POV-Ray : Newsgroups : povray.advanced-users : 24 and 32 bit heightfields Server Time
9 Jun 2026 08:02:14 EDT (-0400)
  24 and 32 bit heightfields (Message 3 to 12 of 12)
<<< Previous 2 Messages Goto Initial 10 Messages
Subject: Re: 24 and 32 bit heightfields
Date: 20 Oct 2009 13:26:51
Message: <4addf2db$1@news.povray.org>
SharkD wrote:
> I write in more detail about this here:
> http://isometricland.com/povray/povray_high_precision_heightfields.php
It's rather specialized. I think it would only make sense
to implement this in POV-Ray if the height_field object would
then also support the higher resolution.
Also, instead of again using a hacked format like it was done
with 16-bit TGA, it might be preferrable to use a 32-bit TIFF.
Possibly the hdr file format could be of interest as well? Of
course, most software likely won't read that either ;) I think
someone was already looking into improving TIFF support for 3.7,
maybe this would become practicable as a side effect.
PS: Your keyboard chart generator looks nice.
Date: 28 Oct 2009 21:42:51
Message: <4ae8f31b$1@news.povray.org>
Is TIFF better in some way than PNG?
Mike
Date: 28 Oct 2009 23:02:33
Message: <+kdNnsCmWQ6KFwHS@econym.demon.co.uk>
The TIFF specs allow you to directly specify 24 or 32 bit greyscale.
Other programs that handle TIFF files will know that it is a greyscale
image (some may not necessarily be able to render it). It might even be
possible to find a graphics application that does support that format
and be able to do useful things like blur the image, thus smoothing the
heightfield.
The PNG specs only allow 8 or 16 bit greyscale. You can hack the format
by setting the parameters to say that the image is a normal full colour
PNG with transparency, and get 8 bits for each of the R, G, B and A
channels, then use the red channel as the high order 8 bits, etc. Other
programs that handle PNG files will render it as full colour with
transparency. It will not be possible to find graphics applications that
would be able to manipulate the image as if it were greyscale.
Mike Williams
Gentleman of Leisure
Date: 29 Oct 2009 03:08:13
Message: <4ae93f5d$1@news.povray.org>
What can you do in grayscale that you can't do in RGB?
Let's say that instead of 8 bits per channel, each channel instead only
held 10 values, from 0 through 9. You could then represent the three
channels as a decimal value between 0.000 and 0.999 with each channel
corresponding to a decimal place.
If you had two "colors" (color is actually meaningless here), 0.345 and
0.765, "blurring" them would result in the average, or 0.555, which is a
valid result.
Granted, creating heightfields from a gradient would require more work
than a simple grayscale image. But if your paint application supported
working on channels independently, then you'd still only need to apply a
different gradient to each channel.
Mike
Date: 29 Oct 2009 03:55:54
Message: <Mw6BSZC7pU6KFwhN@econym.demon.co.uk>
One thing that would go wrong is that bits wouldn't be carried between
channels.
Consider the border of regions with these 32-bit greyscale values
        00000001-00000000-00000000-00000000
        00000000-00000000-00000000-00000000
What we'd like is for a three-pixel-radius blur to output values like
        00000000-11000000-00000000-00000000
        00000000-10000000-00000000-00000000
        00000000-01000000-00000000-00000000
as we approach and cross the boundary, but if the channels are blurred
independently that can't happen.
An application that treats the image as RGBA won't produce bright blue
by blurring together what it sees as dark red and black.
Mike Williams
Date: 29 Oct 2009 08:29:07
Message: <4ae98a93$1@news.povray.org>
The old hacked formats were invented because (a) formats with the same
capabilities didn't exist, or could be processed only by very few
applications, while converters were difficult to find, and (b) they were
necessary.
Now again, formats supporting 32-bit greyscale are few, and the programs
supporting them are even fewer. What's different, however, is that they
are not needed.
16-bit depth greyscale formats were required to eliminate terracing with
height fields, which would be a common effect with 8-bit depth images.
Even with a uniform slope, terracing would occur at resolutions as low
as 256x256.
With 16 bit depth, however, you can represent...
... the entire earth's topology (including ocean floors) to a vertical
resolution of ca. 30 cm, or 1'0".
... the entire earth's continental topology (i.e. above ocean level) to
a vertical resolition of about 15 cm, or 6".
... a section of the Grand Canyon to a vertical resolution of about 2,5
cm, or 1".
If you really /need/ such a high vertical resolution (and can't get away
with a 16-bit floating-point based format for instance, placing the
range of highest precision around the camera elevation), chances are
you're doin' it wrong, and that nobody will really bother to implement
input/output routines for some exotic file format in POV-Ray just to
help you out, unless he's at it anyway and implementing it would be just
a few lines extra.
The good news is that I think nobody will bother to hack some other file
format to serve that purpose either - at least as far as official
POV-Ray is concerned.
Date: 29 Oct 2009 08:31:21
Message: <4ae98b19$1@news.povray.org>
> valid result.
Not so for, say, 0.500 and 0.600: Obviously the proper result should be
0.550, but averaging on a per-digit base would yield 0.500 or 0.600,
depending on your rounding mode.
Date: 30 Oct 2009 00:10:53
Message: <4aea674d@news.povray.org>
Ah, OK. I was mistaken.
Mike
Date: 30 Oct 2009 00:17:23
Message: <4aea68d3@news.povray.org>
> cm, or 1".
Artifacts would be noticable if, say, your were rendering an image of a
lizard with the Grand Canyon visible in the background. But, you're
right, that level of precision wouldn't make much of a difference in the
majority of heightfields. It *would* make a difference if you wanted
smooth transitions between scales on a spherical, isosurface model of
the Earth. But isosurfaces aren't based on bitmap data...
Mike
Date: 30 Oct 2009 08:59:28
Message: <4aeae330$1@news.povray.org>
Man, you'd need some kind of supercomputer to model the entire grand canyon
in enough detail to do a close-up of a lizard on it...
Use some kind of level of detail scheme (ie further away parts are modelled
at lower resolution) - then you'll find that 16 bits of vertical resolution
is plenty for the scene you mention.
