POV-Ray : Newsgroups : povray.unofficial.patches : Megapov error whith skyvase.pov Server Time
13 Mar 2026 16:17:08 EDT (-0400)
  Megapov error whith skyvase.pov (Message 11 to 14 of 14)
Subject: Re: Megapov error whith skyvase.pov
Date: 30 May 2001 20:03:19
Message: <slrn9has0u.127.steve@zero-pps.localdomain>
On Wed, 30 May 2001 09:26:53 +0200, Thorsten Froehlich wrote:
>In article <3b142d2c$1@news.povray.org> , "Bob H." <omn### [at] msncom>
>wrote:
>> Yes, but couldn't the +b1000 throw a wrench into the works?
>No, it actually reduces memory use compared to say +b1 (a few bytes only in
>skyvase.pov in either case).  You could set it to +b1000000 and it would not
>require more memory than +b1000 in any case.
Just done a couple more texts and found that just -i skyvase.pov +b100 works,
but if I use +b1000 in conjusction with the other options that come before it
(from the benchmark site), then it doesn't work in megapov but does in standard
3.1g.
 10:57pm  up 117 days, 23:46,  2 users,  load average: 1.17, 1.10, 1.09
Date: 31 May 2001 08:38:06
Message: <3B15F4DC.498D5A7F@mail.ourservers.net>
I get the above error with MegaPOV v0.7 on OpenVMS Alpha if I try to use
the "+Mv2.0" setting.  If I leave that out, it compiles just fine with
all the
other options.
	$ megapovray +i skyvase.pov +v1 -d +ft -x +a0.300 +r3 +b1000
                     +w640 +h480
Works where..
                     +mV2.0 +w640 +h480
dosen't work and gives the above error.
 | Robert Alan Byer | bye### [at] mailourserversnet | ICQ #65926579 |
 | Send an E-mail request to obtain a copy of my PGP key.      |
 | "It is by caffeine alone I set my mind in motion.  It is by |
 |  cans of cola the thoughts aquire speed, the hands aquire   |
 |  shakes, the shakes become a warning.  It is by caffeine    |
 |  alone I set my mind in motion."                            |
Date: 31 May 2001 17:30:15
Message: <3b16b7e7@news.povray.org>
In article <3B15F4DC.498D5A7F@mail.ourservers.net> , Robert Alan Byer
> all the
> other options.
Yes, because the syntax in the scene file is 3.0 syntax and you obviously
get an error when enforcing version 2.0 syntax.  The version of skyvase.pov
included in 3.1 clearly states that it has been updated to use new 3.1
syntax features.
    Thorsten
e-mail: tho### [at] trfde
Date: 2 Jun 2001 11:05:56
Message: <3b1900d4@news.povray.org>
I rememember having a similar problem when I moved from mp0.4 to 0.6
and see I've got a textures6.inc with "#version unofficial MegaPov
0.6;" added as the first line, and a skyvase6.pov which uses that
include. Both have the comment "Mods to remove MP6's error message". I
can no longer repeat the error and there have been no major system
changes since.
I'm using DOS versions of pov and mega, usualy under a Win98SE prompt.
Alf
http://www.peake42.freeserve.co.uk/
http://ourworld.compuserve.com/homepages/Alf_Peake/
gw3### [at] thersgbnet
