POV-Ray : Newsgroups : povray.advanced-users : I really really want n-sided bezier patches... Server Time
17 May 2026 22:41:50 EDT (-0400)
  I really really want n-sided bezier patches... (Message 11 to 20 of 28)
<<< Previous 10 Messages Goto Latest 10 Messages Next 8 Messages >>>
Subject: Re: I really really want n-sided bezier patches...
Date: 23 Aug 2002 07:43:15
Message: <3d661fd3@news.povray.org>
Micha Riser wrote:
> mesh support uv_mapping as well.
I had forgotten that. However, I still want to use mesh2, because it
cuts down the number of calculations to one sixth. That's quite a big
difference.
> However you have to see that not the whole uv space
> from <0,0> to <1,1> is mapped onto the triangle but
> only half of it!
Yes. :)
> I do not really see an easy non-recursive way
> that does an equally sized subdivison.
I just saw now that the method I used doesn't create an even
distribution. The triangles are a bit bigger towards one of the sides,
probably the w one (even though the control points are the same for the
three sides). However, when looking at your method, it produces the
exact same result, which is also not evenly distributed. Perhaps this is
related to the 'normalisation property'?
If that is the case, making the implementation hold the normalisation
property would be important for UV mapping (and of course it's also
nicest in general if the triangles are evenly distributed). However, at
least the uneven distribution doesn't affect the joining of patches,
since it doesn't affect the edges of the patch.
I'll post some code to povray.binaries.scene-files which shows how to
use a double loop to generate the triangles, and which also show the
uneven distribution clearly (both with the subdivision and the double
loop approach).
> I'll try 5 and 6 sided as well. But these formulas
> probalby are quite a bit messy.
I can imagine. I hope you manage to implement them anyway.
Rune
rune|vision:  http://runevision.com (updated July 12)
POV-Ray Ring: http://webring.povray.co.uk
Date: 23 Aug 2002 09:18:34
Message: <3d66362a@news.povray.org>
> difference.
I have modified my recurisve version so that it passes the points along, so
that all points/normals are calculated only once (has the side effect that
normals are calculated even with non-smooth, but this could be changed as
well).
>> only half of it!
> Yes. :)
But here it the problem. We just use two of the three symmetric vectors
u,v,w for the mapping. This means that in uv-space two sides of the
triangle have size 1 but the third has length sqrt(2)!
No, I have modified it to hold the 'normalisation property'. There is a
change but hardly noticeable. I have also added uv-mapping and the example
shows the problem with it: the w-side (where w=0) crosses uv-space from
<0,0> to <1,1>.
New version in p.b.s-f.
> 3D images and anims, include files, tutorials and more:
If you'd use '-- ' as signature separator I would not be tempted to quote
your signature as my news reader would recognise it as signature then and
automatically cut aways on replying.
- Micha
http://objects.povworld.org - the POV-Ray Objects Collection
Date: 23 Aug 2002 10:48:31
Message: <3d664b3f@news.povray.org>
> the points along, so that all points/normals are
> calculated only once (has the side effect that normals
> changed as well).
That's a big improvement then. But since mesh2 objects are still much
smaller in size, I still think I'll try to make it into a mesh2. It's
not in a big hurry now though, so I'll wait little with that until more
important issues have been solved.
> three symmetric vectors u,v,w for the mapping.
> sqrt(2)!
No, that's just because of the UV vectors you used. You didn't add
support for custom UV vectors, but simply used <0,0>, <1,0> and <0,1>.
With custom UV vectors each side could have any length you want.
The real problem is that the distribution of the triangles is (still)
not even. Apparently it's not related to the normalisation property
then, because I can't see any difference from before.
If, instead of applying UV mapping, you color the individual triangles
individually (like in the version I posted), you will see that at the
third edge the triangles are (still) bigger than at the other edges. I
suppose you don't know how that can be fixed? :/
Outlook Express' fault. But I really thought that the program
OE-QuoteFix was supposed to take care of this problem. Maybe it
doesn't... :(
By the way, should the third character be a regular space, or some
different character that looks the same way as a regular space (if such
a thing exists)?
Rune
Date: 23 Aug 2002 10:56:38
Message: <3d664d26@news.povray.org>
> triangles is (still) not even. Apparently it's
> not related to the normalisation property then,
> individual triangles individually (like in the
> version I posted), you will see that at the third
> other edges. I suppose you don't know how that
> can be fixed? :/
Hmm, I found the solution. Change the value of epsilon1 from 0.001 to
1.0. I don't know why, but it fixes the distortion and makes the
distribution completely even. :)
As I assumed, it was something with how the w value was calculated.
Apparently, if 1-2*u*v is smaller than 1.0, then no division should
happen at all (or a division by 1). I found out by coincidence more or
less, so don't ask me why...
Rune
Date: 23 Aug 2002 11:28:38
Message: <3d6654a5@news.povray.org>
>> sqrt(2)!
In uv-space the triangles are ditributed even. If you make patch that has
the shape of an isosceles , rectangulare triangle then you will
see that all triangles are of (nearly) same size (because uv-space has the
same distances as realspace). Try:
 object{ bezier3triangles(
                 <0,0,0>,<1/3,0,1/3>,<2/3,0,2/3>,  // under line
                 <1,0,1>,<2/3,0,1>,<1/3,0,1>,  // right line
                 <0,0,1>,<0,0,2/3>,<0,0,1/3>, // left line
                 <0.25,0,0.4>,<0.6,0,0.8>,<0.2,0,0.8> // inner points
                 ,5,1,0) // depth, smoothing, enable visible control points
        texture{uv_mapping pigment{checker Red, Green scale .1}}
Now imagine this rectangular triangle being transformed into a equilateral
one.. the result is what you see in your example.
The program works as expected. It just depends on the shape of the triangle
how equally the triangles are sized. I could tweak it so that they were
equally-sized on equilateral patch size.. but this would not change the
uv-mapping. To solve your problem one probably has to add support for
arbitrary edge points in uv-space for the triangle.
> a thing exists)?
Just a plain simple regulare space.
- Micha
Date: 23 Aug 2002 11:52:30
Message: <3d665a3e@news.povray.org>
A few more comments...
I did a new comparing of the patch with and without the normalisation
property, and there is indeed a quite visible difference, so I think
it's a good thing it was implemented, even though it slows down the
calculations.
And about optimisation - the fact that your recursive version passes the
points along doesn't mean that they are only calculated once. They are
calculated twize, because each edge is shared by two triangles, and when
you divide an edge in two, you do it for both triangles.
Rune
Date: 23 Aug 2002 12:12:38
Message: <3d665ef6$1@news.povray.org>
> If you make patch that has the shape of an isosceles,
> rectangulare triangle then you will see that all
> has the same distances as realspace).
But by this, you are saying that the w value is not like the u and v
values. I don't think this fits with the ideology behind the 3-sided
bezier patch. There is not supposed to be any difference between the
three sides.
> It just depends on the shape of the triangle how
> that they were equally-sized on equilateral patch size..
As I wrote, when you change the epsilon1 value to 1, then the
distribution is even for a equilateral triangle and there is no
difference between the three sides. I'm pretty convinced that this is
how it's actually supposed to work, and I don't think it's a random
"tweak" but rather a correction.
Now it does. :)
> for arbitrary edge points in uv-space for the triangle.
The uneven distribution and the UV mapping are two completely different
issues. The UV mapping never was a problem, and as I said earlier, I do
indeed intent to add support for custom UV vectors for the UV mapping.
The uneven distribution was the actual problem, but I found the solution
for that (changing the epsilon) so now there's no problem at all...
There is a white space in the messages I send. If it's not there when
they arrive, then Outlook Express must somehow remove them. :(
Rune
Date: 23 Aug 2002 12:31:04
Message: <3d666345@news.povray.org>
NOO! What you get is no longer a bezier patch! You lose the C-1 continuity
at the borders! You can clearly see this when you set the tanget vectors to
0.7 in your example.
Date: 23 Aug 2002 12:45:54
Message: <3d6666c2@news.povray.org>
> Now it does. :)
It does no more :(
As the distribution exactly uses the uv-points which I it is the same
problem. In regards to the formula u,v,w are exactly symmetric (as long as
you do not chang epislon1).
evil program
- Micha
Date: 23 Aug 2002 12:46:50
Message: <3d6666fa@news.povray.org>
> calculations.
it just doubled the formula's length..
That's true indeed.
