POV-Ray : Newsgroups : povray.advanced-users : Reverse engineering pigments and textures Server Time
10 Oct 2025 22:01:59 EDT (-0400)
  Reverse engineering pigments and textures (Message 1 to 7 of 7)
Subject: Reverse engineering pigments and textures
Date: 15 Jul 2016 15:10:00
Message: <web.5789343436e895bcb488d9aa0@news.povray.org>
I am having, and have had in the past, difficulty reproducing the colors in
sampled images in my renders.
I was wondering if anyone has had success in sampling rgb values from images or
"rgb color picker" apps and getting good results in their renders.
using sRGB doesn't seem to help me much.
This also got me thinking about how my overall textures are usually pretty
simplistic and plain.
Has anyone ever thought about or even experimented with scanning images and
trying to work backwards from the color / brightness values and trying to deduce
any patterns?  I would think that someone, somewhere has experimented with this
- universities, Disney, Pixar, IL&M, etc.
Thanks
Subject: Re: Reverse engineering pigments and textures
Date: 15 Jul 2016 16:59:58
Message: <57894ece$1@news.povray.org>
Am 15.07.2016 um 21:06 schrieb Bald Eagle:
You have to remember that the colour you see in images is not a
straightforward material colour, but a combination of (a) the material
colour, (b) the surface finish, (c) the geometry, (d) the direct
illumination from light sources, and (e) the indirect illumination via
other objects.
Presuming an overall white illumination, the most important factors will be:
(1) Darkening from shadows and/or the light hitting the surface at a
shallow angle. This corresponds to a mixing with black.
(2) Brightening from (possibly very dull) highlights. This corresponds
to a mixing with white.
In combination, they correspond to a change in total brightness and
desaturation. To counter this, you'll usually have to boost both the
brightness by multiplying all channels by another constant value, and
the saturation by subtracting another constant value from all channels.
By how much, that's a thing you'll have to figure out by tweaking.
Note that these changes need to be applied _after_ converting the picked
colour values to linear colour space; this is especially true for the
boosting of the saturation, which would otherwise cause a shift in hue.
I haven't tested it, but you should be able to do it like this:
  #declare SB = 0.2; // Saturation boost
  #declare VB = 0.4; // Brightness ("volume") boost
  #declare MyColour = (( srgb <128,255,220>/255 )-SB)*(1+VB);
Note that in this variant the saturation boost also affects the
brightness, but the upside is that the formula remains simple enough to
be written in one declaration statement, or even at the very place where
the colour is actually used.
If you are ok with something more complex but possibly easier to tweak,
try the following:
  #declare VB = 0.2; // Brightness ("volume") boost
  #declare RawColour = srgb <128,255,220>/255;
  #declare SatColour = RawColour-SB;
  #declare MyColour  = SatColour*(1+VB)*RawColour.gray/SatColour.gray;
This should keep the general brightness unaffected by tweaks to the
saturation.
Indirect illumination from nearby colourful surfaces, or a general
non-uniformity in the distribution of colours in the illumination (such
as a sunny sky, with a yellowish sun and blue sky), may introduce
additional challenges by also affecting the hue. Countering these may
prove particularly challenging, and you may end up tweaking each colour
channel individually. However, the above stable-brightness trick may
help a bit with this.
In any case, coloures picked from a simple everyday photograph (as
opposed to a photograph taken under carefully chosen lighting
conditions) are typically only useful as a starting point, and will
almost inevitably need a certain degree of tweaking.
Date: 16 Jul 2016 02:59:35
Message: <5789db57$1@news.povray.org>
> [snip]
> try the following:
> saturation.
Interesting. I am going to play with this a bit :-)
Absolutely.
I was going to say this. I often 'pick' colours from photographs and
such but only as a basis for further and very substantial tweaking. An
example of one such exercise is the following fairly simple roof tile
texture based on colours picked from 'real' tiles photographs:
#declare MedTileTex =
     cells
     color_map {//colours taken from roof images
       [0.1 srgb <220,158,106>/255]
       [0.2 srgb <217,177,126>/255]
       [0.3 srgb <228,215,173>/255]
       [0.4 srgb <219,152,100>/255]
       [0.5 srgb <166,120, 61>/255]
       [0.6 srgb <225,171,125>/255]
       [0.7 srgb <230,199,142>/255]
       [0.8 srgb <223,187,129>/255]
       [0.9 srgb <236,176,114>/255]
       [1.0 srgb <244,188,131>/255]
     scale <1, 2, 1>*TileScale
   normal {
     average
     normal_map {
       [1 granite 1 scale 0.1]
       [1 cells 2]
   finish {
     specular 0.1
     roughness 0.00286312
     diffuse 0.4
     reflection {0} conserve_energy
It can be used for distant view where each colour represents one tile,
or as a texture for a single tile.
Date: 16 Jul 2016 12:05:00
Message: <web.578a5aba492309545e7df57c0@news.povray.org>
Indeed.  We've discussed this before, with regards to IIRC, the Victorian room's
hardwood floor colors.
I'm thinking that there might be a way to automatically create a color map from
an image file using SDL.   Scan all the color values using eval pigment :)  and
then do a bit of math to see how the color values cluster.
Might need some iterative interaction.   Maybe plot a graph in 3d RGB space.
I might be (probably) reinventing someone's wheel here.
Maybe someone will get to this before I do.    So many experiments.  Need more
round tuits, coffee, and processor cores.
Date: 17 Jul 2016 03:17:48
Message: <578b311c$1@news.povray.org>
My round tuit generator is over-heated at the moment and spits out
half-molten artefacts. I am afraid they are of not much use...
Date: 26 Jul 2016 00:33:01
Message: <1934107526.491199329.263926.gdsHYPHENentropyAThotmaolDOTcom@news.povray.org>
This may or may not be useful for you, but a while back I wrote a simple
.NET app for ripping unique colors from images into include files as
materials and pigments, and an example can be seen here:
http://news.povray.org/povray.binaries.images/thread/%3Cop.vo4db60c0819q0@gdsentropy.nc.rr.com%3E/
The colors were torn from a picture of aluminum corrosion (I used the same
sampling technique in my corrosion macros), and then used to make an agate
like texture by layering scaled copies of the object and used materials and
such.
The original goal was to emulate depth, as one would find in a gas giant
cloud deck, which worked fairly well. Then life happened, as it is wont to
do, and I largely had to drop the POV projects I hd going. Anyway it has a
variety of applications as I am sure you can imagine.
I am confident that there is a better way to do this specific thing (the
physical depth of the texture such that you can see through to lower
layers) but that is neither here nor there.
I can dump the source somewhere, it was the product of maybe 15m work so
don't expect much in the way of "production" worthy code. If I recall
correctly it does have substantial support for various texture and pigment
properties.
I do not check here often so you can shoot me a mail at (sorry for this):
gds
entropy
at hotmail.
The hyphen isn't an accident.
If enough interest exists I can port it up to .NET 4.6.1 and implement it
in WPF, improve threading, and post it in binaries.utilities as source and
binaries.
Ian
> Thanks
Date: 28 Jul 2016 04:05:05
Message: <5799bcb1$1@news.povray.org>
You need to "undo" the lighting still as clipka mentioned.
Otherwise, even with simple lighting in the image, you will not get what
you expect. Imagine sampling the "bright orange" and "brown" central
squares from the image below:
https://phenomenalqualities.files.wordpress.com/2009/09/rubiks-cube-2.jpg
Both have the same rgb value - yet this is not what you want to use in
your pigments!
