POV-Ray : Newsgroups : povray.advanced-users : Blurred reflections Server Time
28 Apr 2024 22:25:45 EDT (-0400)
  Blurred reflections (Message 3 to 12 of 12)
<<< Previous 2 Messages Goto Initial 10 Messages
Subject: Re: Blurred reflections
Date: 6 Feb 2018 08:23:26
Message: <5a79ac4e$1@news.povray.org>
The scene ended up getting stuck at the 99% mark of the preview mosaic
stage for several hours, and I had to stop it.
3.8.0-alpha.9475849+av541.msvc14.win64
Mike
Date: 6 Feb 2018 08:45:17
Message: <5a79b16d$1@news.povray.org>
Am 06.02.2018 um 03:06 schrieb Mike Horvath:
> Also, is there a way to speed this up? Right now it's stuck at 6% of the
> mosaic phase for an hour. I don't recall UberPOV being this slow. :(
The example given in the knowledgebase article uses the so-called
"macronormals" approach, as opposed to the "micronormals" approach that
is only described in the text itself.
Blurred reflections always need oversampling, i.e. at some point the ray
has to be split up into multiple rays that go into slightly different
directions.
With the macronormals approach, that oversampling is done upon
reflection: Wherever a ray is reflected at an object, the ray is split
up into a fixed number of sub-rays. The drawback is that any sub-ray
that also hits a blurred-reflective surface will be split up even
further into the same number of sub-sub-rays. In a scene with many
blurred-reflective surfaces, this causes render times to explode.
The micronormals approach can also be used in the same mode of operation
(essentially just replacing "scale 1000" with e.g. "scale 0.001"), but
alternatively it can be used with just one single texture (rather than
the average of a high number of textures) and some means of effecting
oversampling at the pixel level. This avoids the explosion of render
time in blurred-reflection-heavy scenes. (The drawback is that it also
increases render time for portions of the scene that have no blurred
rteflections; however, this can be partially mitigated by employing an
adaptive mechanism for the oversampling at the pixel level.)
The latter is essentially the mode of operation UberPOV uses. To effect
oversampling at the pixel level, UberPOV provides a special
anti-aliasing mode that shoots a number of rays randomly within each
pixel, and uses stochastic analysis to adapt the number of rays shot per
pixel to the image content.
In official POV-Ray, a very similar oversampling can be effected by
using ever so slight focal blur; adaptive focal blur is recommended in
that case.
A completely different approach to avoid the explosion of tertiary rays
is to provide two copies of each blurred-reflective object: One with
blurred reflections using an average of many textures and the
"no_reflection no_radiosity no_refraction" keyword, and one with just
one plain texture (or a low-quality blurred reflection) and the
"no_image" keyword. However, this approach breaks down if a
blurred-reflective surface is to be visible in a perfect mirror.
Date: 6 Feb 2018 19:14:49
Message: <5a7a44f9@news.povray.org>
> directions.
> that case.
In that case, you can use the micronormals way.
If using mocronormals, you need to use antialiasing to get decent
results. In some cases, you may need to increase the recursion depth by
one or two notches : +r4 or +r5.
Date: 6 Feb 2018 20:17:53
Message: <5a7a53c1@news.povray.org>
I tried scaling by 1/1000 instead of 1000, but the render time has not
improved noticeably. UberPOV blurred reflection is still much much faster.
Mike
Date: 7 Feb 2018 15:41:28
Message: <5a7b6478$1@news.povray.org>
Am 07.02.2018 um 02:17 schrieb Mike Horvath:
Just replacing macro- with micronormals doesn't do anything to render
times. The key is to get rid of the `average texture_map` and use just a
single texture.
Date: 8 Feb 2018 00:11:25
Message: <5a7bdbfd$1@news.povray.org>
> single texture.
So, all I have to do is add a tiny focal blur?
Mike
Date: 8 Feb 2018 04:15:47
Message: <5a7c1543$1@news.povray.org>
Am 08.02.2018 um 06:11 schrieb Mike Horvath:
>>> faster.
>> single texture.
Provided you're indeed using a single texture rather than `average
texture_map` and all that jazz - yes.
The quality of the blurred reflections will then depend on the focal
blur settings.
Date: 8 Feb 2018 16:08:44
Message: <5a7cbc5c@news.povray.org>
>>> faster.
>> single texture.
> Mike
It's an option.
You also can use antiliasing, possibly with some tewaking, like going
from the defaul recussion level of 3 to 4. Adding +r4 on the command
line will do the trick.
Date: 8 Feb 2018 18:12:40
Message: <5a7cd968$1@news.povray.org>
>>>> faster.
>>> single texture.
> blur settings.
Could you provide a short example? As I am not clear on how it works
without seeing some code.
Better yet, update the wiki article.
http://wiki.povray.org/content/Knowledgebase:Language_Questions_and_Tips#Topic_13
Mike
Date: 10 Feb 2018 15:59:26
Message: <5a7f5d2e$1@news.povray.org>
>> Mike
> It's an option.
Okay, I added some focal blur.
camera
	perspective
	up		Camera_Up
	right		Camera_Right
	location	Camera_Location
	direction	Camera_Direction
	focal_point 	Camera_LookAt
	aperture	4
	blur_samples	20
	transform {Camera_Transform}
But I don't see any difference in the object reflections like there is
in UberPOV.
Mike
