POV-Ray : Newsgroups : povray.animations : PovPerson refused to come into my pov scene. Server Time: 5 Sep 2008 06:06:44 GMT
  PovPerson refused to come into my pov scene. (Message 1 to 10 of 11)
Subject: PovPerson refused to come into my pov scene.
Date: 10 Mar 2008 01:40:00
Message: <web.47d49e814b35a0df587ef5e20@news.povray.org>
Hello, Chris,
I have struggled some more with my animation, then started playing with
POVPerson.  I was going to follow
Quick reference step by step before I play with animation
However I had not managed to go far:
The online documentation recommends
#include "povperson.inc"
object {ppFigure("ann.inc","style1.inc","smile","standing.inc","ppoutfit1.inc")
translate x*5}
to drop add into my pov scene.
I had surely updated my Library_Path to include PPV2 folder. well, as I started
testing the code hoping to see ann,
I realized, I had to add "pp" prefix to all include files.  For a Quick
Reference documentation, it might be a nice touch to keep example follow your
naming convention.
Anyhow, that is not where I stopped, as POV-RAY parser complained I kept adding
"pp" prefixes.  Only to realize,
there was no smile file, ppsmile.pov, or any version that sounded like an
expression, Okay. the document does say None yet provided, but I got a parser
error at line reading
#include ppExpression
in ppFigure macro.   What would you recommend that I do? Passsing a blank file
name does not work, not passing that argument does not work.  I could eliminate
that arg from ppFigure macro for now?  Would that be safe?
As for my simple approach, relying on POV-RAY to figure out the coordinates when
there are rotations involved in a subset of joints in a joint-segment pair CSG
union tree hierarchy.  It worked.  POV-RAY definitely figures out where the
segments go as  result of rotations in select number of nodes.  Having
programmed in C and SAS for a long time, I had assumed that there would be a
way to query POV-RAY to learn the resulting state of joint-segment coordinates.
Thanks to this listserve, and thank you Chris, I learned I was being just too
optimistic. Well, not being the one who can take a no easily, now I wonder, how
difficult could it be to add a custom C level function to POV-RAY.  I remember
seeing urls to source code somewhere, of course I am assuming it is very well
documented, it will be very easy to locate an object handle, given the name of
an object.  Even if I can locate the object handle for the root of my Humanoid
tree.  Would each node contain updated transformed coordinates of that node?
Now that I have started reading more on animation, and thinking about rotations,
I have come across a new branch of geometry that was not in the works while I
went for my doctorate with a minor in ECE. The Engineering Mathematics back
then were about Linear Algebra.  Given 3D vectors, we worked with 3x3 rotation
matrices.  Now I hear about "quaternions", memory and computational
efficiency-wise they are regarded very highly it appears.   Well, even for the
old school I used to know I cannot remember fathom how to apply cummulative
effects of rotational transformation at a node and at its parents.   Not only
there might be rotational transformations at some parent nodes, they are
happening  about the center points of those parents.  As for quaternions I
guess I need to get my hands on a book.
I need a few more life times to pursue this interest and possibilities.
Thanks,
Meltem
Subject: Re: PovPerson refused to come into my pov scene.
Date: 10 Mar 2008 12:19:02
Message: <47d53546$1@news.povray.org>
"melo" <meltemnarter [at] coxnet> wrote in message
news:web.47d49e814b35a0df587ef5e20@news.povray.org...
> Hello, Chris,
> object
> translate x*5}
Ah yes. That is wrong. The example files like 'pp00example05.pov' contain
the later version of the syntax for the ppFigure macro, where all of the
parameters have been removed and where you need to 'include' files and call
macros to set specific options before calling the 'ppFigure' macro. This
allows defaults to be used and the parameters in the example above are
roughly the defaults.
The minimum required to add a figure is therefore:
ppFigure()
Which adds an 'ann'  figure about 1.6 POV-Ray units tall standing at the
origin facing towards +Z. The hair looks terrible in this default figure as
it's cut to about 30 hairs to minimise the performance impact, so you may
want to try:
#include "ppstyle6.inc"
ppAddPoseFile("ppsitting.inc");
object {ppFigure() rotate y*180}
light_source { < 2, 60  ,-30> color rgb<1, 1  , 1  >*0.6 }
light_source { < 0, 24  ,-26> color rgb<1, 1  , 1  >*1.2 }
light_source { <5,  6.5,-10> color rgb<1, 0.5, 0.5>}
  location <-0.3, 1.08,-2.1>
  look_at  y
which gives you a model with hair and a non-default pose.
I do have an updated version of the users guide that I never got round to
publishing. I'll dig it out and see if it makes sense to replace the one
that's there.
Chris B.
Date: 12 Mar 2008 03:25:01
Message: <web.47d75aa73d86ff96314b3d800@news.povray.org>
> > Hello, Chris,
> > object
> > translate x*5}
> ppFigure()
Thanks Chris.  I will give this a whirl.  In the meantime.  I will still try to
get the stick-figure Humanoid of my 1st try walk.  After all i had already
invested 5-6 months in it. Ickkk!
Who knows, there might be a way to export the current posed state of a skeletal
object to Moray or Bishop from which one can interactively generate coordinates
of next pose?
Always the dreamer.
Cheers,
Meltem
> want to try:
> camera {
>   look_at  y
> that's there.
> Regards,
> Chris B.
Date: 14 Mar 2008 03:05:00
Message: <web.47d9f8f03d86ff96314b3d800@news.povray.org>
It appears you might have a different/local version of POVPerson.
When I tried your new simple syntax recommendations i.e
 ppFigure()
I got a Parse Error saying :  Expected 5 parameters but only 0 found.
Now a totally unrelated question:
Is it possible to specify movement constraints in POV_RAY.  I had managed to
calculate the coordinates of my Humanoids's forward heal after he strides
forward.  During Cross-Over pose to come in 3 Key-Frames, he moves his back leg
next to his forward leg. This move shifts his weight over forward leg, as his
centroid translates to be directly vertically over his forward heal.
Having said all that, throughout 3 key-Frames, I donot want his forward foot to
move at all as the joint rotations of some other 10-11 joints might be
changing, including the immediate parents of forward_heal_joint & forward_foot
pair's parents, which are forward leg's knee, and hip joints.   They get rotated
to bring Humanoid_Root over the forward heal. They are slightly bent as they are
weight bearing.
I was hoping for some constraint specification that would keep an object
location wise gripped.
Another application of constraint specification could be to ensure that the
floor my exercise room is solid, so as I move my Humanoid around, I would not
be able to dip any part of him/her below the surface.
Well, s/he has been entertaining me emerging through walls, stepping into
floors.   Now just by a new comers luck and mistakes, I had learned how I can
dismantle him/her, segment by segment into a pile.  No, no I am not into
violence, but animating what happens to a being when hit by a car could be
doable, not very realistically, for now.  Given how little I had accomplished
for having worked as long as I had on rudimentary animation, and how much I had
discovered I don't know as of yet.
> > > Hello, Chris,
> > > object
> > > translate x*5}
> > ppFigure()
> of next pose?
> Always the dreamer.
> Cheers,
> Meltem
> > want to try:
> > camera {
> >   look_at  y
> > that's there.
> > Regards,
> > Chris B.
Date: 14 Mar 2008 08:20:40
Message: <47da4368$1@news.povray.org>
news:web.47d9f8f03d86ff96314b3d800@news.povray.org...
> ppFigure()
Oh. Well looking on the bright side, that means that at least the
documentation and the code on the website are more consistent than it
appeared for a moment. :-)
It's possible to specify constraints on joint rotations to keep a joint
within realistic limits.
> I had managed to
> back leg
> his
> foot to
> forward_foot
I think this is where you need to be able to change which body part is
fixed. In my system I just specify the new fixed body part as being the
forward foot. From then on, any small spurious rotations affect the back
foot position rather than shifting the front foot.
> They get rotated
> they are
> weight bearing.
Having a single fixed body part obviously contrains that body part, but when
you get into fixing multiple body parts (e.g. on stairs where both feet can
be in contact with the steps and both hands on the handrails for a number of
animation frames) then it starts to get an order of magnitude more complex.
This gets you into inverse kinematics which I never got round to
implementing properly in POV-Person, although I did have some thoughts on
how I'd go about doing it.
There's no single solution to inverse kinematics as the body parts could
more or less take any route from one fixed position to another. Also this
requires some way of dealing with situations where two body parts can no
longer be joined without violating other constraints. POV-Person was written
to allow for this to a limited extent in that it calculates a pose by
scanning the arrays back and forth rather than working from a single fixed
starting point. If two fixed positions are set and they can't be joined
it'll work out what it can and just leave a gap between body parts it can no
longer join. The next logical step would be to track back and 'straighten'
nearby joints to attempt to bridge the gap.
> the
> not
This brings you into collision detection which is another somewhat complex
area of study. Once again, I wrote POV-Ray to be able to respond to such
detection by maintaining body part positions and rotations in arrays that
can be adjusted iteratively, but never implemented very much in that
respect. My forays into this area were largely contained in the crowd
positioning macros, which use the POV-Ray trace command to detect suitable
positions on a surface for a person to stand on. The macros actually shoot
out multiple traces for a given position to check the gradient of the
surface and the proximity of nearby vertical dropoffs and objects.
> can
> accomplished
> I had
Well human animation is one of the most difficult things to get right. If it
were an easy subject then the professional animators who've been struggling
with it for years would have it nailed by now. There have been a couple of
recent films where, seen at a distance, you can't really tell which of the
figures are real or generated, but I've not yet seen anything that's very
convincing up close.
Our brains are extremely sensitive to even the very slightest inconsistency
in human appearance, posture and movement. Despite being completely
surrounded by images and representations of humans, it's very rare that we
would mistake any of that for a real person for very long. Even when someone
jumps and says "I though that was a real person" it's usually where they've
seen it out of the corner of their eye and the deception only lasts a tenth
of a second or so.
Chris B.
Date: 14 Mar 2008 22:50:00
Message: <web.47db0e5f3d86ff96314b3d800@news.povray.org>
"melo" <meltemnarter [at] coxnet> wrote:
I had tried the new, easier syntax you recommended
 ppFigure()
I got a Parser error, complaining about expecting 5 parameters, and only finding
0.
Your working version sounds different than the downloadable version of PP.
Thanks,
Meltem
Is there any way to define transformation constraints in POV-RAY?  I need to
keep my skeletal objects forward feet locked in place whereever it lands, as he
brings his back leg forward into his cross-over pose ready to take his next
stride.
Another place where I might need transformation constraints is obstacle
avoidance, or not allowing him stepping into or thru hard objects.  Now he
steps into the floor or walks right thru the walls, he is very entertaining, as
he is.
Thanks again.   Of course, none of the above had been doable, since I left it to
POV-RAY to come up with coordinates of bone-segments & joints in my moved
(=posed) skeleton.
How I wish POV-RAY had allowed some kind of structure and linked list
definitions, how I wish it had known and informed its users about states.
It is obviously doing a whole bunch of marvelous, mathematically sound
computations, to be able to render complex CSG objects transformed in any
conciveable ways.
Well, this is the second time I am attempting to respond to this posting, the
first one has disappeared on me.  If they both appear, please accept my
appologies.
Cheers,
Meltem
> > > Hello, Chris,
> > > object
> > > translate x*5}
> > ppFigure()
> of next pose?
> Always the dreamer.
> Cheers,
> Meltem
> > want to try:
> > camera {
> >   look_at  y
> > that's there.
> > Regards,
> > Chris B.
Date: 15 Mar 2008 08:39:03
Message: <47db9937$1@news.povray.org>
news:web.47db0e5f3d86ff96314b3d800@news.povray.org...
I suspect that it would be difficult to meaningfully interpret the internal
structures and the rotational and positional information used internally by
POV-Ray. You'd need to know the starting point that this information is
relative to, and this may not be easy to determine or what you may expect in
all situations.
What POV-Ray does provide is a series of macros that enable you to apply
transformations to vectors. You can therefore say, "if this is my starting
point, where would it end up when I apply these transformations?". IMO this
is more productive and easier to use.
> the
> appologies.
Does that mean you can't see my response to your first attempt either?
I find that, if stuff doesn't appear, it's helpful to look at the same
newsgroup on http://news.povray.org as a reference, but it still doesn't
guarantee that everyone can see the same things.
> Cheers,
> Meltem
Date: 20 Mar 2008 19:40:01
Message: <web.47e2cb703d86ff96314b3d800@news.povray.org>
> all situations.
Your statements highlighted a lot more that I had made assumptions on.  Meaning,
I had assumed that, the documentations on POV-RAY would have enabled me to
interpret the internal structures.  Yet another assumption I had made is that,
those internal structures are state aware.  Meaning, during animation, if I am
in "frame_number=x"  the internal structures would correspond to all the
code parsed, executed for that particular frame number.
As I had mentioned before, in my crude, 1st skeletal animation attempt, I had
povided joint rotation vectors with respect to a global coordinate system, not
in relation to parent joint-segment pairs.   And I had utilized
             Rotate_Around_Trans(Rotation, Point)
macro.
With your help so far, I had managed to get him move from Key-Frame(=Pose) to
Key-Frame(=Pose).  I give him 5 frames to move from one Key-Frame to next.
Well now that I put him in a room, I could see the short-comings of my approach.
Obviously remembering his previous Pose when the new Pose began was not good
enough.  In addition to the Pose, I had to remember where to place him.  Not
into the wall, not below the floor.
Not wanting to give up, the very first pose is when he takes his very first
stride, I used
  vtransform  and  VProject_Plane macros
to calculate where his forward heal and toes would ended up.  By placing
transparent circles I verified that my calculations were correct. Much to my
surprise, they were.
Well, from then on it takes him 4 poses, to bring his back leg into cross over
position.  Throughout all those poses, i.e frame_numbers 6..25, I tried to use
   #if ( !VZero( Forward_Heal_Coord ) )
       object{ PosedHumanoid }
       Align_Trans( PosedHumanoid, -y, Reference_Point )
       Align_Trans( PosedHumanoid,  z, Forward_Foot_Coord )
   #else
       Align_Trans( PosedHumanoid, -z, Reference_Point )
The first part of the if condition was meant to align him with his forward foot
always - with an assumption that his forward toes would be his right most point
(not a good assumption, I know, just to see him walking I was willing to live
with this assumption for now.
Reference_Point was a globally declared vector attempted to prevent him from
dropping below floor or moving into walls.
I was quite disappointed this last attempt did not save the day.
Given, I had not had much luck with PovPerson until now either. And I am
convinced, my simple approach will not save the day.  I do need to keep track
of location as well as rotation of joints of my skeletal tree.
After realizing that I started searching internet again.  Much to my shock I
discovered a freeware character animation software:  Blender, which provided
both build in forward and inverse kinematics.  It was rated next to 3dMax &
Maya.
Has anyone had much/any experience with it.  Am I daydreaming?
Thanks
Meltem
> > the
> > appologies.
NO, No, I was able to see your response.  False alarm.  I was just being
impatient.
Thanks for all your help
Meltem
Date: 21 Mar 2008 17:28:41
Message: <47e3fe59$1@news.povray.org>
news:web.47e2cb703d86ff96314b3d800@news.povray.org...
> approach.
You may find that you can use the 'min_extent' and 'max_extent' functions
may help you avoid collisions between your object and floors/walls/ceilings
(or at least detect them).
> Much to my shock I
> provided
> Maya.
Blender is an open source modeller, (see http://www.blender.org/). It seems
to have come a long way since I last looked at it many years ago and their
site indicates that it incorporates some character animation features. The
'features' section on the site certainly talks of skeleton rigging and
animation with forward/inverse kinematics, although it's difficult to judge
where it's limitations may lie from the brief description that I just read.
Their 'scripts' section at
http://www.blender.org/download/python-scripts/wizards/ talks about
MakeHuman Python scripts, but I couldn't get the links there to work. I
don't know if those scripts are anything to do with the sourceforge
MakeHuman project at (http://sourceforge.net/projects/makehuman/).  There's
also talk of 'Walk.O.matic ' scripts and 'Blender People' scripts that seem
to be separate initiatives.
Their site does have an animation forum which looks to be pretty active, so
you would probably be able to get some good feedback there on how easy it
would be to achieve what you want to do. Also you may well get a wider
audience on this newsgroup by starting a separate thread for this question
rather than tagging it to the bottom of this thread. It might be only you
and me still reading this one :-).
Chris B.
Date: 23 Mar 2008 02:15:00
Message: <web.47e5ca373d86ff96314b3d800@news.povray.org>
> > approach.
Yes, I had tried those a while back, and reported by failures in getting them
work the way I hoped.  See I attempted to draw a box around my Humanoid after
getting min and max extends to see visually what how those macros behaved.
Much to my disappointment, the boxes seemed to extend outside screen.  Well I
played with camera coordinates to see if by accident I had put any part of him
way out of limits.  I could not find anything it down.
Besides, even I was successful getting them working, I was not liking using
them, what if s/he was carrying something in her/his hand that extended beyond
his/her forward foot.   Nonetheless, the macros I found, and keeping rotations
in arrays, allowed me calculate the coordinates of his forward heal/foot
correctly.   Nothing too sophisticated.  Knowing the exact placement of his her
forward foot, and for the poses I coded seeing no other part of his/her was
further ahead than her forward foot should have made
    Align_Trans(Object, Axis, Pt).
macro work, it had not.  Well, I am clueless why the heck not?
It appears I could use a language I am comfortable with to generate POV-RAY
scene code using the Pose files, skeletal hierarchy definition files, to
generate the coordinates of all of the joints, then use POV-RAY to render it.
Well, I was finding myself needing a structured language that could allow me to
create a tree to represent the skeletal hierarcy, where each node would be a
joint-segment pair.   whenever a pose file specify a rotation for a node, that
rotation would need to be applied to all the children of that node.   Well this
is for forward kinematics part of the movement.
It blows my mind that you were able to accomplish not only forward, but some and
absolutely relevant inverse kinematics by traversing an array of joints up and
down and resolving all unresolved movement and geometry constraints.  Assuming
I interpreted your approach correctly.
I have accumulated lots of bioengineering and anthropological references that
give average volume/weight percentages of every segment in an average
male/female human body.   As well as biological joint rotation constraints.
All of those could be properties of tree nodes.
I have hopes, not limited energy to carry thru with all my hopes & dreams.   I
wanted an animated humanoid that would be subject to  the laws of mechanics and
dynamics as s/he moves to stay in balance.
I wonder how I managed to get my doctorate without Google?  Now, with the touch
of my fingertips I can do so much through research than before. Which has its
benefits and its down site, I get lost in the information highway, when I
realiaze how little I know, and how much more I want to know.
Well as I started teaching myself skeletal and character animation, and reading
up on forward and inverse kinematics, I realized the mathematics needed to make
my virtual being move was the the same math used in robotics.   Now, I want a
take robotic classes, I want to  have a robot that will be syncronized with my
virtual humanoid, in hopes they can facilitate robotic rehabilitation device
development and testing.
Yeah, yeah.  very doable for someone who is a recovering perfectionist, and a
recovering TBI survivor.
Thanks for your note, I will create a separe line of inquiry on Blender?
Instead of investing my years into resolving problems already solved -see that
would be the only way for me to really understand them and learn them- I should
focus on the areas I want to apply them to.
Cheers,
Mel
> > Much to my shock I
> > provided
> > Maya.
> Regards,
> Chris B.
Copyright 2003-2008 Persistence of Vision Raytracer Pty. Ltd.
