Magnatune: We Are Not Evil
  POV-Ray : Newsgroups : povray.animations : CSG tree of Unions Server Time: 9 Jan 2009 02:51:28 GMT
  CSG tree of Unions (Message 1 to 8 of 8)
Subject: CSG tree of Unions
Date: 4 Feb 2008 08:45:01
Message: <web.47a6d01895eefef63c0d56f20@news.povray.org>
Well I have a hierarchically structured CSG tree. Different parts of the tree at
different levels represent different body parts.
#declare Humanoid =
  union { // trunk
    cone{ ..}
    sphere{ ...}
    union{  // right arm
      sphere{..} // shoulder
      cone{..}   // upperarm
      union{ // lower right arm
        sphere{..} // elbow
        cone{..} // lowerarm
        union{
           sphere{..} wrist
           object{ right_hand }
This structuring allows me to animate by rotating about joints/spheres.  After
rotating a number of body parts, the coordinates of the sphere, cone objects
that make up Humanoid object change.
Now questions:
1. Do those changes get reflected back in the POV-RAY SDL variable Humanoid?
2. Is it possible to traverse my CSG Unioned tree object and figure out where
the limbs of my virtual guy have ended up at? [I need to be able to do this so
I can put my Humanoid into the pose he was at the end of the prev stage, at the
beginning of the new stage.)
Subject: Re: CSG tree of Unions
Date: 4 Feb 2008 10:21:31
Message: <47a6e72b$1@news.povray.org>
"melo" <meltemnarter [at] coxnet> wrote in message
news:web.47a6d01895eefef63c0d56f20@news.povray.org...
> tree at
> #declare Humanoid =
>  union { // trunk
>    cone{ ..}
>    sphere{ ...}
>    union{  // right arm
>        sphere{..} // elbow
>        union{
>           sphere{..} wrist
> After
> objects
> Now questions:
> Humanoid?
Once the parser has read the definition in your SDL the internal
representation of the variable Humanoid will end up holding an internal
representation of the shapes resulting from the application of the
transformations to the objects. You won't be able to access that internal
representation from further down in your SDL other than by referencing the
variable 'Humanoid'. That is to say that POV-Ray doesn't expose the internal
representation.
It's different from the way things like HTML and VRML have evolved with
their separation between the DOM and scripting to support interrogation of
the current DOM hierarchy from the scripting language.
> where
> this so
> at the
No. You won't be able to traverse the elements of the composite CSG object
as you've currently got it defined. The only access you subsequently have to
it is through the variable 'Humanoid'. There are some functions that give
you specific pieces of information about it, such as the min_extents() and
max_extents() vector functions, but the information returned is for the
whole object, not for individual components.
The simplest solution is likely to be to store away the information you will
need later as you go through building up your object definition. You will
find arrays handy for this as they can store all sorts of things, including
vectors for positions and rotations, but also entire transformations.
Transformations assigned to an identifier can subsequently be applied to
position vectors using the 'vtransform' macro.
Chris B.
Date: 4 Feb 2008 11:35:01
Message: <web.47a6f8447294e2553c0d56f20@news.povray.org>
"Chris B" <nomail [at] nomailcom> wrote:
Thank you very much for responding so promptly.
I have a better idea of POV_RAY SDL environment .
I hope you will have time to respond to my other post.
Thanks again,
Meltem
> > tree at
> > #declare Humanoid =
> >  union { // trunk
> >    cone{ ..}
> >    sphere{ ...}
> >    union{  // right arm
> >        sphere{..} // elbow
> >        union{
> >           sphere{..} wrist
> > After
> > objects
> > Now questions:
> > Humanoid?
> representation.
> > where
> > this so
> > at the
> Regards,
> Chris B.
Date: 4 Feb 2008 12:53:31
Message: <47a70acb@news.povray.org>
> Thanks again,
> Meltem
Hi again Meltem,
Do you mean your "skeletal animation using POV-RAY" post?
On that thread I posted a lengthy response which is followed by a follow-up
response from you, but in your response I only see a copy of my response (I
see no additional text).
I've checked on the  http://news.povray.org web site because my Outlook
Express newsgroup reader quite often misses postings or responses, but the
thread looks the same there.
Did you post follow-up questions on that thread that I'm not seeing?
Chris B.
Date: 4 Feb 2008 14:17:51
Message: <47a71e8f$1@news.povray.org>
I see the same.
Date: 4 Feb 2008 15:10:01
Message: <web.47a72a9e7294e255c150d4c10@news.povray.org>
> #declare Humanoid =
>   union { // trunk
>     cone{ ..}
>     sphere{ ...}
>     union{  // right arm
>         sphere{..} // elbow
>         union{
>            sphere{..} wrist
> Now questions:
Appropriately structured and nested use of vaxis_rotate and/or vrotate could be
of use.
-tgq
Date: 5 Feb 2008 02:10:01
Message: <web.47a7c4c77294e2553c0d56f20@news.povray.org>
Sorry Chris,
I composed a length response to your response, with lots of burried in thanks,
comments, and some additional questions.  I am stresses to see it go.  However,
I will respond to it again.
Getting my Humanoid moving smoothly is of utmost importance to me.  I realize
for a brand new beginner to animation, and to POV-RAY, I might have bitten of
more than I could chew.
Well, I am driven I see skeletal animation as a good visual way for me to learn
about the physiology of movement.  As this deepened understanding could help me
conduct research toward building motion enabler devices.  3.5 years ago I got
hit by a car going 35-45mph as a pedestian, head on.  Well after the impact the
car continued to move, I did not.  I was in the hospital for 6 months, and then
wellchair bond for another year.  Now, most of my movement and cognition is
back.  My rehabilitation period had put me in touch with other people with TBI.
Not all of them were as lucky as me.
I have no idea if my dreams of using computer technology towards helping people
will come to fruitation.  That dream keeps me going, and it brings me joy.
Sorry, I am being too chitty, chatty.   Now I need to go and repost to skeletal
animation comments/questions.
Cheers,
Meltem
> > Thanks again,
> > Meltem
> Hi again Meltem,
> Regards,
> Chris B.
Date: 6 Feb 2008 04:44:44
Message: <47A93A7C.5030209@joplin.com>
I've been following your adventures in animation with some interest as I
have travel down that road also.
  I started with still poses of robots made from scratch for each pose.
Then I put all the angles to position body parts in separate file. As I
used the Robots for still pictures I had a robot POV that made the robot
that could be call from a scene file. The scene file would have the pose
file name and pass it to the robot, the robot would read it, make a
robot, then pass back an object call 'Robot'. The Scene file could place
that 'Robot' anywhere ya wanted. I could have several robots in various
positions and poses in a scene. Once I had a few poses I made a few
different robot POVs that could use those pose files.
  Now on to animation. I decided I had all those poses it would be nice
if I could have a robot move. I've seen that you've been asking about
the same stuff I found out through trial and error. I have an web page
http://leroywhetstone.s5.com/
It has the result of my animting robots. I went with ....
I'll let you check out that web page before I turn this post into a
novel. It should be helpful.
Have Fun!
Copyright 2003-2008 Persistence of Vision Raytracer Pty. Ltd.
