POV-Ray : Newsgroups : povray.beta-test : How do we want photons { pass_through } to work? Server Time
11 Jun 2026 22:41:15 EDT (-0400)
  How do we want photons { pass_through } to work? (Message 1 to 8 of 8)
Subject: How do we want photons { pass_through } to work?
Date: 2 Apr 2010 14:42:16
Message: <4bb63a88$1@news.povray.org>
First, here's bad news:
We have a bug in photons { pass_through }.
The current implementation mechanism is (and apparently has always been)
causing an "amplification" effect on photons. See
http://bugs.povray.org/task/93 for an example scene.
Then, there's good news:
I located the error.
There is a piece of code in PhotonTrace::ComputeLightedTexture that
causes pass_through objects to *both* let the photon pass unaffected
*and* have a clone of it pass trough it with all effects - transmit &
filter attenuation, reflection & refraction - the whole smash.
Duh!
Question is, how to fix this thing? Do we just want to suppress
reflection & refraction but do transmit & filter attenuation? That would
be my favorite, though according to the documentation only media-based
attenuation should occur.
Subject: Re: How do we want photons { pass_through } to work?
Date: 2 Apr 2010 17:55:01
Message: <web.4bb6677d910f6b384833458a0@news.povray.org>
> Duh!
I suspect people may have been using this for an artistic effect to date, so I'm
in favor of throwing an optional parameter to pass_through:
Omitted/"double": Current effect.
"transmit"/"filter": Proposed effect; suppresses only reflection/refraction.
"media": Suppresses all non-media attenuation.
At least, if doing it this way wouldn't make things more complicated than it's
worth.
Date: 2 Apr 2010 18:11:21
Message: <4bb66b89$1@news.povray.org>
> Duh!
When I add pass_through, I expect the object to have no effect on the
photons, but I like your suggestion of allowing filter and transmit to
affect the result.
With your suggestion, if there is something looking like a stained
glass, or similar, in the way of the incoming light, you'll get all the
effect of it, without having to compute photons for areas that only get
affected by that filtering object.
If you go that way, the documentations will have to be changed to match
that behaviour.
Date: 2 Apr 2010 18:21:40
Message: <4bb66df4$1@news.povray.org>
Am 02.04.2010 23:54, schrieb MDenham:
No, it's definitely broken. If backward compatibility is really a
concern, the policy would be to fall back to the current behavior when
#version 3.6 (or earlier) is specified, while providing no way of
"resurrecting" this bug for non-legacy scenes. This way, some versions
later the bug can be fully removed from the code.
Date: 2 Apr 2010 18:32:49
Message: <4bb67091$1@news.povray.org>
Am 03.04.2010 00:11, schrieb Alain:
Yup, that's exactly why I favor it. I think it is a good deal more
useful than just making it fully neutral to photons altogether - and if
that functionality should still be desired, I'd personally prefer the
keyword to fit into the "no_something" group, i.e. "no_photons".
> that behaviour.
Definitely so. But I'd even volunteer to change it if that helps my
cause :-P
Date: 4 Apr 2010 10:25:42
Message: <4bb8a166@news.povray.org>
> photons
  If I understand correctly, the object's *surface* has no effect on the
photons when 'pass_through' is specified, but if the object has media and
the photons are set up to interact with it, then they will become visible
in the media.
  Well, at least that's how it works in the simple media tutorial I wrote
for the docs. However, I have later noticed that photons often behave
inconsistently with regard to this.
  It's also confusing. Maybe a clearer syntax for different interactions
should be devised.
Date: 5 Apr 2010 12:31:58
Message: <4bba107e$1@news.povray.org>
clipka wrote:
> and if  that functionality should still be desired, I'd personally prefer
> the  keyword to fit into the "no_something" group, i.e. "no_photons".
I think pass_through was originally intended to be the photon
equivalent of "no_shadow" (considering the latter automatically
avtivates the first). If you think of this in the sense of light
(fakedly) passing through a solid (non-transparent) object it
certainly makes sense that transmit was ignored.
My guess would be that removing the undocumented clone photon
would have less impact on existing scenes than changing the
documented shadowing behavior.
But if it is changed as you suggested here, then I'd vote for
having "no_photons" as a replacement. Also, "pass_through" should
then be decoupled from "no_shadow" as they will no longer be
closely related. And I don't think "no_shadow" should imply
"no_photons" either, that just creates confusion.
BTW, another confusing aspect of pass_through is that it only
has an effect prior to hitting the photon target. At least for
a new no_photons keyword I'd suggest to make no distinction
there if technically possible.
Date: 5 Apr 2010 13:09:15
Message: <4bba193b@news.povray.org>
Am 05.04.2010 18:35, schrieb Christian Froeschlin:
It definitely is possible.
