POV-Ray : Newsgroups : povray.beta-test : Sanity test of full installer Server Time
26 Apr 2026 11:33:12 EDT (-0400)
  Sanity test of full installer (Message 11 to 17 of 17)
Subject: Re: Sanity test of full installer - installed OK after uninstall
Date: 7 Jul 2008 06:17:40
Message: <4871ed44$1@news.povray.org>
Bob Hughes wrote:
> somewhere about them going elsewhere now. Perhaps a few months ago I had
> done a beta /install switch, so maybe that's when it started. This folder I
> was never aware of is:
> C:\Users\*name*\AppData\Local\VirtualStore\Program Files\POV-Ray for Windows
> v3.7
I'm not familiar with this path. Certainly, the path itself isn't something
that I have coded explicitly into the app. I suspect it's a Vista 'feature'
related to redirecting modified data out of program files and into a users
local profile. If this is still occurring with the version that comes with
a installer let me know and I'll look up its meaning.
-- Chris
Date: 7 Jul 2008 06:48:50
Message: <4871f492@news.povray.org>
Bob Hughes wrote:
> Got around to removing the beta 27 through Add/Remove Programs (no
> uninstaller for the beta yet?), removed the subfolder out of
that *is* the uninstaller (at least, the 'correct' way of uninstalling). or
you could just run the installer again (not intuitive, but that's MSI's for
you). the use of a stand-alone uninstaller seems to have more or less gone
out of vogue.
> v3.7
http://www.itwriting.com/blog/141-peeking-into-vistas-virtual-store.html
gives some background. the current beta should not write anything to the
program files folder.
-- Chris
Date: 7 Jul 2008 06:56:49
Message: <l3t37493ls5j1e4e9vldrm2krj0632enag@4ax.com>
On Mon, 07 Jul 2008 20:13:09 +1000, Chris Cason
<del### [at] deletethistoopovrayorg> wrote:
>Stephen wrote:
>> Duh! Thanks Chris I forgot about "pvengine.ini". The GUI works now, other than
>> it does not return the rendered image. But that has been the case in all the
>> betas, I have tried, so I assume that you will get round to it when you can.
>I really don't think I'll have time to look into GUIEXT's in the short to
>medium term - the fix is likely to be simple but needs testing (I don't
>have any GUIEXT's installed)
That does not surprise me :)
>Also, the author of at least one GUIEXT has had access to our revision
>control system for more than a year but hasn't had time to fix it either:
>given that, I have taken the approach that the issues with them can't be
>that serious.
The issues are not important and I'm more than willing to put up with having to
Alt-Tab to PovRay to see the rendered image. The speed up using Pov 3.7 is worth
the slight inconvenience.
As an aside the only other inconvenience is, I cannot see the sample images in
the material editor but then I can render them in 3.6.
I do not expect Hugo to waste time on getting the GUIEXT's working for a Beta
Pov when he is trying to prepare his program for its final release.
So no worries, no pressure :)
Keep up the good work.
Regards
Subject: Re: VirtualStore in Vista and file relocation
Date: 7 Jul 2008 15:45:50
Message: <4872726e@news.povray.org>
"Chris Cason" <del### [at] deletethistoopovrayorg> wrote in
message news:4871f492@news.povray.org...
> or
> for
> out of vogue.
I see... ok. This was something in the 3.6 installation so I noticed it
missing from 3.7. And I actually shouldn't have said "Add/Remove", thinking
back to XP there since Vista just calls it Uninstall now (like that matters!
heh).
>> Windows
>> v3.7
Showing my ineptitude by not knowing what all Vista encompasses by now,
having used it for the past 8 months. Apparently I can set POV to Run as
Administrator and bypass the VirtualStore "feature". I wasn't before now
simply because all appeared to be correct with both 3.6 and 3.7 beta.
Interestingly, there's only a biscuit.bmp in a 3.6 scenes\advanced subfolder
there. However, 3.6 obviously caused Vista to put something there for it
too.
Speaking of the scenes folder... realizing the 3.7 beta is putting one into
the other path at
C:\Users\*name*\AppData\roaming\POV-Ray for Windows v3.7
and none into the usual place at
C:\Program Files\POV-Ray for Windows v3.7
I guess the confusing thing for me is how that, together with the other
potential file placement above, will affect things. Would it be possible to
have the installer ask to create a location for scene files? Maybe default
to C:\Scenes\ and likewise for a file output location, such as
C:\Renderings\ while I'm on the subject of default file locations.
The way the new beta installer does things has probably been planned awhile
and I'm just wondering if this was all thought about already-- or if the
Vista OS is causing some extra complications to arise.
Only now read a little more about VirtualStore... it's mentioned it might
not always exist in the future.
http://msdn.microsoft.com/en-us/library/bb530198.aspx
/*bob hughes*/
Date: 7 Jul 2008 17:40:06
Message: <48728d36$1@news.povray.org>
> out of vogue.
I didn't yet look at beta 27, but not having a stand-alone uninstaller
is different from not providing an uninstall link, which would probably
just have to be something like "[systemdir]msiexec /x {productcode}"
Date: 7 Jul 2008 17:47:32
Message: <48728ef4@news.povray.org>
> subfolder there.
Probably the only sample scene you actually rendered
with 3.6 on Vista without administrator privileges.
> into the other path at
That is actually the intended solution of the Vista problems:
Install ini and scene files where the user is allowed to write
in the first place, then you need no virtual store.
Date: 13 Jul 2008 01:20:01
Message: <web.48799026796ddd41d57798c90@news.povray.org>
Chris Cason <del### [at] deletethistoopovrayorg> wrote:
> I was able to install under Vista as an ordinary user (no admin). I had to
> choose a different install path, and also had to click to ignore several
> errors during install (where the installer attempts to do things like set
> admin keys or install fonts - none of these are essential). No registry
> editing was needed to get the installed program to work. I'm not sure what
> went awry in your case.
So, I tried to install it using the default location (Program Files).  I get a
permission error when it tries to copy the files (can't write to the
directory). I don't get the usual UAC prompt like I do installing other
programs.  I would assume that coping the files would be done by elevating to
Administrator or SYSTEM privs first, but I have the feeling it is trying to
copy the files as the local user instead.  That probably also explains the
other errors you get (normal user can't muck with those either).
