Hi guys, I was wondering if anyone has attempted to create the Matrix bullet
time effect. Or if someone has an idea on how to do it.
Kind Regards
Fidel.
bullet
// predeclare objects agent, bullet, and neo
object {agent translate z*10}
object {bullet translate z*(10 - 20*clock)}
object {neo translate -z*5}
location <0,10-7*clock,-(10-5*clock)>
look_at 0
rotate y*360*clock
translate -z*5
Heh... untested code, btw.
- Slime
[ http://www.slimeland.com/ ]
> bullet
> camera {
> look_at 0
> rotate y*360*clock
> translate -z*5
> - Slime
I couldn't see it...
(no light)
Remco
neither could Greg
-tgq
Hi Slime,
Thanks for your reply, but I was actually interested in the effect of the
bullet. That is the wave trails it leaves in the air.
The bullet is travelling and leaving trails. That's what I am looking for.
Thanks once againg.
Fidel.
in article 3db9d52f@news.povray.org, Slime at slm### [at] slimelandcom wrote on
26/10/02 12:35 am:
> bullet
> camera {
> look_at 0
> rotate y*360*clock
> translate -z*5
> - Slime
IIRC, this may be quite difficult. I think that there were rings of
"turbulence" or whatever coming out as the bullet went through the air -
quite simple if you can get a nice looking transparent texture.
However, I also recall them distorting the background, ie refracting,
but without a solid edge. This is the only case that I can think of (so
far) where variable IOR would be nice to have. Perhaps the effect could
be re-created with a set of lens objects, becoming very thin and flat at
the edges (for no distortion), with a sort of ring-like bulge that moves
outwards. Definitiely a case for isosurfaces or meshes here.
"Fidel viegas" <fid### [at] artrecognitioncouk> wrote in message
news:B9E04BB0.5B66%fid### [at] artrecognitioncouk...
> Hi Slime,
the
for.
> Thanks once againg.
> Fidel.
on
> 26/10/02 12:35 am:
Matrix
> > bullet
> > camera {
> > look_at 0
> > rotate y*360*clock
> > translate -z*5
> > - Slime
> in the effect of the bullet. That is the wave trails
Not finished code ready for the purpose, but maybe something that can
get you started:
#include "transforms.inc"
camera {location <2,3,-8> look_at 0}
light_source {<0,10,0>, color 1}
global_settings {max_trace_level 100}
sky_sphere {pigment {gradient y color_map {[0,rgb 1][1,blue 1]}}}
plane {y, 0 pigment {checker rgb 0.3 rgb 0.9} normal {quilted 0.5}}
#macro BulletWave(Location,Normal,Radius,Strength,Ior)
intersection {
cylinder {
-0.0001*y, 0.0001*y, 1
pigment {rgbf 1.0}
normal {cylindrical Strength sine_wave phase -1/4}
cylinder {
-0.0002*y, 0*y, 1.2
pigment {rgbf 1.0}
interior {ior Ior}
scale Radius
transform {Point_At_Trans(Normal)}
translate Location
#declare StartP = <0,2,-8>;
#declare DirV = <0.2,0.1,1>/4;
#declare C = 0;
#declare Waves = 100;
#while (C<Waves)
BulletWave(StartP+C*DirV,DirV,0.3+0.1*sin(C/2),0.02,2)
#declare C = C+1;
Rune
rune|vision: http://runevision.com (updated Oct 19)
POV-Ray Ring: http://webring.povray.co.uk
in article 3dbaeb9b$1@news.povray.org, Run### [at] runejohansen@mobilixnet.dk
> get you started:
> intersection {
> cylinder {
> pigment {rgbf 1.0}
> cylinder {
> -0.0002*y, 0*y, 1.2
> pigment {rgbf 1.0}
> interior {ior Ior}
> scale Radius
> translate Location
> #end
> #declare C = 0;
> #while (C<Waves)
> #declare C = C+1;
> #end
Thank you all for the replies. Rune, that is definitely a start. I'll play
around with it. Thanks a lot.
All the best
Fidel.
Remco de Korte <rem### [at] onwijscom> wrote in
news:3DB9F151.C368ED78@onwijs.com
> (no light)
Neo has ambient and is illuminating sorrounding bullets and agent :)
Just have a look at this site:
http://www.jefflew.com/articles.html
It's not done in POV-Ray, but perhaps it helps.
Bonsai
___ __ __ _ ___ ___ _
| _ ) \ \( ) _) _ )( )
| _ \() |\ \ |\ \/ _ \| |
|___/__/_)\__)___)/ \_)_)
www.b0n541.net
