POV-Ray : Newsgroups : povray.beta-test : Optional way to handle #include files? Server Time
25 Apr 2026 21:43:04 EDT (-0400)
  Optional way to handle #include files? (Message 11 to 18 of 18)
Subject: Re: Optional way to handle #include files?
Date: 30 Jul 2010 04:40:41
Message: <4c529009@news.povray.org>
Le_Forgeron <jgr### [at] freefr> wrote:
> And there is "cheating code" (but which I believe is still ok) like
> // file macro_begin.inc
> #macro Warp_Is_Great(a,n)
> sphere { .... }
> #include "macro_end.inc"
> //continue with scene description
> // file macro_end.inc"
> torus { .... }
> #end
> How would you cache that ? (and it can even be more trickier)
> Sometime tricky code is useful.
  The possibility of having part of the macro's body in a different file
(the macro definition block doesn't even need to be split into two files
as in your example, it's enough to simply have part of the macro's body
in a different file, inserted in the macro with an #include) makes the
caching slightly more complicated because "#include" needs to be handled
in a special way. In other words the "#include" command itself cannot be
cached, but instead it has to be interpreted while caching (so that what
ends up in the cache is not the "#include" command, but what it brings
to the macro definition). I don't see this is impossible.
  (Another option is that while transferring the macro to the memory
cache, if an "#include" is found, the macro is then marked as "uncacheable"
and then handled as macros are currently handled. The advantage of supporting
this is that if some other "trick" is later discovered which messes up with
the caching, the same solution can be used to fix the problem: If the problem
is found while caching, simply discard the caching of that macro and mark it
as "uncacheable".)
> Macro and loop came handy to avoid that.
> If you want to make cached macro, may I suggest you use some new keyword
> like #inline, with the added constraints that the end of the #inline
> must be in the same file as its beginning, and probably that you cannot
> redefined an already defined #inline.
  It's perfectly possible to detect, while parsing the macro, if it has
been split into more than one file, so the caching/non-caching can be
automatized. No need to introduce new keywords and functionalities into
the SDL.
Date: 31 Jul 2010 05:00:01
Message: <web.4c53e5082fe4fe04c0721a1d0@news.povray.org>
Thorsten Froehlich <tho### [at] trfde> wrote:
> The suggestion of caching include files comes up every now and then. The
> issue is that there is no way to determine if an include file is modified by
> some other file. The only always reliable way to determine this is by
> parsing the scene, defeating any optimization on parsing.
>  Thorsten
Personally I see no reason why POV-Ray would expect the include file to be
changed. It could read the file and subsequently read from the cache.
Alternatively one could indicate that the file doesn't change between reads and
that it's safe to read from the cache by including "static":
    #include "doesntchange.inc"  static
    #include "maychange.inc"
Date: 31 Jul 2010 19:06:48
Message: <4c54ac88@news.povray.org>
Le_Forgeron wrote:
> Now, what is the point of optimising the parser when the actual work of
> rendering the picture might take hours, days or weeks ?
It's not the parsing speed of the final render, it's all the previewing
and tweaking it takes to get there.
> If you really wants performance, a single file with a copy of the needed
> macros (or even better, no macro call at all) is all you need.
I've copied macros and functions from other files into my main include,
and that it seems to have sped things up considerably.
Date: 31 Jul 2010 19:09:21
Message: <4c54ad21$1@news.povray.org>
Christian Froeschlin wrote:
> stbenge wrote:
>>  #include  "transforms.inc"  into_scene
> I'd support the feature request that include handling
> should be more efficient but without special syntax.
> After all, once you have implemented the functionality
> there is no need to have slow includes anymore. There
> might be some additional memory use for the include
> files but it should be manageable.
But if the implementation increases memory usage, it would become a
problem for some scenes (especially if you're like me and only have a
measly 2GBs of RAM).
Date: 31 Jul 2010 19:14:03
Message: <4c54ae3b$1@news.povray.org>
Chris Cason wrote:
> We could I suppose have a "fast_macro" keyword which is explicitly defined
> as being cached in memory. But none of us have the time to write this ATM.
Something like that would be great, mainly if you could mark *any* macro
as being a fast_macro, so that official macros could be used in this
manner without editing the includes files they come from.
Date: 1 Aug 2010 07:58:53
Message: <4c55617d$1@news.povray.org>
Am 01.08.2010 01:14, schrieb stbenge:
>> defined
>> ATM.
Good point.
So maybe a suitable syntax would be:
     #macro Foo(...)
     #fast_macro Foo
where "#fast_macro IDENTIFIER" would cause the parser to retrieve the
specified macro into memory.
I'd also suggest not to store the content of the macro literally, but
rather in an already tokenized form, as I guess this would speed up
things even a bit more.
BTW, when revisiting macro syntax, I think it would be a good idea to
also introduce "local" macros, in analogy to local variables. But that's
another story.
Date: 2 Aug 2010 04:09:13
Message: <Xns9DC86747B136Dseed7@news.povray.org>
in news:4c527665$1@news.povray.org Chris Cason wrote:
> defined as being cached in memory.
currently we have #include "mannequin.inc"
how about
#from "mannequin.inc" include Hand
or even
#from "mannequin.inc" include Hand #as MyHand
in the last case you could make a fast hardcopy of the macro / function
/ object and still be able to modify the original Hand of mannequin.inc
and and (re)use that in you scene using "#from "mannequin.inc" include
Hand"
... to that add namespaces to avoid collisions and do,
mannequin.Hand( , , )
but then we are realy into POV4.0
ingo
Date: 2 Aug 2010 07:50:03
Message: <4c56b0eb@news.povray.org>
>      #macro Foo(...)
>      #end
>      #fast_macro Foo
  Maybe I'm being stubborn here, but I still can't understand the need
for such a keyword. What would be the problem in *always* having all
macros as "fast"?
  This going towards a byte-compiled VM (much like the user-defined
functions), which is what has been the suggestion for POV-Ray 4 for
a long time...
