POV-Ray : Newsgroups : povray.beta-test : Long parse time Server Time
17 Feb 2026 13:06:05 EST (-0500)
  Long parse time (Message 1 to 10 of 11)
Subject: Long parse time
Date: 11 Feb 2004 15:40:13
Message: <402a932d$1@news.povray.org>
I have a somewhat complex scene which gives me strange parsing
times on different computers :
  Athlon 1333 Mhz - Win 2000 - 512 Mb
   POV 3.5 : 23 seconds
   POV 3.6 : 44 seconds
   Intel P4 2.8 Mhz - Win XP - 512 Mb
   POV 3.5 : 18 seconds
   POV 3.6 : 55 seconds
The scene contains CSG, many macros, several big meshes, a big
image_map, #reads a big file.  It does NOT contain photons,
isosurfaces, HF...
Rendering time seems normal (though I didn't compare accurately).
Does anyone noticed similar behaviour ?
Fabien.
Subject: Re: Long parse time
Date: 12 Feb 2004 11:59:53
Message: <Xns948DB71585AF5seed7@news.povray.org>
Yes, I noticed using my mesh generation include files. The use loops and
functions a lot.
Ingo
Date: 15 Feb 2004 14:54:38
Message: <402fce7e@news.povray.org>
news:402a932d$1@news.povray.org...
I just observed a similar behaviour - worse in fact. With a scene containing
essentially big meshes (mesh2):
POV-Ray 3.5 - parsing 65 s
POV-Ray 3.6b1 - parsing 149 s
With one mesh (#include only, about 400000 tokens): 19 seconds in 3.6b1 vs 8
seconds with 3.5.
Intel P4 1.7Gz, Windows XP HE SP1, 1GB RAM.
G.
http://www.oyonale.com
- Graphic experiments
- Posters
Date: 15 Feb 2004 15:44:13
Message: <402fda1d$1@news.povray.org>
In addition to meshes, a simple loop causes it too.
#declare i=0;
#while (i<100000)
    sphere{0,1 translate x*i*2 pigment{rgb x}}
    #declare i=i+1;
Takes 19s with 3.6b1, 8s with 3.5
G.
- Posters
Date: 15 Feb 2004 16:04:58
Message: <402fdefa@news.povray.org>
An early pre-beta version of 3.5 had a similar problem and it was caused
by it using C++ streams to read the input. When they were changed to
C streams the speeds went back to the 3.1 speeds.
  I wonder if the reason is the same now...
Date: 15 Feb 2004 16:08:04
Message: <r035g1-jco.ln1@triton.imagico.de>
Gilles Tran wrote:
> #declare i=0;
> #while (i<100000)
>     #declare i=i+1;
> #end
I did a quick test here on Linux and it parses in ~31s on 3.5 and 21s on
3.6 here, that difference is at least partly due to different
optimizations - i assume the same for your 3.5/3.6 difference observation.
Last updated 11 Jan. 2004 _____./\/^>_*_<^\/\.______
Date: 15 Feb 2004 16:22:30
Message: <402fe316$1@news.povray.org>
In article <402fdefa@news.povray.org> , Warp <war### [at] tagpovrayorg>  wrote:
No.
    Thorsten
e-mail: tho### [at] trfde
Date: 15 Feb 2004 16:30:36
Message: <402fe4fc$1@news.povray.org>
news:r03### [at] tritonimagicode...
Perhaps someone on a non-Windows platform should test the mesh parsing too.
If you haven't one I can see if I can put one for download.
Actually I'm back to 3.1 as far as parsing time is concerned :D
I should add that this seems to affect only the parsing time, not the render
time. I noticed that it's a different compiler too.
G.
- Posters
Date: 15 Feb 2004 17:10:03
Message: <im65g1-ef8.ln1@triton.imagico.de>
Mesh parsing is about the same here as the loop, i only tested a very
small mesh that only took about 5 seconds so it is not very accurate but
3.6 is slightly faster than 3.5.
3.1 is indeed much faster for the loop here as well (the mesh was a
mesh2 so i could not test it), but the changes from 3.1 to 3.5 were
fairly large so this is quite understandable (more features -> slower
parsing).
You could try Megapov 0.7 and Megapov 1.0 in comparison.  You should
also notice that with parsing times of only a few seconds you should
always run the test several times because speed of file access will
strongly vary.
Date: 15 Feb 2004 22:06:30
Message: <403033b6$1@news.povray.org>
Program ended abnormally on 15/02/2004 15:44, Due to a catastrophic Gilles Tran
error:
> #declare i=0;
> #while (i<100000)
>     #declare i=i+1;
> #end
> G.
I figured that on a slower machine, the difference would be more noticeable,
Version:	Parse times:
POV 3.1:		19s.
MegaPOV 0.7:		20s.
POV 3.5 (ICL):		17s.
MegaPOV 1.0 (MSVC):	20s.
POV 3.6 (beta1):	28s.
I noticed that 3.6 updates the status line while parsing this scene while
previous versions only had a "parsing..." message, maybe the added calculations
and time spent updating the status line have something to do with it.
