![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Subject: Light_sources in light_groups don't cast shadows.
Date: 24 Nov 2001 08:43:41
Message: <3bffa40d@news.povray.org>
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Read the same thread in beta.test for explanation.
This is the scene:
camera
location <0, 2, -4>
look_at <0, 0, 0>
light_group {
light_source
<0, 5, -3>
rgb 1
text {ttf "times.ttf" "TEXT" 1,0 pigment {rgb 1} translate <-1,1,-2>}
torus {1.75,0.25 pigment {rgb 1}}
The first image shows the bug. The second one shows how it should look (I
commented out the light_group).
Jonathan.
Download 'light1.png' (16 KB)
Download 'light2.png' (13 KB)
Preview of image 'light1.png'
![light1.png](/povray.beta-test.binaries/attachment/%3C3bffa40d%40news.povray.org%3E/light1.png?ttop=432686&toff=100&preview=1)
Preview of image 'light2.png'
![light2.png](/povray.beta-test.binaries/attachment/%3C3bffa40d%40news.povray.org%3E/light2.png?ttop=432686&toff=100&preview=1)
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Interesting because I see the shadowed result here (2nd image) without
changing the scene. (v3.5b7 on P3 WinXP)
"JRG" <jrg### [at] hotmail com> wrote in message
news:3bffa40d@news.povray.org...
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Subject: Re: Light_sources in light_groups don't cast shadows.
Date: 24 Nov 2001 09:04:21
Message: <3bffa8e5@news.povray.org>
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Maybe it's due to the OS?
"Bob H." <omn### [at] msn com> ha scritto nel messaggio
news:3bffa88f$1@news.povray.org...
(I
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Date: 24 Nov 2001 09:06:24
Message: <3bffa960@news.povray.org>
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Or are you using any particular ini option?
Perhaps posting your ini settings might be interesting.
(I
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Date: 24 Nov 2001 09:08:39
Message: <3bffa9e7@news.povray.org>
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
I got it. -UL makes it work correctly. A bug indeed.
(I
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Date: 24 Nov 2001 09:11:57
Message: <3bffaaad@news.povray.org>
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
news:3bffa960@news.povray.org...
No. Just:
; Width of image in pixels. Accepts integer values.
Width = 320
; Height of image in pixels. Accepts integer values.
Height = 240
; File format to write render image to.
Output_File_Type=N
; File Output Buffer (amount to write to memory before writing to disk)
Buffer_Output=On
Buffer_Size=4096
; Sets minimum number of objects before auto bounding kicks in.
Bounding_Threshold = 6
; Turn display on
Display=On
Display_Gamma=2.3
; Turn verbose mode on
Verbose=On
And I tried bmp, tga, and png file outputs too, all same. Didn't expect any
difference really.
bob h
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Date: 25 Nov 2001 00:51:11
Message: <3c0086cf@news.povray.org>
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Bob H. wrote in message <3bffaaad@news.povray.org>...
Try changing this to 0. You've only got two objects in the scene, so
bounding boxes are not used. It might be a problem with the bounding box
code. Use (or non-use) of bounding boxes has been a cause of apparently
platform-dependent behavior before.
Mark
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Date: 25 Nov 2001 02:12:33
Message: <3c0099e1@news.povray.org>
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
"Mark Wagner" <mar### [at] gte net> wrote in message
news:3c0086cf@news.povray.org...
That changed it alright, very curious. So must be the bounding/light
buffer. Too bad I don't know POV program source code to fix it myself.
I went from 0 up to 6 again and not until 6 did it have a shadow, also was
slower to render of course. Guess I just happened to have that set to the
magic number for this particular example. I'm supposing 4 letters plus a
torus counts as five things.
text{ttf"arial","bob h",.1,0pigment{rgb 9}translate<-1,-.2,3>}
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
