POV-Ray : Newsgroups : povray.advanced-users : Using lightmaps generated with POV back into POV textures Server Time
14 Dec 2025 16:54:40 EST (-0500)
  Using lightmaps generated with POV back into POV textures (Message 1 to 7 of 7)
Subject: Using lightmaps generated with POV back into POV textures
Date: 27 Jan 2011 05:22:48
Message: <4d414778$1@news.povray.org>
Hi Gurus:
   I'm back at trying to develop my "texture baking" experiments into a
more serious and usable technique for general usage. I'm working on a
demo scene (and the corresponding how-to) with bundled tools to automate
the process as much as possible.
   So far, the "direct texture baking" approach is working pretty well:
when I use the baked textures back into the textures, without lighting,
the result is the expected one (see living_room-tb.jpg on p.b.i.).
   But the "lightmapping" approach is giving me some headaches... the
problem is not the map generation itself, but the "loading back" step
where I "mix" the desired final pigment and the lightmap. This is what
CG people calls "modulating" the texture with the lightmap. Everyone
seems to be doing it just with multiplication, but I can't get good
results with this method... not even multpliying it twice (see
living_room-lm1.jpg and living_room-lm2.jpg on p.b.i.).
   Can anyone think of a better (more suited) operation than simple
multiplication?
// macro baked_texture()
// params:
// * p_lightmap: lightmap pigment
// * t_pigment: pigment to combine with the lightmap
// * t_finish: finish for the resulting texture
// * t_normal: normal for the resulting texture
// description:
// creates an uv mapped texture by multiplying the specified pigments
// and adding the specified finish and normal statements
// uv_mapping is added to pigment and normal individually to allow
// for texture layering over the resulting texture
// min() is used on the lightmap function to avoid strange artifacts
// when using interpolation (not present when using 3.6)
#macro baked_texture(p_lightmap,t_pigment,t_finish,t_normal)
   #local ft_pigment = function { pigment { t_pigment } };
   #local fp_lightmap = function { pigment { p_lightmap } };
   #local RED = pigment {
     function { ft_pigment(x,y,z).red * min(fp_lightmap(x,y,z).red,1) }
     color_map { [0 rgb 0][1 rgb <1,0,0>] }
   #local GREEN = pigment {
     function { ft_pigment(x,y,z).green * min(fp_lightmap(x,y,z).green,1) }
     color_map { [0 rgb 0][1 rgb <0,1,0>] }
   #local BLUE = pigment {
     function { ft_pigment(x,y,z).blue * min(fp_lightmap(x,y,z).blue,1) }
     color_map { [0 rgb 0][1 rgb <0,0,1>] }
   #local TC = pigment {
     function { ft_pigment(x,y,z).transmit }
     color_map { [0 rgb 0][1 rgb 0 transmit 1] }
   #local FC = pigment {
     function { ft_pigment(x,y,z).filter }
     color_map { [0 rgb 0][1 rgb 0 filter 1] }
   texture{
     pigment{
       uv_mapping
       average
       pigment_map{
         [1 RED]
         [1 GREEN]
         [1 BLUE]
         [1 TC]
         [1 FC]
     finish{
       t_finish
       emission 5
     normal{
       uv_mapping
       t_normal
Jaime Vives Piqueres
http://www.ignorancia.org
Subject: Re: Using lightmaps generated with POV back into POV textures
Date: 27 Jan 2011 08:08:39
Message: <4d416e57@news.povray.org>
Am 27.01.2011 11:22, schrieb Jaime Vives Piqueres:
> multiplication?
No ;)
I think just *one* multiplication should do it.
Actually it looks to me like the saved lightmap file is not linear. Or
maybe it gets gamma corrected when loading it back?
Have you used OpenEXR files for the lightmap or something else?
And that min() bothers me as it defeats the idea of HDR lighting.
What kind of artefacts do you get?
-Ive
Date: 27 Jan 2011 09:52:48
Message: <4d4186c0$1@news.povray.org>
>> multiplication?
> No ;)
   I think it is linear, as I'm using assumed_gamma 1 and the output is
PNG, but I'm never sure about anything if gamma is involved. ;)
   Unfortunately I cannot use OpenEXR, as POV-Ray doesn't supports alpha
output on these... and I need it for the trick which "grows" the UV maps
to avoid the visible seams (of course, HDR output will be the best
solution).
  Well, as I'm not using HDR, I guess it shouldn't matter.
   Dot-artifacts, exactly them same ones that FlyerX was describing on
this thread:
http://news.povray.org/povray.general/thread/%3C4ca53804$1@news.povray.org%3E/?ttop=355419&toff=50
   In the mean time, I got slighty better results using the
multiplication and then applying to the result the formula for the Gimp
"overlay" mode. Also, I'm not sure if baking lightmaps with white
pigments on the objects was the best choice... perhaps a medium grey
would get better results? (trying it now...)
Date: 27 Jan 2011 12:53:24
Message: <4d41b114@news.povray.org>
Am 27.01.2011 15:52, schrieb Jaime Vives Piqueres:
> solution).
Have you actually tried OpenEXR? This file format *does* support alpha
and IIRC there was once a bug (with alpha getting inverted or some such)
but it should work fine now - haven't tried it myself since quite some time.
Sure, but this is quite a limitation when used for exactly this purpose.
> Dot-artifacts, exactly them same ones that FlyerX was describing on this
> thread:
I see. Looks like a POV-Bug. Have you considered filing a bug report
before it is too late ;) - which reminds me that I wanted also report
one more definite bug but for the moment I cannot remember what it was.
> In the mean time, I got slighty better results using the multiplication
> and then applying to the result the formula for the Gimp "overlay" mode.
> Also, I'm not sure if baking lightmaps with white pigments on the
> objects was the best choice... perhaps a medium grey would get better
Hmm, should help as radiosity (unless you use insane settings) tends to
flatten the lighting and this effect does become much more prominent
when using plain white as pigment.
And I think I'm beginning to see the cause of the problem: there is too
much light distributed as all objects whithin the scene are equally
bright. So - purely judged from your posted example images - I would try
to apply a power function on the lightmap (kind of inverse gamma)
*before* doing the multiplication, like:
function { ft_pigment(x,y,z).red * pow(fp_lightmap(x,y,z).red,
MyLightmapExponent) }
-Ive
Date: 27 Jan 2011 13:01:32
Message: <4d41b2fc@news.povray.org>
> thread:
This might be related to a bug I've been meaning to report. Image_maps,
when interpolated (2,3 or 4) and made into functions, tend to produce
horrible dot artifacts. I haven't tested it with the last two beta
versions, but it would seem that the artifacts are still present :(
Sam
Date: 27 Jan 2011 14:43:59
Message: <4d41caff$1@news.povray.org>
   (In moments like this one, I realize how appropriate was the choice
of the name for my site domain... :)
   No, actually I didn't try OpenEXR... I tried Radiance (.hdr), which
doesn't support alpha, and I assumed this was the only HDR output in
POV-Ray 3.7! I should read the new docs ASAP...
   BTW, I just tried OpenEXR output and it worked perfectly for light
mapping, as soon as I found out that I had to adjust the the 0-1 range
to 0-255 (thanks, Sam: I realized it when reading your latest post!).
     function { ft_pigment(x,y,z).red * fp_lightmap(x,y,z).red/255 }
     color_map { [0 rgb 0][1 rgb <255,0,0>] }
   Did I ever mention that I'm waaaay too lazy? ...well, OK, only for
this time I will try overcome my aversion for bug reporting.
   Thanks for your excellent advice, as usual...
Date: 27 Jan 2011 15:02:52
Message: <4d41cf6c@news.povray.org>
/Your/ post reminded me to make light of this issue :) As it turns out
(thanks to Ive's input), a higher value than 255 might be needed for
some images.
Sam
