POV-Ray : Newsgroups : povray.advanced-users : light filter in media Server Time
8 Jul 2024 20:06:28 EDT (-0400)
  light filter in media (Message 1 to 8 of 8)
Subject: light filter in media
Date: 23 Dec 2007 21:15:01
Message: <web.476f153cc3e5249f534b0ad0@news.povray.org>
Can someone help me out with this scene? I'm trying to create a glowing
cylindrical object (to look like a spotlight that fallsoff without using an
actual light source) and I'm getting some results that look like coincident
surfaces. Code is below.
Also, how would I go about modifying this so it does not look like a black end
has been pasted on a green cylinder?
#declare cam_pos=(x*4+y*3+z*-2)*2;
 location cam_pos
 look_at (x*1+y*0+z*0)*0.5
light_source {
 cam_pos
 color White
 cylinder { 0, <1,0,0>, 1
                gradient x
                pigment_map{
                        [0.0 color Green filter 1]
                        [0.05 color Green filter 1]
                        [0.8 color Green filter 0]
                        [1.0 color Green filter 0]
        hollow
        finish{ ambient 0.000 diffuse 0.000 specular 0}
        interior{
                media{
                        emission 1
        scale x*3
light_source{
        cam_pos
        color White
Subject: Re: light filter in media
Date: 24 Dec 2007 02:44:55
Message: <476f6377@news.povray.org>
Woody napsal(a):
make the cylinder a little bit shorter or scale the pigment. Your
pigment has a sharp transition right on the {x,3} surface.
Date: 24 Dec 2007 09:25:01
Message: <web.476fc11381a774e8c150d4c10@news.povray.org>
Coincident surfaces also occur with patterns like gradient.  There is a hard
transition from 1 back to zero at each frequency.  Adjust the map size or the
cylinder size as you would for any coincident surface.
-tgq
Date: 24 Dec 2007 15:32:31
Message: <4770175f$1@news.povray.org>
Woody nous apporta ses lumieres en ce 2007/12/23 21:11:
I would alter the scene as follow:
> camera {
>  location cam_pos
> light_source {
>  cam_pos
>  color White // add *2 if this light is not bright enough
         pigment {rgbt 1} // No need to see the container
         hollow
         interior{
                 media{
                         emission y/2 // to prevent the oversaturation
//adjust the colour to your taste
                         density {gradient -x scale 1.01}//prevent second ramp
from apearing
         scale x*3
> //remove this second light. It will make the rendering faster.
> light_source{
>         cam_pos
>         color White
Whenever you have more than 1 light_source at the same location you should
replace them with a single one having the sum of all the original ones. It
render faster as you now need only 1 shadow test instead of two, or more. The
color value of a light is not limited to 1.
light_source{0 color 2}
and
light_source{0 color 1} light_source{0 color 1}
both have exactly the same effect on your scene.
But I thought YOU did the backups...
Date: 25 Dec 2007 19:50:00
Message: <web.4771a51a81a774e87ae6bc470@news.povray.org>
> and
> Alain
The double light was actually an accident. But thanks for the info. I was not
aware of light_sources being greater than 1. Thanks for all the good advice.
Date: 26 Dec 2007 14:21:38
Message: <4772a9c2@news.povray.org>
Woody nous apporta ses lumieres en ce 2007/12/25 19:49:
>> and
>> Alain
In the samples scenes, there is one with a light that have a value of 1000!
I drive way too fast to worry about cholesterol.
Date: 2 Jan 2008 02:30:00
Message: <web.477b3afd81a774e878dcad930@news.povray.org>
> Can someone help me out with this scene? ...I'm getting some results that look
> like coincident surfaces.
Another solution would be to add a slight translation to your color_map, which
will pull its sharp index-list "crossover" position away from the cylinder's
end cap:
                 gradient x
                 pigment_map{
                  translate .0001*x
                  ...etc. ....
Ken W.
Date: 2 Jan 2008 02:45:01
Message: <web.477b3f5781a774e878dcad930@news.povray.org>
Looking over your scene code and running it, I was wondering if the following
alternate code is what you're trying to achieve? I've reworked yours (and
eliminated the lights, which actually aren't necessary):
 location cam_pos
   hollow
         pigment {color rgbt 1} // transparent
         finish{ ambient 0.000 diffuse 0.000 specular 0} // finish is optional
      // with this rgbt 1 object
        interior{
                media{
                        emission .6
                        density{
                            gradient x
                            color_map{
                               [0.0 color Green] // green media
                               [1.0 color rgb 0] // no media at all
        scale x*3
Ken W.
