POV-Ray : Newsgroups : povray.advanced-users : Planes (?) for cleaning building envelop (walls) through CSG. Server Time
10 Jan 2025 06:00:50 EST (-0500)
  Planes (?) for cleaning building envelop (walls) through CSG. (Message 1 to 8 of 8)
Subject: Planes (?) for cleaning building envelop (walls) through CSG.
Date: 16 Jan 2010 22:00:01
Message: <web.4b527a32107718d7772dd76f0@news.povray.org>
I am creating a tool for modeling architecture/building information in
POV-Ray SDL. I am implementing the ability for the walls to clean up (form a
clean connection regardless of angle) with each other.
I am currently using planes and although it is still too early to notice memory
problems I was wondering if this is the right direction. The building walls are
mainly made of boxes while the floors (most parts) are made of prisms. As you
can imagine there will potentially be a lot of instances for this use (i.e.
clean up).
I have not tried triangles (I have read so much about it being efficient) but I
have read so much too about it not being so stable for CSG operations.
Any insight on this from anyone?
Subject: Re: Planes (?) for cleaning building envelop (walls) through CSG.
Date: 17 Jan 2010 10:50:01
Message: <web.4b533172ebc49540772dd76f0@news.povray.org>
> clean up).
I have realized that a merge does this work well enough with some recalculation
to get the new intersections. This seems to make more sense at this point.
Date: 17 Jan 2010 11:42:52
Message: <4b533e0c@news.povray.org>
One thing to be careful of is if you're using actual shadow-casting lights
instead of ambient or some such. If you build the entire building out of one
object (e.g., a union of walls and floors), the shadow calculations will
take forever. Each light will have to test every object in the entire
structure for each ray cast.
   Forget "focus follows mouse." When do
   I get "focus follows gaze"?
Date: 17 Jan 2010 12:40:01
Message: <web.4b534ac5ebc49540772dd76f0@news.povray.org>
Thats good to know but I am good so far. I am trying to be as simple as possible
in this project so am using only boxes and prisms so far. The only CSG is on the
creation of curved walls and also in my plan for windows and doors. I suspect
also parts of the roof. I have discarded the plan for using merge at
intersections also. Prisms work very nicely.
It is important to model most items as single items because of the information
management part of the tools. I need to know precisely where things are so that
a flat drawing (plan and elevations can be extracted later).
Thanks for the comment.
Date: 18 Jan 2010 13:24:38
Message: <4b54a766$1@news.povray.org>
>> clean up).
Unless you are working with transparent walls that have
intersecting/overlaping parts and you need to remove the internal faces,
use union instead of merge. It's much faster. With an union, you only
test for the components that occupy a given, limited, area. With a
merge, you always have to test for every components.
If you create all your walls with a corner aligned to a reference plane
(one edge with a zero coordinate) and you rotate them to the desired
orientation then translate to the desired location, it's easy to have
them join cleanly.
If you use triangle, they don't have an interior. You can't use them to
remove something from something else. You can chop bits from it. You can
definetly union them with anything.
You can combine many triangles into a mesh, and it can have a definite
interior, you just need to add an "inside" vector. That way, it can be
used in CSG without any problem. If you have many walls all defined
using the same mesh, the mesh will reside in memory only once and will
be referenced as needed with some transformations. Meshes also render
fast, but a box is one of the most effecient primitive regarding
rendering speed.
When you mention "a lot of instances", you think of what order of
magnitude? POV-Ray can easily handle 100000's, or even millions,
individualy textured boxes in a single scene, plus 100's of different
prisms.
Date: 20 Jan 2010 11:35:01
Message: <web.4b572fb5ebc49540772dd76f0@news.povray.org>
I am using a union of boxes and prisms for all unclean joints.
> them join cleanly.
Imagine a +45 degree slanted wall connected to a 0 degree one. This will result
in an unclean connection. The spaces around the connection has to be filled and
some parts cut off. This is the problem I was describing. Also, the dimensions
need to be extracted for automatic creation of clean 2D flat drawings that are
construction document-level quality. Maybe they can be combined with another
drawing (as references) after extraction from POV-Ray but I do not want them to
be brushed-up or cleaned.
> rendering speed.
I wish to keep away from triangles although I feel that I will use them in the
roof construction. I get a headache handling them... for now.
> prisms.
A typically residential building (which is my focus for now) would probably use
a few hundred boxes. I am also modeling finishes as boxes because I need to
calculate construction cost, etc.
Date: 20 Jan 2010 11:50:01
Message: <web.4b5733a6ebc49540772dd76f0@news.povray.org>
Actually, am still using planes to cut the parts that need to be removed in the
connection. So a part of my original question is still valid. Is it OK regarding
memory, using so many planes in a scene (a few hundreds for sure)
Date: 21 Jan 2010 22:16:25
Message: <4b591889$1@news.povray.org>
A plane don't use much memory:
- A directional vector (a group of 3 floats)
- A distance from the origin (a single float)
- possibly a texture
- possibly some transformation
You'd need many thousands, even millions, before your planes start to
cause memory isue. So, several 100's is entirely OK memory whise.
I rendered scenes with over 100000 individualy textures spheres without
problem. Note that a sphere uses about the same amount of memory as a plane.
