in news:402a932d$1@news.povray.org Fabien Mosen wrote:
> Does anyone noticed similar behaviour ?
Yes, I noticed using my mesh generation include files. The use loops and
functions a lot.
Ingo
news:402a932d$1@news.povray.org...
> I have a somewhat complex scene which gives me strange parsing
> times on different computers :
I just observed a similar behaviour - worse in fact. With a scene containing
essentially big meshes (mesh2):
POV-Ray 3.5 - parsing 65 s
POV-Ray 3.6b1 - parsing 149 s
With one mesh (#include only, about 400000 tokens): 19 seconds in 3.6b1 vs 8
seconds with 3.5.
Intel P4 1.7Gz, Windows XP HE SP1, 1GB RAM.
G.
http://www.oyonale.com
- Graphic experiments
- Posters
In addition to meshes, a simple loop causes it too.
#declare i=0;
#while (i<100000)
sphere{0,1 translate x*i*2 pigment{rgb x}}
#declare i=i+1;
Takes 19s with 3.6b1, 8s with 3.5
G.
- Posters
An early pre-beta version of 3.5 had a similar problem and it was caused
by it using C++ streams to read the input. When they were changed to
C streams the speeds went back to the 3.1 speeds.
I wonder if the reason is the same now...
<1,1,3>hollow}text{ttf"timrom""Warp".1,0translate<-1,-.1,2>}// - Warp -
Gilles Tran wrote:
> #declare i=0;
> #while (i<100000)
> #declare i=i+1;
> #end
I did a quick test here on Linux and it parses in ~31s on 3.5 and 21s on
3.6 here, that difference is at least partly due to different
optimizations - i assume the same for your 3.5/3.6 difference observation.
Last updated 11 Jan. 2004 _____./\/^>_*_<^\/\.______
In article <402fdefa@news.povray.org> , Warp <war### [at] tag povray org> wrote:
No.
Thorsten
e-mail: tho### [at] trf de
news:r03### [at] triton imagico de...
Perhaps someone on a non-Windows platform should test the mesh parsing too.
If you haven't one I can see if I can put one for download.
Actually I'm back to 3.1 as far as parsing time is concerned :D
I should add that this seems to affect only the parsing time, not the render
time. I noticed that it's a different compiler too.
G.
- Posters
Mesh parsing is about the same here as the loop, i only tested a very
small mesh that only took about 5 seconds so it is not very accurate but
3.6 is slightly faster than 3.5.
3.1 is indeed much faster for the loop here as well (the mesh was a
mesh2 so i could not test it), but the changes from 3.1 to 3.5 were
fairly large so this is quite understandable (more features -> slower
parsing).
You could try Megapov 0.7 and Megapov 1.0 in comparison. You should
also notice that with parsing times of only a few seconds you should
always run the test several times because speed of file access will
strongly vary.
Program ended abnormally on 15/02/2004 15:44, Due to a catastrophic Gilles Tran
error:
> #declare i=0;
> #while (i<100000)
> #declare i=i+1;
> #end
> G.
I figured that on a slower machine, the difference would be more noticeable,
Version: Parse times:
POV 3.1: 19s.
MegaPOV 0.7: 20s.
POV 3.5 (ICL): 17s.
MegaPOV 1.0 (MSVC): 20s.
POV 3.6 (beta1): 28s.
I noticed that 3.6 updates the status line while parsing this scene while
previous versions only had a "parsing..." message, maybe the added calculations
and time spent updating the status line have something to do with it.
/* flabreque */L)polygon{5,F,F+z,L+z,L,F pigment{rgb 9}}#end union
/* @ */{P(0,a)P(a,b)P(b,c)P(2*a,2*b)P(2*b,b+c)P(b+c,<2,3>)
/* videotron.ca */}camera{orthographic location<6,1.25,-6>look_at a }
Program ended abnormally on 15/02/2004 22:00, Due to a catastrophic Francois
Labreque error:
> Gilles Tran error:
>> #declare i=0;
>> #while (i<100000)
>> #declare i=i+1;
>> #end
>> G.
> noticeable,
> POV 3.1: 19s.
> MegaPOV 0.7: 20s.
> POV 3.5 (ICL): 17s.
> while previous versions only had a "parsing..." message, maybe the added
> calculations and time spent updating the status line have something to
> do with it.
Oops! I should have added my machine's specs.
AMD Athlon 650 MHz. 512MB RAM. Win98SE.
BTW, sorry about the messed up table. It seems Mozilla has issues with the TAB key.
