POV-Ray : Newsgroups : moray.win : animation within animation Server Time
19 Jul 2026 23:27:30 EDT (-0400)
  animation within animation (Message 1 to 9 of 9)
Subject: animation within animation
Date: 26 Oct 2006 17:56:08
Message: <45412ef8$1@news.povray.org>
Hello all.
I am getting back into animation after a couple of years break, and I would
like some help with creating a moving television or picture animation within
an animation.
(details).  I have a pre recorded video of some students of my karate club
at a tournament, and I would like to include some footage of them in an
animation created with Moray & PovRay.
Is there a tutorial anywhere that could help me.
I have found animations on the PovRay site where this is done, but have no
idea how to achieve this.
Thanks Alex.
Subject: Re: animation within animation
Date: 27 Oct 2006 01:50:00
Message: <web.45419da58edb802b772850b00@news.povray.org>
Hi.  First of all, I should mention that I'm not a Moray user...
When you did animations in the past were you doing the animating portion in
Moray or in Pov-Ray?  If you're already used to converting numbers &
associating segments of animation in Pov-Ray with different values of clock
or frame_number it's a good start.
If you've got some software which can convert your video into a sequence of
numbered files (similar to what Pov-Ray outputs in animation mode) then
with some string-manipulation you should be able to read in individual
frames of video and slap them onto your 3d model using image_map (3.5.1.5.1
 in docs).
What format is the video in? Maybe somebody will have a suggestion for
turning the video into individual frames....
Hope this helps some
Charles
"Alex McMurray" <ale### [at] melbpcorgau> wrote:
> Hello all.
> an animation.
> Thanks Alex.
Date: 27 Oct 2006 02:49:25
Message: <4541abf5@news.povray.org>
"Charles C" <nomail@nomail> wrote in message
news:web.45419da58edb802b772850b00@news.povray.org...
> in
> clock
I used both in the past, Moray for quick tests to see that it comes out as
it should, then PovRay for the final movie.
> of
> (3.5.1.5.1
> in docs).
At the moment the video is still on 8mm Digital tape, my video software,
Pinnacle Studio 9 is capable of saving in multiple formats.
I was hoping not to go down the road of having to save the video as
individual images, hoping to find a patch or shortcut that would allow a
video to be taken frame by frame directly off the video file, but if there
is none, then that is the way I will have to go.
The reason being that I wanted to have a number of movies within movies
going at the same time, as in a series of screens with video images going
on, and the camera dollies past each one.
There will be a large number of images for 4 or 5 files.
Thanks anyway.
Alex.
Date: 27 Oct 2006 04:00:01
Message: <web.4541bc448edb802bf1cb1e660@news.povray.org>
> Hello all.
> an animation.
> Thanks Alex.
post it in p.b.i as UV Mapped Cylinder - Map01a.avi but it has disappeared.
The only way I know how to do it is as Charles says, extract the frames and
use them as image maps on your TV screen.
Even though this uses a lot of disc space it does have the advantage of
knowing what will be showing on the screen at each stage of your animation.
Date: 27 Oct 2006 07:53:59
Message: <4541f357@news.povray.org>
Well, there is another (more CPU and disk-space intensive) way...a while
back I experimented with DF3s, building a block where each slice is a
frame of an animation, then translating the texture through a container
which only shows one slice at a time, and having the media of the
density map set to be either emitting (for a CRT) or absorbing (for a
filmstrip)...
Tim Cook
Version: 3.12
Date: 27 Oct 2006 08:10:00
Message: <web.4541f6198edb802bf1cb1e660@news.povray.org>
> filmstrip)...
I remember that! You should have posted a link.
Did you ever get it to display in colour?
Date: 27 Oct 2006 16:04:14
Message: <4542663e$1@news.povray.org>
I couldn't find it T_T
Yes, by way of making three separate DF3s, one each for red, green, and
blue, then stacking the containing boxes (if they exactly line up they
have coincident surface issues).
Tim Cook
Version: 3.12
Date: 29 Oct 2006 15:25:59
Message: <ki3ak2922ua1r04re3bimndi50e00ddfgk@4ax.com>
On Fri, 27 Oct 2006 16:04:13 -0400, Tim Cook <z99### [at] bellsouthnet> wrote:
I did something similar about the same time using three df3's I made from the
"Invisible Orchard's" Cubic Mandelbrot code. Only I used one containing box with
a material that had three emitting medias in the interior. Each media used its
own df3 file. I have just tried to reproduce it using a photo and extracting the
R,G and B channels to no avail. I can't get an image, drat! I can't find my
original scene as I did it two system crashes ago :-(
Regards
Date: 25 Sep 2007 18:17:16
Message: <46f988ec$1@news.povray.org>
I've done it here, for testing:
http://fr.youtube.com/watch?v=UkA37wdw5BA
Large BMP with four frames... And sliding on X...
Kzerphii
4541f357@news.povray.org...
>> and
> which only shows one slice at a time, and having the media of the density
> filmstrip)...
> Tim Cook
> http://home.bellsouth.net/p/PWP-empyrean
> -----BEGIN GEEK CODE BLOCK-----
> Version: 3.12
> GFA dpu- s: a?-- C++(++++) U P? L E--- W++(+++)>$
> N++ o? K- w(+) O? M-(--) V? PS+(+++) PE(--) Y(--)
> PGP-(--) t* 5++>+++++ X+ R* tv+ b++(+++) DI
> D++(---) G(++) e*>++ h+ !r--- !y--
> ------END GEEK CODE BLOCK------
