POV-Ray : Newsgroups : povray.beta-test.binaries : Re: radiosity nag. Server Time
19 May 2024 15:24:44 EDT (-0400)
  Re: radiosity nag. (Message 11 to 16 of 16)
Subject: Re: radiosity nag.
Date: 6 Jun 2004 12:35:01
Message: <web.40c346e89346345c307441310@news.povray.org>
"Thorsten Froehlich" <tho### [at] trfde> wrote:
> In article <c9vdmc$64c$1@chho.imagico.de> , Christoph Hormann
> <chr### [at] gmxde>  wrote:
> > I really can't see a reason why one would try to use something like
> I guess it is some program generating this output.  As you apparently have
> both 3.5 and 3.6 running, could you try to comment out one of the parameters
> until you find the one interpreted differently?
>     Thorsten
> ____________________________________________________
> Thorsten Froehlich, Duisburg, Germany
> e-mail: tho### [at] trfde
> Visit POV-Ray on the web: http://mac.povray.org
I'll try later this week, I'm currently working nightshift, and
today we start at 2000, so I won't get out of bed until 1300 or so..
Terribly sorry!
                               Greetings from the Swedish summer
                               (not a polarbear in sight ;)
Date: 6 Jun 2004 14:25:34
Message: <40c3619e@news.povray.org>
In article <web.40c346e89346345c307441310@news.povray.org> , "fomhorian"
>>     Thorsten
> Terribly sorry!
My reply was to Christoph.  Nothing for you to worry about :-)
    Thorsten
Date: 6 Jun 2004 15:11:49
Message: <40c36c75$1@news.povray.org>
In article <c9vgh2$6vg$1@chho.imagico.de> , Christoph Hormann
> It seems to be the reflection 'exponent sqrt(2)'.
OK, so in conclusion that setting should be changed in fomhorian's scene and
it will work.
> Note i also get
> occasional render freezes (i.e. the render halts and the program can
> only be stopped by multiple CTRL-Cs) in 3.6 when using the fresnel
> reflection.
Sounds like stack overflows.  I will need to take a look at the fresnel
implementation to find out what that happens.
>  Since i never had any problems with fresnel reflection
> before i assume this is something specific to this scene (i.e. the
> mesh).  Lowering max_trace_level strongly or not using radiosity avoids
> this (so maybe the ray recursion handling of radiosity in combination
> with reflection does not work properly although i have rendered a lot of
> scenes with radiosity + reflection without problems).
OK, if you find some time, take a look.  Otherwsie, we won't bother for 3.6.
    Thorsten
Date: 6 Jun 2004 20:08:59
Message: <40c3b21b@news.povray.org>
news:c9vgh2$6vg$1@chho.imagico.de...
> It seems to be the reflection 'exponent sqrt(2)'.  Note i also get
> reflection.
For the record, I also observed an extremely nasty combination of mesh,
radiosity, reflection and prism (!), generating large black artifacts where
3.5 performed OK. Unfortunately I wasn't able to replicate it using a
smaller scene (the scene I used is around 50-100 Mb), so I couldn't report
it. But something is definitely lurking out there...
G.
http://www.oyonale.com
- Graphic experiments
- Posters
Date: 7 Jun 2004 07:45:00
Message: <web.40c454319346345cd1180cec0@news.povray.org>
> reflection.    Since i never had any problems with fresnel reflection
> Christoph
> POV-Ray tutorials, include files, Sim-POV,
> HCR-Edit and more: http://www.tu-bs.de/~y0013390/
> Last updated 01 May. 2004 _____.//^>_*_<^/.______
Good morning folks!
Yes I too boiled it down to the 'exponent sqrt(2)'. the scene looks
fine as long as I use an exponent <= 1.0 in POVRay 3.6 .
Freezez? No, haven't come across those...
Download 'stormer_pov36_exponent1.jpg' (63 KB)
Preview of image 'stormer_pov36_exponent1.jpg'
Date: 7 Jun 2004 08:20:01
Message: <web.40c45c2f9346345cd1180cec0@news.povray.org>
A small addendum here:
I did the same scene with sphere{}, and other basic POVRay
objects, and fresnel exponent 1.5 and got the same strange result.
So it is not my mesh...
Oh:
>You don't seriously want to call that minimal, do you?
When I started with POVRay back in 1999 on my Pentium 75mhz
and DOS; I had meshes, in smooth_triangle, up to 35 megs!
Imagine the loading-time for those ;)
                              ..And I'm off for breakfast..
