POV-Ray : Newsgroups : povray.advanced-users : rgb vs srgb Server Time
28 Sep 2024 18:52:07 EDT (-0400)
  rgb vs srgb (Message 1 to 10 of 48)
Subject: rgb vs srgb
Date: 9 Sep 2011 10:27:50
Message: <4e6a2266$1@news.povray.org>
Is it possible one way or another, to determine/calculate the srgb
equivalent of a given rgb vector? and vice-versa of course?
Subject: Re: rgb vs srgb
Date: 9 Sep 2011 10:56:59
Message: <4e6a293b@news.povray.org>
  Try the method described here: http://en.wikipedia.org/wiki/SRGB
Date: 10 Sep 2011 02:49:44
Message: <4e6b0888$1@news.povray.org>
Am 09.09.2011 16:27, schrieb Thomas de Groot:
This is surely possible but the way it is done depends on what you
actually mean by 'rgb'.
Assuming you mean the rgb color space that is using the same primaries
as sRGB but is in linear space (i.e scRGB) all you need is a gamma
transformation like:
#declare sRGB_Gamma = function(C) {
   select(C-0.0031308, C*12.92 : 1.055*pow(C,1/2.4)-0.055)
and the inverse for sRGB -> scRGB:
#declare sRGB_GammaInverse = function(C) {
   select(C-0.04045, C/12.92, pow((C+0.055)/1.055,2.4))
Assuming both input and output within 0.0 - 1.0 range.
Now just write macros that do handle the 3 color channels with these
functions but keep filter and transmit values untouched.
Otherwise (when you are not referring to scRGB) you'll need to transform
it via CIE xyz color space where my CIE.inc file should come in handy.
-Ive
P.S. untested code as I do not have POV-Ray available atm.
Date: 10 Sep 2011 03:51:32
Message: <4e6b1704$1@news.povray.org>
Thank you Warp and Ive. Let me try to be a bit more explicit. It boils
down to the need of having a real srgb color picker, as was already
discussed/wished in these ng's some time ago. All color pickers (like
Sven's for instance) that I know of use (linear) rgb as far as I am aware.
As a user of Poser and Poseray, I often like to tone the skin of the
human figures. The latest Poseray version does this nicely with some
added macros where you just have to put in the tone's srgb values.
However, that is where my problem arises: I can define those tones in my
ancient PSP or in the latest Gimp, but those give the values in linear
space. So, to get the result I want I have to correct the Poseray output
just by changing 'srgb' into 'rgb' where necessary. If not, the result
is way to dark in general. This works but is a bit fastidious. Better
would be to have the 'real' srgb values of the tones from start. I hope
I made myself clear...
Date: 10 Sep 2011 05:06:33
Message: <4e6b2899@news.povray.org>
Am 10.09.2011 09:50, schrieb Thomas de Groot:
While I'm not aware of any that *does* use *linear* rgb values (don't
know about "Sven's" though).
> space.
I really doubt that.
Sorry, but I've got the feeling that there is some fundamental
misconception on your side. sRGB is by definition gamma corrected
(composed of two functions as shown in my last post) and the linear
variant of it is called scRGB and this *linear* rgb space should be used
for *any* kind of math applied to colors (that is why POV-Ray
internally always assumes linear rgb values). But I don't know what
FlyerX actually does as I'm just using PoseRay's geometry output in
combination with my own textures.
Actually I'm not using PoseRay anymore as it does not work on my machine
(x64 with AMD OpenGL drivers) but this is a different story...
> I hope I made myself clear...
...nope :(
-Ive
Date: 10 Sep 2011 07:21:08
Message: <4e6b4824@news.povray.org>
>> aware.
Right. I see I have got it all wrong obviously... ;-) What I mean is
simply the use of rgb (as in POV-Ray) versus srgb (as in POV-Ray too).
>> space.
I am sure you do :-)
> for *any* kind of math applied to colors (that is why POV-Ray internally
> always assumes linear rgb values). But I don't know what FlyerX actually
> does as I'm just using PoseRay's geometry output in combination with my
> own textures.
What I see in POV-Ray is that, e.g. rgb <213,127,79> does not render
identical to srgb <213,127,79>. I would like to know what srgb values
correspond to the given rgb ones. This is independent, I assume, of what
Poseray does...
> ...nope :(
<sigh> I was not surprised...
Date: 10 Sep 2011 08:12:44
Message: <4e6b543c$1@news.povray.org>
> Poseray does...
obviously: rgb <213,127,79>/255 and srgb <213,127,79>/255
Date: 10 Sep 2011 08:23:48
Message: <4e6b56d4@news.povray.org>
Am 10.09.2011 13:20, schrieb Thomas de Groot:
Well, assuming you are *not* talking about HDR values but actually mean
"<213,127,79> / 255" what is wrong with using the functions given within
my very first reply?
#macro scRGB_to_sRGB(Color)
    rgb <sRGB_Gamma(Color.red),
	sRGB_Gamma(Color.green),
	sRGB_Gamma(Color.blue)>
if you need the inverse transformation or actually want to input values
in 8bit (0..255) range I'll leave it up to you to write these macro as
an exercise ;)
But what I do not get is why you do not simply type srgb <whatever
values> when you are actually using sRGB values (e.g. from a color
picker) and rgb <whatever values> when using linear values.
-Ive
Date: 10 Sep 2011 10:48:04
Message: <4e6b78a4$1@news.povray.org>
> #end
No HDR! I shall try this indeed.
> an exercise ;)
<grin> I am not really good at this. I am even awfully moronic to tell
the truth ;-)
Well mainly because color pickers give values as rgb. If I want to use
that same shade as srgb, for example in Poseray, I do not know what the
corresponding values are. However, your functions may help me with that
indeed! Thanks!!
Date: 10 Sep 2011 12:58:47
Message: <4e6b9747@news.povray.org>
>> #end
>> an exercise ;)
> the truth ;-)
> indeed! Thanks!!
> Thomas
Almost all colour pickers, like the ones in Gimp or Paint, work in sRGB
space. They assume a source encoded in sRGB space and return a value
that is assumed to be used in the sRGB space.
Just try picking colour for 25%, 50% and 75% grays and see the actual
results...
