POV-Ray : Newsgroups : povray.animations : Particle systems question for Rune, Jonathan, Tim, Fernando, et al Server Time
28 Jul 2024 10:23:54 EDT (-0400)
  Particle systems question for Rune, Jonathan, Tim, Fernando, et al (Message 1 to 4 of 4)
Subject: Particle systems question for Rune, Jonathan, Tim, Fernando, et al
Date: 4 Dec 2001 14:08:30
Message: <3c0d1f2e@news.povray.org>
I think the animations produced by all your respective particle systems are
pretty amazing.  I just have a couple of questions which don't seem to be
getting asked.
1.    Are any of you planning to release your systems to the great unwashed
soon?  (I'd love to beta test if not!)
2.  What's the speed of your respective systems like?  How long does it take
to parse/render a typical particle scene?  (I realise this is a difficult
one to answer.  Maybe quoting the times of posted animations would be a good
guide?)
3.  Have any of your tried using non-spherical/non-blob particles?
Thanks for your time,
Alan.
http://www.mp3.com/FeedingTheCats
Subject: Re: Particle systems question for Rune, Jonathan, Tim, Fernando, et al
Date: 4 Dec 2001 16:10:00
Message: <3c0d3ba8@news.povray.org>
>       the great unwashed soon?  (I'd love to beta test if not!)
In my case not too soon because there's so much work left to do.
>     long does it take to parse/render a typical particle scene?
I'm pretty impatient so I usually don't let frames take more than a minute
to parse+render, often much less. That is sometimes on a 1 GHz machine,
other times on a 150 MHz machine.
>     particles?
I have tried using MegaPov glows and also textured discs facing the camera
and in the future I intent to take much more varied approaches.
Rune
Rune's World:    http://rsj.mobilixnet.dk (updated Nov 5)
Date: 4 Dec 2001 17:03:57
Message: <3C0D47DD.DBCDD7F2@gmx.de>
> getting asked.
Well, I'm pretty much wrapping the system together. It's not a system that uses
the trace()-function though, and thus...
> guide?)
...and thus it has huge parsing-times (around 1 minute for 300 particles using
"physics"-calculations). Frames are then traced depending on how large the
final blob is.
Yes, it is possible. But the systems mostly rely on calculating one position. So
objects are merely placed at that position. On spheres, you don't see the effect
of rebouncing, which would actually cause the particles to spin or "flop"
around,
like a coin would when hitting the ground in a certain angle.
Regarding the beta-testing:
If you'd send me an ema### [at] TimNikias@gmx.de, I could send you the
system as soon as I've created a little help-file for it, with which you may
be able to understand most of it (though probably not in detail).
If you're looking for the more physically advanced systems, try the others
for some beta-testing, since my system is suited more for object placement
and having several objects move along same paths etc... The simple
"moving masses" stuff...
Ask if you have more detailed questions...
Tim
Date: 4 Dec 2001 17:41:02
Message: <3c0d50fe@news.povray.org>
are
> getting asked.
unwashed
I'm not planning to do a fully functional particle system at all :(
I have some code I wrote for fun that perhaps I will put together into a
*real* particle system when I have time (I'm too busy with University at the
moment).
take
good
> guide?)
The last animation I posted took 1h and 56 minutes to render (400 frames,
320x240, +a0.3). Without inter-particles collision things should be much
faster.
Not yet.
Jonathan.
> Alan.
