POV-Ray : Newsgroups : povray.beta-test.binaries : Re: radiosity nag. Server Time
14 Jun 2024 23:00:41 EDT (-0400)
  Re: radiosity nag. (Message 1 to 10 of 16)
Subject: Re: radiosity nag.
Date: 6 Jun 2004 07:10:01
Message: <web.40c2fb019346345c307441310@news.povray.org>
"Thorsten Froehlich" <tho### [at] trfde> wrote:
> Looking at the render of the scene you provided, I cannot see anything
> wrong.  What wrong output should one expect to see in the scene you posted?
>     Thorsten
Well; in comparison to the image traced by POVRay 3.5, also posted
to this board, I have this big black blotch in the center of my
image :( I tried to up the quality today to see if it was that
which caused the effect, but as you can see it actually got
worse, in my opinion that is, with the blackness almost totally
covering the ship! And no, I didn't get any kind of error-messages.
Download 'povmessagepane.txt' (3 KB)
Date: 6 Jun 2004 07:20:02
Message: <c9uuep$ih1$1@chho.imagico.de>
The scene you posted renders the same in 3.5 and 3.6 here.  No 'ship' is
visible at all.  You will need to post a scene and images showing the
difference with *exactly* this scene for being of any use to trace down
a possible problem.
Last updated 01 May. 2004 _____./\/^>_*_<^\/\.______
Date: 6 Jun 2004 09:45:01
Message: <web.40c31ee49346345c307441310@news.povray.org>
> a possible problem.
> Christoph
I did and I have! I put both a POVRay 3.5 and a POVRay 3.6 version
of the e x a c t same scene on this board. I also put the scene without
the mesh here, check both beta-test and beta-test.binaries.
Date: 6 Jun 2004 10:26:37
Message: <40c3299d@news.povray.org>
In article <web.40c31ee49346345c307441310@news.povray.org> , "fomhorian"
You don't understand.  Beta or not, we need a *complete* but minimal scene
to reproduce the problem.  The information needed to reproduce a problem is
outlined in:
Newsgroups: povray.announce.frequently-asked-questions
Subject: bug reporting
Date: Wed, 10 Jul 2002 20:32:49 -0700
Message-ID: <fpupiu02i1198jbb38i3o06hv6is1a3uar@4ax.com>
Xref: news.povray.org povray.announce.frequently-asked-questions:50
<http://news.povray.org/fpupiu02i1198jbb38i3o06hv6is1a3uar%404ax.com>
Without a complete and minimal scene, we will not be able to reproduce your
problem and thus will not be able to help you!
    Thorsten
PS: Please note that the final release of POV-Ray 3.6 will be in less than
48 hours, so should this really be a problem in POV-Ray and not in your
scene, we will need your complete but minimal scene *soon*.  Thus, arguing
with us about the information you provided makes it more likely you will
have to wait many month for the problem to be corrected, should it indeed be
in POV-Ray and not in your scene.
e-mail: tho### [at] trfde
Date: 6 Jun 2004 10:35:02
Message: <c9v9qr$lcr$1@chho.imagico.de>
>>a possible problem.
There is nothing in your postings that enables us to reproduce your
problem.  Without this you can't expect anyone to be able to explain the
difference you observe.
Date: 6 Jun 2004 11:15:01
Message: <web.40c333e09346345c307441310@news.povray.org>
Okidoki, but I don't know if it is that small...
Download 'stormer.pov.txt' (386 KB)
Date: 6 Jun 2004 11:40:02
Message: <c9vdmc$64c$1@chho.imagico.de>
You don't seriously want to call that minimal, do you?
The most likely explanation of the difference you observe is that one of
your extremely ugly finish parameters is interpreted differently in 3.6
as a side effect of another change.  When i remove all those finishes
the results i get in 3.5 and 3.6 are idetical.
I really can't see a reason why one would try to use something like
       finish{
         ambient  0.05
         diffuse 0.4
         brilliance 2.5
         metallic 1.5
         specular 2 roughness 0.05
         phong 0.5 phong_size 30
         reflection{
          <0,1,0.5>*0.005,0.05
          metallic 0.25
          fresnel on
           falloff 0.5
           exponent sqrt(2)
Date: 6 Jun 2004 11:48:42
Message: <40c33cda@news.povray.org>
In article <c9vdmc$64c$1@chho.imagico.de> , Christoph Hormann
Well, the point is not if they are ugly but if they are valid.  We should
try to figure out which change causes this and maybe issue an error if any
of the specified parameters is outside valid bounds (assuming that is the
problem)...
    Thorsten
Date: 6 Jun 2004 11:52:32
Message: <40c33dc0$1@news.povray.org>
I guess it is some program generating this output.  As you apparently have
both 3.5 and 3.6 running, could you try to comment out one of the parameters
until you find the one interpreted differently?
    Thorsten
Date: 6 Jun 2004 12:30:01
Message: <c9vgh2$6vg$1@chho.imagico.de>
It seems to be the reflection 'exponent sqrt(2)'.  Note i also get
occasional render freezes (i.e. the render halts and the program can
only be stopped by multiple CTRL-Cs) in 3.6 when using the fresnel
reflection.    Since i never had any problems with fresnel reflection
before i assume this is something specific to this scene (i.e. the
mesh).  Lowering max_trace_level strongly or not using radiosity avoids
this (so maybe the ray recursion handling of radiosity in combination
with reflection does not work properly although i have rendered a lot of
scenes with radiosity + reflection without problems).
