POV-Ray : Newsgroups : povray.animations : AVI file as background or backdrop Server Time
27 Sep 2024 20:24:35 EDT (-0400)
  AVI file as background or backdrop (Message 1 to 8 of 8)
Subject: AVI file as background or backdrop
Date: 21 Jun 2004 11:49:17
Message: <web.40d6f5f2e436328fc60dd8760@news.povray.org>
I would like to render an object in POV where the background is an AVI file.
I wrote a program that a.o. can extract the consecutive frames from the
AVI, and I use these images as background by setting them as an image map
on a plane. Things look OK, but the lights disturb these background images,
they become too bright!
BTW: of course I need lights in the POV scene to light my objects.
I hope there is a way to put external images as a background (or backdrop)
into POV scenes without the scene infuencing the image.
Thanks!
Subject: Re: AVI file as background or backdrop
Date: 21 Jun 2004 13:59:10
Message: <40d721ee@news.povray.org>
  Theoretically you could use the image in a sky_sphere, which is not
affected in any way by light sources, but it might not be trivial to
transform the image_map so that it will perfectly fill the viewport.
  With the image_map in a plane you could just try setting the finish
of the plane to 'ambient 1'.
Date: 21 Jun 2004 16:54:45
Message: <40d74b15$1@news.povray.org>
Warp nous apporta ses lumieres ainsi en ce 21/06/2004 13:59... :
If you go that way, also set 'diffuse 0'. This way, it won't be affected
by your light.
Date: 24 Jun 2004 03:10:01
Message: <web.40da7df76c19b690c60dd8760@news.povray.org>
Warp and Alain,
Thanks a lot for your advices! I now have things running the way you
proposed! The only thing that bothers me is the absence of the possibility
to have a background image in stead of background color, so for the time
being I'll have to do it with a plane as background.
What I had to do is to define the plane (with an image of 720 * 576, DV PAL)
in such a way that it fills the resulting POV end image (also 720 * 576), I
did this on an experimental basis, is there an easy rule for this?
Next to that: I developed a VB program that allows images to be superimposed
on AVI footage made by Digital Video camera, where the position of the
image can be locked to a certain objectposition on the AVI. The program
does some image analysis in order to automatically trace the object in the
AVI, so for instance I can place a tree somewhere on the ground and this
tree will stay on it's virtual place no matter the movement of the camera.
(see www.stabilize.tk for a demoversion of this program called VMT). Now I
would like to adjust the program that it also can place animations on the
AVI footage, using POV. In my test this already works! What I do in VMT is
to point at the position where I like to place the POV object. VMT then
traces this position and a.o. outputs a datafile where the X and Y position
of the indicated point. These data then should be used by POV to translate
the object to the correct position of the point in different frames.
The X and Y positions are in DV coordinates (1-720, 1-576). How to best
recalculate these coordinates for the translation?
Thanks in advance for your advice!
Hans
Date: 27 Jun 2004 04:06:21
Message: <40de7ffd@news.povray.org>
I'm confused; they suggestions they gave you should not have limited your
ability to use an image.
The original setup that you had, with finish {ambient 1 diffuse 0} should
have worked fine; the image would not be affected by lighting and would be
visible in the background if you placed the plane right.
 - Slime
 [ http://www.slimeland.com/ ]
Date: 28 Jun 2004 02:55:00
Message: <web.40dfbfc66c19b690c60dd8760@news.povray.org>
Slime, thanks for your reaction; I think I didn't explain my problem
clearly.
Using the plane with an image works fine; my problem however (due to
inexperience probably!) is that everytime I change the camera position I
also have to change the plane's position.
Using a background or even better a backdrop like in Carrara overcomes this
problem. I hope you can give me an advice how to position the plane with
the image file in such a way that it remains visible no matter the camera's
orientation!
regards, Hans
Date: 28 Jun 2004 04:23:23
Message: <40dfd57b$1@news.povray.org>
Ah.
You may want to look into screen.inc. Specifically, the Screen_Plane macro
may do what you want. Although the macro is intended to put a plane *close*
to the camera, with a large value for "Scaling" (the second argument), I
think you can make it go as far away from the camera as you want.
 - Slime
Date: 28 Jun 2004 06:35:00
Message: <web.40dff3336c19b690c60dd8760@news.povray.org>
Slime,
Looks like this is exactly what I am looking for! Thanks a lot for your
advice!
Hans
