> On 04/02/2018 06:59, Mike Horvath wrote:
>>> Does POV have this feature yet, or is it still just an Uberpov thing?
>> Yes in Ver 3.7
> Do you mean 3.7.1? Because that's what it says in my old uberpov scenes.
3.7.0 on my machine. I've not used it much recently.
Regards
Date: 5 Feb 2018 06:16:13
Message: <5a783cfd$1@news.povray.org>
On 02/05/2018 04:20 AM, Mike Horvath wrote:
> I tried an old scene that worked properly in uberpov, but I see no
> effect in 3.7.0 or 3.8.0 alpha.
> Here are my global_settings:
> global_settings
>      assumed_gamma    1
>      #if (Use_Radiosity = 1)
>          radiosity
>              pretrace_start    0.1
>              pretrace_end    0.001
>              recursion_limit    2
>              count            3
>              nearest_count    20,10
>              always_sample    off
>              maximum_reuse    0.1
>              minimum_reuse    0.001
> //            no_cache
>      #end
>      ambient_light    0
> //    mm_per_unit        0.4
>      mm_per_unit        1/4000
>      adc_bailout        0.001
>      max_trace_level    8
>      subsurface
>          samples 5, 5
>          radiosity true
> Here is my finish:
>      #declare lg_solid_finish = finish
>          ambient    0
>          #if (lg_quality >= 2)
>              diffuse albedo    0.9
>              specular albedo    PlasticSpecularity
>              roughness PlasticRoughness
>              fresnel on
>              reflection
>                  PlasticSpecularity
> //                roughness PlasticRoughness
>                  fresnel on
>          #end
>          conserve_energy
> Are there additional settings I am missing?
> Mike
You need a subsurface {} block in your finish {} block in addition too
the one in global_settings {}.
Remember there are almost always example scenes for features. A
subsurface.pov sample scene ships with POV-Ray. It can also be found
online at:
https://github.com/POV-Ray/povray/tree/master/distribution/scenes/subsurface
Bill P.
Date: 5 Feb 2018 07:56:30
Message: <5a78547e@news.povray.org>
>> global_settings
>>      assumed_gamma    1
>>          radiosity
>>              pretrace_start    0.1
>>              pretrace_end    0.001
>>              recursion_limit    2
>>              count            3
>>              nearest_count    20,10
>>              always_sample    off
>>              maximum_reuse    0.1
>>              minimum_reuse    0.001
>> //            no_cache
>>      #end
>>      ambient_light    0
>> //    mm_per_unit        0.4
>>      mm_per_unit        1/4000
>>      adc_bailout        0.001
>>      max_trace_level    8
>>      subsurface
>>          samples 5, 5
>>          radiosity true
>> Here is my finish:
>>          ambient    0
>>              diffuse albedo    0.9
>>              fresnel on
>>              reflection
>>                  PlasticSpecularity
>>                  fresnel on
>>          #end
>>          conserve_energy
>> Mike
> online at:
> Bill P.
Thanks!!
For LEGO, should I just reuse the surface color for the transparency? Or
something else, like white or black?
Mike
Date: 5 Feb 2018 11:43:31
Message: <5a7889b3@news.povray.org>
Am 04.02.2018 um 07:59 schrieb Mike Horvath:
It never was an UberPOV-only thing in the first place ;)
Date: 5 Feb 2018 12:18:13
Message: <5a7891d5$1@news.povray.org>
Am 05.02.2018 um 03:10 schrieb Mike Horvath:
>> Yes in Ver 3.7
> Does anyone know what appropriate values might be for LEGO (Ldraw) models?
> Here are the mm and ldu units:
> http://www.brickwiki.info/wiki/LDraw_unit
According to that table, and presuming that POV-Ray export of LDraw
models uses 1 LDU = 1 unit in POV-Ray, you should use
    global_settings {
      mm_per_unit 0.4
and either of:
    // opaque (ABS, acrylnitrile butadien styrene)
    interior { ior 1.6 }
    // transparent (Makrolon(R), a polycarbonate)
    interior { ior 1.585 dispersion 1.02 }
    // axles (polyamide, maybe Nylon)
    interior { ior 1.53 }
(The `ior.inc` in the master branch contains values for ABS and PC,
named `iorABS`, `iorPC` and `dispPC`, respectively, but not for PC yet;
it also needs a POV-Ray version newer than v3.7.0.)
As for the subsurface translucency values, you'll have to tinker. I know
of no measured values, and the properties may differ from colour to colour.
Date: 5 Feb 2018 12:34:04
Message: <5a78958c$1@news.povray.org>
Am 05.02.2018 um 13:56 schrieb Mike Horvath:
I guess you mean the `translucency` setting.
No, use neither the pigment colour nor black.
This is actually not a colour /per se/, but rather a value related to
the average distance a photon will travel inside the material before
being absorbed/scattered/both (can't remember the exact interpretation
off the top of my head), which can be specified differently for the
three colour channels (R,G,B).
There are no limits to the setting -- particularly translucent materials
might have values like <10,10,10> or even higher, while "dense"
materials might have values like <0.1,0.1,0.1> or even lower.
I'd start at <1,1,1> and see how it looks. If the material appears too
waxy, reduce the value. If it appears too "hard", increase the value.
Date: 5 Feb 2018 17:33:30
Message: <5a78dbba$1@news.povray.org>
I think I've been confusing two entirely different features. What I've
been trying to achieve is *blurred reflections*, not SSLT. Are they
related? I got confused because my old Uberpov scenes tried to do both.
But blurred reflections are still an Uberpov-only thing right?
Mike
Date: 6 Feb 2018 08:53:13
Message: <5a79b349$1@news.povray.org>
Am 05.02.2018 um 23:33 schrieb Mike Horvath:
> related?
No, not at all. Essentially the only thing they have in common is that
they both are stochastic algorithms and as such create a bit of pixel noise.
Yup.
Date: 6 Feb 2018 21:00:00
Message: <web.5a7a5cacff8943e7a47873e10@news.povray.org>
> global_settings
> [snip]
>  subsurface
>   samples 5, 5
>   radiosity true
I have only limited experience with SSLT so far, but your samples count should
be much higher (try 100,100); otherwise you'll still see some linear-like
stochastic noise or blotches. I *think* the noise appearance has no relation to
the size of the object or its distance from the camera; it shows up as the same
'size' in the render no matter what.
Date: 8 Feb 2018 16:15:48
Message: <5a7cbe04$1@news.povray.org>
>> global_settings
>> [snip]
>>   subsurface
>>    samples 5, 5
>>    radiosity true
The dafault values are 20, 20. You can reduce that if you can live with
some graininess. In my experience, something around 10 to 15 tend to
give acceptable results.
If you have very low translucency, or very large relative to the size of
the object, you may be able to get away with smaller values.
Also, when taking radiosity into account, you probably need to take more
samples.
