POV-Ray : Newsgroups : povray.beta-test : thread count rendertimes unpredictable? Server Time
16 Feb 2026 20:31:22 EST (-0500)
  thread count rendertimes unpredictable? (Message 1 to 10 of 18)
Subject: thread count rendertimes unpredictable?
Date: 18 Jan 2009 19:27:35
Message: <4973c8f7$1@news.povray.org>
I was comparing beta 30 and the radiosity-changed exe for any differences
when using thread count 1 or 2 and found it varies depending on scene file
complexity or animations. I was wondering if thread count was being checked
by others.
Getting a 160% slower render sometimes when using Work_Threads=2 versus 1,
and other times 60% (much faster). In the past I had been making sure to
keep the threads at only 1 so renders wouldn't slow down on larger sized
images or animations. I think there might have been a change but couldn't be
sure about that.
Right now it seems to be unpredictable instead of guaranteeing a speed-up by
going with more than 1 thread. Thought maybe this hasn't been discussed
recently so wanted to bring it up again.
POV for Windows (SSE2's and non-SSE2's), Vista and AMD X2 dual core
Subject: Re: thread count rendertimes unpredictable?
Date: 18 Jan 2009 19:42:24
Message: <9E363925719942B18BA14BF08FF37968@HomePC>
Could you post what times you get with specific scenes?
...Ben Chambers
www.pacificwebguy.com
Date: 19 Jan 2009 04:36:31
Message: <4974499f$1@news.povray.org>
"Chambers" <ben### [at] pacificwebguycom> wrote in message
news:9E363925719942B18BA14BF08FF37968@HomePC...
I hadn't checked any of the sample files before posting until now so I gave
the scenes\advanced\benchmark.pov a try and found the render times to be
like I would expect. Using 1 thread was slower at 26 minutes, while 2
threads improves that to about 14 minutes; both SSE2's I tested it in, while
non-SSE2 is similar yet slower overall of course.
A curiosity to me was how photons are reported, saying 5 threads, although I
understand this isn't finished yet but since the file had it on I left it
as-is. I didn't use radiosity at all. Here's one of the render time stats:
  Photon Time:      0 hours 11 minutes 11 seconds (671.876 seconds)
              using 5 thread(s) with 1028.810 CPU-seconds total
  Radiosity Time:   No radiosity
  Trace Time:       0 hours 13 minutes 31 seconds (811.406 seconds)
              using 2 thread(s) with 1578.745 CPU-seconds total
Looking more at the stats I've realized something is probably wrong about
Max Level, it was saying the output image resolution (same width, height
numbers). Don't know if that's just incorrect or really happening in the
render but it's only when setting Work_Threads=2 not =1, only the
*radiosity-changed* executable does this-- not the original beta 30.
If I find an included scene file which causes the huge render-time
difference I will post back about it.
For at least one of my own files (actually a pov with collection of .inc's)
the render-time differences can be incredible, at the same output image
resolution just over 12 minutes using 1 thread in pvengine-sse2.exe, and
about 96 minutes using 2 threads in pvengine32-sse2.exe (pvengine-sse2.exe
beta 30 was 6 minutes faster, or 90 minutes, for whatever reason).
My guess was perhaps the splines causing trouble but since I haven't a clue
how thread count can affect object types being rendered (rather vice versa)
I can't really say what's going on. I don't understand the processes
involved.
Here's stats when rendering one of my own pov files:
_____________________________________________________________________________
begin stats for pvengine-sse2 beta 30 1 thread
Finite Objects:         7474
Infinite Objects:          0
Light Sources:             2
Total:                  7476
Parser Time
  Parse Time:       0 hours  0 minutes  0 seconds (0.000 seconds)
              using 1 thread(s) with 1.934 CPU-seconds total
  Bounding Time:    0 hours  0 minutes  0 seconds (0.047 seconds)
              using 1 thread(s) with 0.046 CPU-seconds total
Render Options
  Quality:  9
  Bounding boxes.......On   Bounding threshold: 3
  Antialiasing.........On  (Method 1, Threshold 0.400, Depth 2, Jitter Off)
Render Statistics
Image Resolution 1600 x 1200
Pixels:          2040800   Samples:         4629652   Smpls/Pxl: 2.27
Rays:           12772602   Saved:           1587744   Max Level: 9/9
Ray->Shape Intersection          Tests       Succeeded  Percentage
Blob                            200144           35757     17.87
Blob Component                  167655           84980     50.69
Blob Bound                      800576          167655     20.94
Box                             895707          888096     99.15
Cone/Cylinder                 10696292         9385215     87.74
CSG Intersection                 10395             132      1.27
CSG Union                       462067          174964     37.87
Polygon                         143850           62685     43.58
Sphere                          505290          382893     75.78
Sphere Sweep                  18753062          540509      2.88
Surface of Revolution           355109          187896     52.91
Surface of Rev. Bound           355109          291122     81.98
Torus                           190213          103812     54.58
Torus Bound                     190213          104002     54.68
True Type Font                  817186          213488     26.12
Clipping Object                 540887          478611     88.49
Bounding Box                2413335789       531789506     22.04
Function VM calls:          9498297
Roots tested:              18806406   eliminated:                 1119
Shadow Ray Tests:          10683037   Succeeded:                 47102
Shadow Cache Hits:            40562
Reflected Rays:              168931   Total Internal:             8718
Refracted Rays:              160895
Transmitted Rays:           5772324
Smallest Alloc:                  12 bytes
Largest  Alloc:                  12 bytes
Total Alloc calls:                1         Free calls:       56312792
Render Time:
  Photon Time:      No photons
  Trace Time:       0 hours 12 minutes 21 seconds (741.718 seconds)
              using 1 thread(s) with 739.631 CPU-seconds total
POV-Ray finished
CPU time used: kernel 1.40 seconds, user 744.23 seconds, total 745.64
seconds.
Elapsed time 746.60 seconds.
Render averaged 2571.65 PPS (2574.98 PPS CPU time) over 1920000 pixels.
end stats for pvengine-sse2 beta 30 1 thread
begin stats for pvengine32-sse2 (radiosity-changed) beta 30 2 threads
Infinite Objects:          0
Light Sources:             2
Total:                  7476
Parser Time
              using 1 thread(s) with 1.591 CPU-seconds total
Render Options
  Quality:  9
Render Statistics
Rays:           12772602   Saved:           1587744   Max Level: 1600/1200
True Type Font                  817132          213488     26.13
Bounding Box                2413335438       531789436     22.04
Shadow Cache Hits:            40563
Total Alloc calls:                2         Free calls:       56314983
Render Time:
  Trace Time:       1 hours 36 minutes 33 seconds (5793.391 seconds)
              using 2 thread(s) with 7003.306 CPU-seconds total
POV-Ray finished
CPU time used: kernel 267.56 seconds, user 6745.00 seconds, total 7012.56
seconds.
Elapsed time 5799.85 seconds, CPU vs elapsed time ratio 1.21.
Render averaged 331.04 PPS (273.79 PPS CPU time) over 1920000 pixels.
end stats for pvengine32-sse2 (radiosity-changed) beta 30 2 threads
Date: 19 Jan 2009 14:47:45
Message: <147C633062104D78B2FA2555A7C26198@HomePC>
> -----Original Message-----
> From: Bob Hughes [mailto:omniverse charter net]
> gave
> be
> while
That's about what I would expect going from 1 thread to 2.  The Trace
portion of POV scales extremely well (almost ideally) with adding cores.
> .inc's)
> and
> sse2.exe
Is there any way you could create a minimal scene that demonstrates this
discrepancy?  I'm rather interested in testing it myself, as I haven't
had any such problems.
If you can't minimize the scene, would you consider posting your file,
or a link to it?  I can't guarantee how useful it would be without
knowing how large it is, of course.
...Ben Chambers
A render isn't slow unless it won't finish until after your next
birthday.
Date: 20 Jan 2009 04:37:08
Message: <49759b44$1@news.povray.org>
news:147C633062104D78B2FA2555A7C26198@HomePC...
>> .inc's)
> image
>> and
>> sse2.exe
Hey Ben, thanks for wanting to check on this but I haven't been able to get
anywhere with it yet.
Something I misspoke of before was saying "splines" when I meant
sphere_sweep (using cubic_spline).
I tried a separate test scene file with some objects (sor, blob,
sphere_sweep, text, sphere, cylinder) taken from the original problem
file(s), always renders with a speed-up using 2 threads. I can't seem to
narrow it down to anything but the original render slows considerably at 1/4
to 1/3 into it then remains slow, while the Work_Threads=1 helps it speed
along by comparison.
I still haven't found another file able to cause the same kind of slowdown
so it could be this one particular rendering I kept thinking of as being the
problem when changing thread count, except if one does it I'm sure others
must.
I ran a histogram in 3.6 to see what things would be using the most time
(not able to in 3.7 beta?), sphere_sweep and overlapping cylinders with
gradient pigment (some transparency) look the slowest. Not totally
unexpected at all.
Vista search indexing was all I could think of outside of POV being at
fault. I switched that off and nothing changed.
If I don't get anywhere soon I might email a link, if you wouldn't mind
that. It's a time-line data chart I don't really want out loose on the 'net
because of info used in it that would become outdated. But maybe it doesn't
matter... guess I just can't see posting it due to the specific nature of
it.
Date: 20 Jan 2009 10:10:26
Message: <5AA99CEE980A486397B6F8F3AE9F92A6@HomePC>
> to narrow it down to anything but the original render slows
considerably
> at 1/4 to 1/3 into it then remains slow, while the Work_Threads=1
helps it
> speed along by comparison.
One method I've used is to take a copy of the scene, and try removing
objects / simplifying textures one at a time, until the problem
disappears.  If you can't recreate the problem any other way, this
usually works.
mind
> 'net because of info used in it that would become outdated. But maybe
it
> doesn't matter... guess I just can't see posting it due to the
specific nature
> of it.
That's fine, whatever is appropriate for the data you have.
...Ben Chambers
Date: 21 Jan 2009 07:23:28
Message: <497713c0$1@news.povray.org>
I put the files at http://0mniverse.com/public/37threads2slow.zip so if
anyone else wants to check whether it renders much slower with
Work_Threads=2 in the 3.7 beta they could do so.
When emailing it to Ben I forgot about the clockmod.inc being used and you
would need to get that from http://www.geocities.com/ccolefax/clockmod.html
if you don't have it already. Also not sure about the fonts... everyone
might not have the ones I do and I didn't check which ones I used. If any
errors occur when attempting to render I think switching the fonts for
others shouldn't change rendertime.
You're welcome to use the files in part yourselves if you wish, if sense can
be made of my SDL, I just don't want the whole thing used for what I am
using it for since I'm putting the resultant graph online already. Doubt
that needed to be said...
Date: 21 Jan 2009 22:13:29
Message: <ABFA7CDD4CD84294B7B1B9E3C8A84A19@HomePC>
By the way, I also had to create a dummy file "holiday symbols.inc" for
it to render.
...Ben Chambers
Date: 21 Jan 2009 22:28:51
Message: <3E8BA04547084C94A0AF378EADFB4C29@HomePC>
Using Beta 30 x64, I got 70 seconds with one thread and 34 with two.
Using the sse2 version of the modified executable, I got 72 seconds with
one thread and 76 seconds with two!
Something is definitely going on here... I'll be playing with the scene
file...
...Ben Chambers
Date: 21 Jan 2009 23:16:01
Message: <20CECB82D05043A6B6A700156C442C4B@HomePC>
I don't have more time to work with it today, but I can definitely say
that the effect seen is related to the overlapping graphs and the
background.  Eliminating sets of data or the background both have the
effect of reducing the effect.
...Ben Chambers
