POV-Ray : Newsgroups : povray.beta-test : Gamma of interpolated colors in color maps Server Time
24 Jun 2026 15:52:31 EDT (-0400)
  Gamma of interpolated colors in color maps (Message 11 to 20 of 36)
Subject: Re: Gamma of interpolated colors in color maps
Date: 21 Dec 2010 04:48:20
Message: <4d1077e4$1@news.povray.org>
>    As said, I don't really know *why* this is so. As I have mentioned,
> with my CRT a 'rgb 0.5' as produced by pov3.7 by default looks about
> 50% gray when compared to a test pattern, so *in theory* a linear
> gradient produced by pov3.7 should look linear.
No it shouldn't - your eye/brain does not see light in a linear fashion.
  50% actual brightness from something (as measured in cd/m^2 or
whatever) will *not* look half as bright as 100%.  It's no different to
a real scene, light bulbs, or an image on your monitor.  It's just the
way your eye/brain works.
An analogy is hearing, a sound with twice the physical power (in Watts)
does not sound twice as loud to a human.
Date: 21 Dec 2010 05:46:04
Message: <4d10856c@news.povray.org>
  I suppose the fundamental question would then be: "If I say to povray
to produce a linear gradient, should it produce a gradient which is
linear according to light intensity, or according to the perceived
linearity as seen by people?"
  What I'm getting at is that when people specify a linear gradient,
they expect to get a gradient that *looks* linear (rather than a gradient
that might be linear as measured by some device that measures light
intensity).
  As for whether eg. surface shading looks more realistic with the new
gamma handling or the old one, it would be interesting to see some
actual comparisons with photographs. (Note that I'm *not* saying here
that in my opinion pov3.6 is producing the more closer-to-reality
result while pov3.7 is producing something which is way off. I'm
completely honestly interested in actual comparisons with real-life
photographs, to see which one gets closer, if that would be possible.)
Date: 21 Dec 2010 06:00:12
Message: <4d1088bc$1@news.povray.org>
Agreed, as I wrote already it might be a good idea for an additional
keyword (to be used in colour maps) that specifies whether you want
physical linear interpolation (which will "look" non-linear) or some
other interpolation type suited to the human visual system.  This would
be totally separate to any gamma settings, as it has nothing to do with
gamma.
For grey-scales you can already simply use something like "poly_wave 3"
to get a more natural gradient, but once colours are involved it's going
to look wrong without some more sophisticated interpolation algorithm.
The problem with that kind of test is that you are also testing the
surface lighting equations used in POV (which are a simplification of
real surfaces).  I wasn't aware there was any doubt as to whether the
new gamma was more accurate (you can simply test it with a black/white
checkerboard next to 50% grey).
Date: 21 Dec 2010 07:26:16
Message: <4d109ce8$1@news.povray.org>
Am 21.12.2010 12:00, schrieb scott:
> gamma.
Not sure whether I mentioned it here or not, but such a mechanism has
already been on my agenda for a while (it will not make it into 3.7.0
proper though); the syntax would be something along the lines of
     gradient y
     color_map {
       perceptual
       [0.0 rgb 0]
       [0.5 rgb 1]
       [1.0 rgb 0.5]
(The example also showcases the problem with the poly_wave workaround
you mention, which only works for gradients running from [0.0 rgb 0] to
[1.0 Some_Color].)
Pigment maps will need the same mechanism, btw. I also thought about
whether it would make sense in texture maps, but I guess that's too
complicated to implement, for too little gain.
> real surfaces). I wasn't aware there was any doubt as to whether the new
There's also the problem that photographs may be non-linear as well;
digital cameras aren't typically calibrated, and photographic paper has
non-linearities, too.
A typical reference image would be the Cornell Box (see
http://www.graphics.cornell.edu/online/box/).
Date: 21 Dec 2010 08:45:29
Message: <4d10af79$1@news.povray.org>
> proper though);
OOC did you decide already which algorithm to use for this?  Will it
give more linear looking gradients between different colours too?
> pigment {
> gradient y
> color_map {
> perceptual
> [0.0 rgb 0]
> [0.5 rgb 1]
> [1.0 rgb 0.5]
That's exactly the sort of thing I was thinking of.  Maybe Warp will
argue that the default should be "perceptual" though, and we need a
"linear" keyword to revert to the existing behaviour.
I have no idea how well consumer-grade cameras are made, but my camera
has an option for sRGB or Adobe RGB colour space, so I imagine it can't
be that far off either one when selected.  Photographic film is probably
worse, IDK.
Date: 21 Dec 2010 09:20:26
Message: <4d10b7aa$1@news.povray.org>
Am 21.12.2010 14:45, schrieb scott:
>> proper though);
> OOC did you decide already which algorithm to use for this? Will it give
I expect so.
When interpolating between two colors, POV-Ray currently computes
something along the lines of:
   q = 1-p;
   result = p * color1 + q * color2;
For a "perceptually linear" gradient, the formula would be changed to:
   q = 1-p;
   temp1 = pow(color1, 1/gamma);
   temp2 = pow(color2, 1/gamma);
   tempR = p * color1 + q * color2;
   result = pow(tempR, gamma);
where gamma would be a value around 2.5.
... except that he'd even argue that "linear" would be the wrong keyword
for that purpose.
I'll just let him argue then. I'm not reading his newsgroup postings
anyway, as it would ultimately result in the two of us getting mad at
each other. Never put two zealots adhering to contradicting dogmata in
the same room. Fortunately (for me) I'm not in a position of needing to
be heard to get my will.
Date: 21 Dec 2010 13:14:53
Message: <4d10ee9c@news.povray.org>
  The thing is that most people are used to specifying colors as perceived
by the human eye rather than in watts. For example, doubling the values of
the color components is expected to double the brightness of the color
(iow. eg. 'rgb 0.8' is assumed to be twice as bright as 'rgb 0.4').
  To elaborate, if I have understood correctly, POV-Ray 3.7 has been
changed so that regular color specifications express the power of
luminous radiation (which is called radiant flux, and in physics is
measured in watts) rather than the perceived luminosity as seen by
the human eye. The relation between these two is not linear (but closer
to logarithmic). This means that eg. doubling the radiant flux (ie.
doubling the "wattage") does not correspond to doubling the perceived
luminosity of the color, as seen by the human eye.
  This might correspond more closely to reality when calculating
illumination. For example surfaces reflect a portion of the light they
receive, and this portion is relative to the radiant flux, not to the
perceived brightness. (In other words, if the surface properties and
angle with respect to incoming light is so that it reflects exactly
half of the light it receives, this half is measures in watts, not in
what the human eye perceives as "half bright".) I suppose that at least
in theory this ought to give a more realistic end result for surface
illumination, ie. a result which corresponds more to real life.
  As said, the only problem is that people are accustomed to specifying
colors and color gradients in perceived luminosity, not in watts. This
can and will cause confusion.
  In POV-Ray 3.6 color specifications correspond directly to pixel
component values, and this happens to be close to linear with respect
to the perceived luminosity, and hence 'rgb 0.8' looks about twice as
bright as 'rgb 0.4', and this is what people are accustomed to. Likewise
linear color gradients in POV-Ray 3.6 (which, as said, simply map
directly to pixel values) happen to be close to to perceived linear
brightness, which is also what people are accustomed to.
  "You don't specify perceived brightness anymore, but absolute brightness"
is a rather radical change, and many people will get confused by it,
especially since in most systems (at least those with a gamma of 2.2)
raw pixel values map almost linearly to perceived brightness.
Date: 22 Dec 2010 08:54:12
Message: <4d120304$1@news.povray.org>
Just tell them to use the srgb keyword, as it uses the same colour space
as the web, MS Office, Paint etc.  rgb should be reserved for use only
when you need to specify the absolute physical brightness.  I can fully
imagine that later on srgb will become more commonly used and then we'll
have questions like "what is the rgb keyword for?".
Date: 22 Dec 2010 13:34:07
Message: <4d12449f@news.povray.org>
>"Warp"  schreef in bericht news:4d10761e@news.povray.org...
>The problem with the current pov3.7 is that such a gradient is not
>looking even close to linear, even with monitors where 'rgb 0.5' is
>truly 50% bright, as compared to a test pattern. I don't know why this
>is so, but it just isn't.
I'm curious Warp. I've shrunk the file you made yourself for the thread
'More Gamma Again' in p.b.i to a very small one. Now you don't have
to see through your eyelids but can simple look at it. For me the 3.6
side is lineair and the 3.7 side absolutely not. How looks this stamp
on your monitor now?
Don't say it's the thrinking technic, because for me it's absolutely
the same for the big and the small one.
If you have windows 7, than put the file on your monitor and you
automatically get a stamp as icon.
Can everybody react on this with which side is for them the right
one, because I'm under the impression that more people see
what I see.
Thanks in advance,
Jaap Frank
Download 'gradient_10_pov.png' (4 KB) Download 'gradient_pov_mini.png' (1 KB)
Preview of image 'gradient_10_pov.png'
Preview of image 'gradient_pov_mini.png'
Date: 22 Dec 2010 13:39:21
Message: <4d1245d9$1@news.povray.org>
>"Jaap Frank"  schreef in bericht news:4d12449f@news.povray.org...
This should have been:
If you have windows 7, than put the file on your DESKTOP and you
Sorry,
Jaap Frank
