![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Using version 3.1g, I can't seem to create checker textures properly, at
least for planes. If I specify
pigment {checker X White}
where X is any pre-defined colour, I always get a plane which appears to
have
pigment {checker Green White}
Is this a known bug, as I've only just started using POV-Ray and am not up
to speed yet? Thanks
Chris
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> have
> Chris
It is not a bug. You MUST specify both colors with a comma seperating
them.
In your case it should be pigment { checker X, White }
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
>them.
Though I consider the fact that a comma is necessary a bug. I think
I posted the fix to bugreports, but it was a long time ago. Basically,
POV sees "Puce Chartreuse" as just "Chartreuse".
Ron Parker http://www2.fwi.com/~parkerr/traces.html
My opinions. Mine. Not anyone else's.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Ron Parker <ron### [at] povray org> wrote:
: Though I consider the fact that a comma is necessary a bug.
I would consider not throwing a syntax error when there isn't a comma a bug.
If you see "comma expected but blah blah found instead" you will probably
see quite fast what is the problem.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
That would be true if commas were required anywhere else in the language.
As it is, they're only required when it's necessary to disambiguate the
elements of a vector ( <1,-2,3> vs. <1 -2 3>, one of which is a 3-vector
and one of which is a 2-vector.)
Besides, the problem stems from the fact that POV doesn't recognize a
difference between
Puce Chartreuse
and
red 1 green .7 blue .1 green 1
If the latter followed "checker", where would you expect to find the comma?
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
: red 1 green .7 blue .1 green 1
: If the latter followed "checker", where would you expect to find the comma?
Well, that's why I think comma should be required. That is, support for
a checker statement with only one parameter instead of two should be
removed. It will only do good.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
I suggested a transparent (i.e. doesn't break most existing scenes) workaround
in .bugreports when I originally posted the problem:
|Unfortunately, you can also say "color Red Green" and get green. This
|is not documented, and is probably a bug (the docs do say COLOUR_IDs
|should come first.) Parse_Colour should probably UNGET and EXIT when
|it gets a second instance of any of COLOUR_ID, rgb, rgbt, rgbf, rgbft,
|or a bare vector expression. This would make rgb 1 red 0 legal as a
|shortcut for cyan, but make rgb 1 rgb 0 become two separate colors,
|suitable for use in checkers or bricks or hexagons.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Ok, thanks for that. Just one remaining question - why the hell does it
replace the "unspecified" colour with Green?
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Because the rather unintuitive defaults for checker are, IIRC, yellow and
green.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
